C or E KO2
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chaboi, Oct 16, 2015.
  1. Oct 16, 2015 at 12:46 AM
    Chaboi
    Chaboi [OP] Well-Known Member
    I don't "wheel" anything like what Mike330 did in his great post about his off road gen3. TRDORDCLB coming in soon and need to decide which tires to get. New wheels are 17" so going 265/70/17 just need to know if I really need E rated. Road ride is really important.
    My off roading is only on fire roads, but they can have larger sized gravel chunks and some larger rocks in the road. I am on these roads 2+ times/week. Thoughts?
  2. Oct 16, 2015 at 12:59 AM
    Maximus
    Maximus Well-Known Member
    North Bay
    11 Tacoma TRD OR 4x4
    Icon Suspension with CDCV, SPC Light Racing UCAs, Wheeler's 3 Leaf AAL, Wheeler's Superbumps, sPod SE BAMF Sliders, All-Pro Skids, AFE Drop in filter, Magnaflow Exhaust, RCI Aluminum LCA Skids, BAMF Bed Brackets, 4X Innovations Rear Bumper, FX-R Retrofit Headlights with Philips 4300k, Custom Nestah Edition Firestik AM/FM Antenna, Famous Fab Hood brackets, FrontRunner SlimLine 2 Roof Rack, Mob Town Offroad tailgate reinforcement plate, Ram A pillar mount, Anti-Dark hood lights, Lots of LED lights,
    E is unnecessary. Stick with C if you can. Your ride quality will be a lot better and your fuel economy will not take that much of a hit.
  3. Oct 16, 2015 at 1:04 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    E is for a 1-ton full size trucks carrying loads that would crush the Tacoma. They should be avoided if possible as they are very heavy and will have a stiff sidewall resulting in a poor ride and poor mpgs. Go with C-load whenever possible, they will handle off road conditions far better than stock.
  4. Oct 16, 2015 at 1:06 AM
    Chaboi
    I just notice a lot of people on here go with E load. Is that because of lack of load options for the KO2?
    Avoiding punctures is important.
  5. Oct 16, 2015 at 1:13 AM
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    Thats the only reason I have E tires. mastercraft C/T.
  6. Oct 16, 2015 at 1:13 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    C-load will avoid punctures just fine. Many go with E-load because the KO2 is not available in C-load in the 16" wheel size, which most Tacomas have. I switched to 17" wheels specifically so I could run them in C.
    Cs weigh 45lbs, Es weigh 53lbs. Rotating mass is equivilant to 4x static mass, meaning that 8lbs x4 wheels X 4 factor is equivalent to adding 128lbs to your truck. I wheel in sharp volcanic rock with Cs for 10 years and never punctured a sidewall.
    Chaboi[OP] likes this.
  7. Oct 16, 2015 at 1:19 AM
    Chaboi
    What about tread punctures? When I mountain bike its tread punctures that seem more common than anything. Mike330 had a rock gash through the tread on the stock GY adventure At w/ Kevlar.
  8. Oct 16, 2015 at 1:31 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    You don't need E.. don't talk yourself into an E, either.
    Mountain bike tires are not at all comparable or relevant to what is an appropriate tire for a Tacoma.
  9. Oct 16, 2015 at 5:29 AM
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    C, but it has to be a quality c. E rated tires are not needed on a small truck like the tacoma. I have driven thousands and thousands of dirt road and jeep trail miles in Tacomas and F150s doing overland trips and biological work all over the west. C range is all we run and we rarely get flats. When we do, it is usually a nail that even an E rated tire would have picked up.
  10. Oct 16, 2015 at 5:44 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    The C load KO2's have a 2 ply sidewall the E load has 3 ply sidewall. I personally feel by what the OP described (driving on fire roads) that the C load will be fine but if anyone is going to really push their trucks they should probably get the E load just for the extra margin of durability.
    K Mac likes this.
  11. Oct 16, 2015 at 7:08 AM
    K Mac
    K Mac Well-Known Member
    Kyle
    Saskatchewan, Canda
    2016 Quicksand TRD OR ACLB 6MT
    I think as long as it's not a duratrac C should be fine :/
    My offroading friends with C rated duratracs all went thru multiple sidewalls, but the ones with E rated duratracs have been fine... I really hope the KO2 is a better tire anyways.
  12. Oct 16, 2015 at 8:36 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Duratracs are known for having no side wall protection and not being a very durable tire despite their looks, they are classified as a 'commercial tire'. KO2s are purpose built to be a real off-road tire, designed to be air down and take significant sidewall abuse. BFG has won the Baja 1000 using the same exact KO2s we use on the street.
    I've posted this video before on the technical improvements of the KO2, including the sidewall puncture test:
    https://www.youtube.com/watch?v=K-mSQDOBmh8
    K Mac[QUOTED] likes this.
  13. Oct 16, 2015 at 8:41 AM
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
  14. Oct 16, 2015 at 9:25 AM
    VetteVert
    VetteVert Well-Known Member
    '17 Storm Trooper DCSBOR
    But no 265 75 16s in C, right?
  15. Oct 16, 2015 at 9:29 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I got E's because I couldn't find the size I wanted in C. I don't notice any difference between my E KO2's and D Duratracs.
  16. Oct 16, 2015 at 9:29 AM
    stempsons
    stempsons Well-Known Member
    SW WA
    2015 Tacoma TRD O/R 4x4 DC
    TRD Supercharged, TRD Exhaust, TRD Bead Locks, OEM Audio +, Bilstein 6112's/5160's
    KO2's come in a "D" rated 275/70/16, just a touch taller and wider than 265/