Cab mount chop without welding a plate
Discussion in '3rd Gen. Tacomas (2016-2023)' started by batong_23, Jun 26, 2021.
  1. Jun 26, 2021 at 12:25 AM
    batong_23
    batong_23 [OP] vincedprince
    SoCal
    2017 white toyota tacoma trd sport
    Like the title itself, has anyone done the CMC on their tacoma but didn't weld a plate to cover it?
  2. Jun 26, 2021 at 1:25 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    You're not welding the plate on as a cover...it's structural.
  3. Jun 26, 2021 at 1:32 AM
    TacoJoeBro
    TacoJoeBro Well-Known Member
    Not Joe
    Midwest
    12 DCSB OffRoad
    6112/5160 Icon RXT JBA KO2
    I've seen pics here on TW, without the plate welded on. I'm sure there is structural sacrifice not having it, then again the engineers that designed it would argue about the sacrifice of cutting it at all. That being said, the ones without the plate claim it's only for aesthetics. Personally I wouldn't want it open either way, just to keep crap like mud and debris out of there.
    ORtoCOTaco and ClassyTacos like this.
  4. Jun 26, 2021 at 1:44 AM
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    Don't make a hack job out of it, do it right. As others said above, that plate is welded in for structural support, not just aesthetics. Leaving it open allows all kinds of water and crap to get in there, rust it away from the inside out, and make it that much easier for the already compromised structure to buckle/break off. On top of just looking hacky and gross.
    It's a complicated cut/weld to make look good, so get a good welder to do it right. Or you can spend a few bucks on a mount relocation kit, so you can lop off the stock mounting points altogether and have a simpler, cleaner solution.
    Mark77, dubktrd, roundrocktom and 2 others like this.
  5. Jun 26, 2021 at 4:45 AM
    NorNev
    NorNev Phone? Call someone who gives a shit.
    Dave
    39° 31′ 6″ N, 119° 59′ 19″ W
    KDMAX Tuned 17 2•2X2•2 Hood Scoop
    A Few
    My question is, why not? It’s a straight forward project. Order the plates @ $25, chop, weld, then paint.
  6. Jun 26, 2021 at 5:12 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Mud, dirt, crap will get in there. And it does look unfinished. Also, when any car guy looks at it unfinished it kind of sets the pace for the whole build like nothing was done right. Just my opinion, sometimes it makes sense to cut corners, sometimes no no. This is a corner not worth cutting.
    Dirk Diggler likes this.
  7. Jun 26, 2021 at 5:20 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Welding a cover over the hackjob with your $299 harbor freight Flux core machine does not "restore the structural integrity".
    Fill the cavity with body and paint it black.
    *edit: meant to type body filler
    Mark77 likes this.
  8. Jun 26, 2021 at 6:12 AM
    batong_23
    SoCal
    That's what I was gonna do.. how come those welders won't do it?
  9. Jun 26, 2021 at 6:14 AM
    batong_23
    SoCal
    Relocation is the only option for my 35s coz even with the hack job that I did leaving it open, if I weld a plate on it, for sure it will rub again
    NorNev[QUOTED] likes this.
  10. Jun 26, 2021 at 7:16 AM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    I'm genuinely curious. Two real points of opposition have been brought up.
    1. Structural integrity
    2. Collecting debris
    I guess the first point could be argued, but there are thousands of people that have cut the mount and drive it without welding a plate. I've never heard of any sort of flex or breakage. I'm no expert, just bringing up a point. The debris problem really floors me though. There is a huge hole right there from the factory. If anything, the open cmc would give the ability to actually clean it out.
    The last objection is the way it looks. After the pinch weld smash I don't think anyone is going to notice a clean cut cmc, but that is definitely opinion
    SethM likes this.
  11. Jun 26, 2021 at 7:20 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    I see what you did here
    ClassyTacos[QUOTED] likes this.
  12. Jun 26, 2021 at 7:21 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    I have a welder from HF. Its good enough to weld damascus billets together for.forge welding, but thats about it. I wouldnt trust it for mahor structural stuff on my truck. Ive made some tools stands and things with it, but thats it.
