C1433 Steering Angle Sensor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by duswhit, Jan 26, 2022.
  1. Jan 26, 2022 at 9:18 AM
    duswhit
    duswhit [OP] Member
    Dustin
    Kenosha, WI
    2018 TRD Sport
    OME Kit 005, Freedom Offroad UCAs, 33" BFG K02, Rear Diff Breather EXT. KB Voodoo 18" Bed Rack, Tuff Stuff ALPHA Tent
    Back story: During the process of replacing the starter on my 18' TRD Sport I mistakenly let the steering wheel column rotate freely and destroy the internal clock spring. This resulted in loss of power to all steering wheel buttons, as well as causing Lane Departure Assist, ABS, Airbag, and Cruise control lights to appear on the dash.
    Replaced the clock spring with an Ebay knockoff and regained the horn along with all steering wheel controls. All lights have remained on the dash though, showing that there is still something wrong with the Steering Angle Sensor. Code C1433 Steering Angle Sensor Internal Circuit is given and comes back immediately after being cleared.
    I attempted to do a VSC zero point calibration by shorting out the pins with no luck.
    My question is if the actual sensor itself is fried and needs to be replace. I'm having a hard time finding information on whether or not over rotating the steering wheel can destroy the sensor the same way it destroyed the clock spring.
    Any insight is appreciated. Thanks
  2. Jan 26, 2022 at 11:37 AM
    BmTaco91
    BmTaco91 Well-Known Member
    Alberta Canada
    2021 AC TRD OR 6MT
    You might need a good scan tool to do a EPS Relearn .
  3. Jan 26, 2022 at 12:08 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    I thought the spiral cable was built into the same assembly as the sensor. Manual seems to imply that separating them would be 'crossing the stream type of bad'
    Here is some data for DTC C1432 and C1433.
    This will be kinda hard to read, I will try to remember to upload the service manual pages rather than paste in the data later.
    DTC C1432 Steering Angle Sensor Power Source Voltage Malfunction
    DESCRIPTION
    Steering angle sensor (spiral cable with sensor sub-assembly) signals are sent to the skid control ECU (master
    cylinder solenoid) via the CAN communication system. When there is a malfunction in the CAN communication
    system, it is detected by the steering angle sensor zero point malfunction diagnostic function.
    DTC
    CODE
    DTC DETECTION CONDITION TROUBLE AREA
    C1432
    A steering angle sensor power supply malfunction
    signal is received from the steering angle sensor.
    ECU-B NO. 2 fuse
    ECU-IG NO. 3 fuse
    sensor sub-assembly) power supply
    sensor sub-assembly)​
    When the speed sensor or the yaw rate and acceleration sensor (airbag sensor assembly) has trouble,
    DTCs for the steering angle sensor (spiral cable with sensor sub-assembly) may be stored even when the
    steering angle sensor (spiral cable with sensor sub-assembly) is normal. When DTCs for the speed sensor
    or yaw rate and acceleration sensor (airbag sensor assembly) are output together with DTCs for the
    steering angle sensor (spiral cable with sensor sub-assembly), inspect and repair the speed sensor and
    yaw rate and acceleration sensor (airbag sensor assembly) first, and then inspect and repair the steering
    angle sensor (spiral cable with sensor sub-assembly).​
    DTC C1433 Steering Angle Sensor Internal Circuit
    DESCRIPTION
    The skid control ECU (brake actuator assembly) outputs this DTC when it receives an internal malfunction signal
    DTC
    NO.
    DETECTION ITEM DTC DETECTION CONDITION TROUBLE AREA
    C1433
    Steering Angle
    Sensor Internal
    Circuit
    With the +BS terminal voltage 9.5 to 17.4 V, the
    skid control ECU receives an error signal from
    Steering angle sensor (Spiral
    cable with sensor
    sub-assembly)
    INSPECTION PROCEDURE
    HINT:
    When U0073, U0124 and/or U0126 is output together with C1433, inspect and repair the trouble areas
    indicated by U0073, U0124 and/or U0126 first .
    When any of the speed sensors or the yaw rate and acceleration sensor (airbag sensor assembly) has
    trouble, DTCs for the steering angle sensor (spiral cable with sensor sub-assembly) may be output even
    when the steering angle sensor (spiral cable with sensor sub-assembly) is normal. When DTCs for the
    speed sensors or yaw rate and acceleration sensor (airbag sensor assembly) are output together with DTCs
    for the steering angle sensor (spiral cable with sensor sub-assembly), inspect and repair the speed sensor
    and yaw rate and acceleration sensor (airbag sensor assembly) first, and then inspect and repair the
    steering angle sensor (spiral cable with sensor sub-assembly).
    PROCEDURE
    1. REPLACE SPIRAL CABLE WITH SENSOR SUB-ASSEMBLY
    (a) Replace the spiral cable with sensor sub-assembly .
    NOTICE:
    Do not remove the steering angle sensor from the spiral cable with sensor sub-assembly.
    When replacing the spiral cable with sensor sub-assembly, confirm that the replacement part is of the
    correct specification.​
    Kev250R likes this.
  4. Jan 27, 2022 at 5:09 AM
    duswhit
    duswhit [OP] Member
    Dustin
    Kenosha, WI
    2018 TRD Sport
    That's also where I'm confused, when referring to the sensor sub-assembly it's referring to the steering angle sensor correct? To replace the spiral cable itself the old steering angle sensor must be removed from the original spiral cable and clipped to the new one.
  5. Mar 16, 2022 at 4:30 PM
    duswhit
    duswhit [OP] Member
    Dustin
    Kenosha, WI
    2018 TRD Sport
    UPDATE: Ordered a new steering angle sensor and replaced the old one now all dash lights are gone.
    I'm assuming that the sensor was fried along with the Clock spring when the steering wheel rotated freely.
    Kev250R and hiPSI like this.
  6. Mar 22, 2022 at 11:29 PM
    Mk hawaii
    Mk hawaii New Member
    2021 tacoma
    I have the same code on my truck after replacing the steering rack. All my steering wheel controls and horn still work, do you think I have to change the whole clock spring assembly or just the steering angle sensor?
  7. Mar 23, 2022 at 5:50 AM
    duswhit
    duswhit [OP] Member
    Dustin
    Kenosha, WI
    2018 TRD Sport
    When I replaced the clock spring I only regained control of the steering controls, to get all the codes to permanently clear I had to replace the steering angle sensor.
    I would figure if you still have wheel controls that the clock spring should be fine
  8. Mar 23, 2022 at 9:19 PM
    Mk hawaii
    2021 tacoma
    Where did you get that steering angle sensor from ? I seen some cheap ones on eBay but I might just get a genuine.
  9. Mar 24, 2022 at 3:34 AM
    duswhit
    duswhit [OP] Member
    Dustin
    Kenosha, WI
    2018 TRD Sport
    I bought cheap knockoffs from ebay for both the clock spring and steering angle sensor. Neither have given me an issue so far, it was about $70 for the SAS. If I had the money I probably would have gone withe the OEM, the price difference is just so large
    Bryan Mejia likes this.
  10. May 9, 2022 at 8:28 PM
    Bryan Mejia
    Bryan Mejia New Member
    2018 Toyota Tacoma sport 4x4
    I have the same issue, I have a Christmas tree on my dashboard,I got my truck diagnosed and my steering angle internal circuit is messed up, I’ve been to like 2 shops in socal trying to see if they can replace it but they all say only the dealer can do it, did you just replace your SAS and that was it, you didn’t have to calibrate or anything like that, because I’ll just do it myself if I don’t have to do any computer diagnosing or something like that .
