C Rated or E Rated Tires....What Do You Run?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WreckedRooster, Dec 9, 2020.
Which Tires Do You Prefer?
  1. C Load Rating
    182 vote(s)
    54.0%
  2. E Load Rating
    155 vote(s)
    46.0%
  1. Dec 9, 2020 at 6:43 AM
    WreckedRooster
    WreckedRooster [OP] Well-Known Member
    Jake
    Oklahoma
    2020 MGM DCSB
    **Update at bottom of post**
    I'll be honest and say I didn't realize there were load ratings when it came to tires (and my Dad works for Michelin :facepalm:). That being said and looking back, I believe I've mainly ran E rated tires. I'm currently running 285/75r16 KO2's that are E rated. They don't (and I have no idea why) make C rated tires in this size.
    With that being said, I'm wondering is it worth it to buy 17 inch wheels and run the equivalent 285/70r17 tire that does have C rated options? I've never ran C rated tires and would like to hear from those that have ran both E and C load range tires (especially on the Tacoma) to see what your thoughts are. My current wheels and tires are less than a year old, so it's a big purchase to change to 17" wheels and new tires. Of course, I'll be able to sell mine to recover some of the cost.
    • C load from what I've read:
      • Softer daily ride but get chewed up on trails
      • Lighter, so you save gas
      • Don't last as long
    • E load from what I've read (and experience):
      • Super tough tire
      • Last forever
      • Heavier, so you lose mpg
      • Stiff, seemingly harsher ride on the Tacoma - I run at 32 psi to help
    Unsprung weight is a big deal for mpg and performance (from what I've read). And the C load 17" equivalent is over 8 lbs lighter. That's 32 lbs total unsprung weight savings. The new 17" wheels I'm looking at weigh as much as my current 16" wheels. Weight specs on each tire:
    • 285/75r16 E Load = 58.6 lbs
    • 285/70r17 C Load = 50.3 lbs
    With all of that being said, what's your preference?
    **Update**
    X factor, my wife drives a Lexus GX460 with 18's and 33" E rated tires. If I went up to 17's and she dropped down to 17's, we could both buy either C or E rated 285/70r17 tires and be able to use each other's spares when we go on trips. Wanting to build a teardrop/squaredrop trailer and I could run the same size tires on it as well for more versatility.
  2. Dec 9, 2020 at 6:51 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    XL here, for what little it's worth..
    Nitto Ridge Grapplers 265/65/17 40.2 lbs.
    Lightweight, silent on the road, and do fine on the hard pack clay and smooth rock fire roads of SE Tennessee.
    R4D4G4ST, TacoBuffet and LV-TAC like this.
  3. Dec 9, 2020 at 6:51 AM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    I run E rated mud tires. All the things you said are true regarding sidewall stiffness and having a “harsher” ride on the street. I don’t mind. Off road they can be aired down without me worrying about side wall puncture. Also at speed they are less prone to getting torn up by rocks and what not on the trail.
    One way to alleviate the harsh street ride is to run lower psi (27psi). Not good for handling and mileage but it makes the ride way softer.
    If you off road a good amount then E rated is what you want
    Side Note , I don’t think they will “last forever”. My mud tires have a softer rubber compound which is awesome for grip but they wear fast .
  4. Dec 9, 2020 at 6:57 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I had C and E load. I prefer C with stock sport suspension. E load rode like bricks on my sport. The only advantage was, my truck cornered like a sports car.
    It doesnt corner as well with C load, but man its a way nicer ride, especially offroad. I noticed no difference in fuel mileage, which is strange.
    IMHO e load is overkill for our tacos, unless you offroad a lot and air down often.
    I will always buy C load from now on.
    ZColorado, Fast1, knayrb and 2 others like this.
  5. Dec 9, 2020 at 6:58 AM
    Tnc
    Tnc Well-Known Member
    Tim
    NE Oklahoma
    2017 DCLB TRD OR
    E rated every time for me. Minimum of 5 miles every day on gravel roads. Anything less than 10 ply (rated) won’t last for me.
    Edit for clarification
    Charlie Too and Junkhead like this.
  6. Dec 9, 2020 at 7:00 AM
    vanrynd
    vanrynd Well-Known Member
    dan
    West Chester, Pa
    2017 Off Road DCLB
    WIP
  7. Dec 9, 2020 at 7:05 AM
    AutoTaco
    AutoTaco Well-Known Member
    Jay
    Pittsburgh, PA
    2021 Lunar Rock TRD Pro
    Calliraised Sliders, Diamondback HD, 265/75 Wildpeaks
    I went with C. I don’t plan on adding a ton of weight to my truck, and I only intend on traveling lighter trails.
  8. Dec 9, 2020 at 7:07 AM
    lilyota12
    lilyota12 Well-Known Member
    Shredona
    2012 Tacoma DCSB 4.0 TRD Off-Road
    See Build Thread
    I run C rated Duratracs now and I love them over the old E rated ones I was running before. They are a lot smoother ride and less weight, and I have never had any durability issues offroad when rock crawling aired down or busting down fire roads. In the future I would only go E rated if that was my only choice.
  9. Dec 9, 2020 at 7:18 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    E load does not have 10 plies, just so you know. Its 10 ply "rated". Google it.
    R4D4G4ST and DRAWN like this.
  10. Dec 9, 2020 at 7:24 AM
    Tnc
    Tim
    NE Oklahoma
    2017 DCLB TRD OR
    Thanks guy. My tire shop guy calls them 10 ply so I call them 10 ply. E rated, 10 ply. All the same in my book. I’m sure most here know what I meant.
    Junkhead[QUOTED] likes this.
  11. Dec 9, 2020 at 7:25 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Fair enough sir.
    Tnc[QUOTED] likes this.
  12. Dec 9, 2020 at 7:27 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I have 285 70 17 KO2 in C load, 51 lbs.
    On all the C load KO2s I have got around 55K miles out of them. I could have gone more on them.
    With a 2 inch lift, leer canopy, I’m still getting around 17 or 18 mpg combined.
    Not a 3rd Gen though so you should get better mpg than me.
  13. Dec 9, 2020 at 7:34 AM
    su.b.rat
    su.b.rat broken truck
    strictly E ranges here, Cooper AT3 LTs 265/70-17. C tires would not allow me to throw the truck around like E's do. need all the sidewall firmness i can get, and those Coopers are great. i had C's for about 400 miles and it was the most boring 400mi I've had with the truck. no C's ever again for me.
    Junkhead likes this.
  14. Dec 9, 2020 at 7:35 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
  15. Dec 9, 2020 at 7:36 AM
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    Back in 2017 went from stock to C rated KO2 265/70/17 on the Tacoma. Rode much better than stock. Got flat(nail) and repaired it, going strong for 2+ years now. Moved the KO2 to 4Runner and upgraded to 33s E rated WildPeaks on the Tacoma. Definitely cornered much better and you can def tell it is firmer. I like both so much that as of now I couldn't decide which one to get next time around. If you aren't too sure or haven't rode on C/E rated, probably stick with C to be safe. Finally I'll just say this, C feels nice and you can feel that it's slightly firmer than stock. E noticeably feels firmer. Love it when attacking the corners :D so....maybe I'll stick with E LOL :burnrubber:
  16. Dec 9, 2020 at 7:36 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    C on the Tacoma, E on the Duramax for pulling the heavy loads. C's ride smoother.
    Newwt, GarlicFarts, boston23 and 3 others like this.
  17. Dec 9, 2020 at 7:40 AM
    VeeSix
    VeeSix Yotahead, Deadhead.
    Tennessee, USA
    2011 Tacoma 4x4
    2018 Tacoma - gone 2003 Tacoma - gone 1983 FJ60 - gone 1988 BJ73 - gone 1992 FJ80 - eternal
    E. All I've ever run. No difference in mileage at all that I can see, and they last for years and years. Any imaginary mileage difference is more than made up for by the amazing durability and life span.
  18. Dec 9, 2020 at 7:42 AM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    I put E rated on my 4Runner. Great for preventing sidewall punctures, but could definitely feel the added weight, especially with the increase in braking distance. Sharp rocks, sticks, soybean fields or other sidewall hazards would justify the E rated. Otherwise for mostly street and mild trails, C rated probably better on the tacoma for most.
    BC Hunter, barch88, OZ TRD and 2 others like this.
  19. Dec 9, 2020 at 8:17 AM
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    I am running E Load Duratracs at present, I really don't feel a lot of difference from C Load on the pavement, even the fuel mileage difference is barely noticeable (maybe 1/2mpg, if that). Although C Load tires would probably suffice for my typical off road driving, the difference in price is minimal ($12 per tire), and I feel more confident off road, especially aired down with the E's. The sidewall puncture resistance is better with E's, which is a bigger concern here in Texas with the sharp rocks and thorns encountered, but for many, that wouldn't be as big of concern. I would avoid anything less than C Load as it does begin to negatively affect your off road options, and there's even a C Load minimum requirement to get permitted for unmaintained areas in parts of SW Texas state lands (i.e. BBRSP).
    BC Hunter likes this.
  20. Dec 9, 2020 at 8:18 AM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Just went for E to C because I got a steal on them. I am hoping to get ~50k miles on them. I am heavy af so this thread is making me a bit nervous.
    I got ~70k out of my load E Copper Maxx.
    Currently running load C Nitto Ridgegrapplers
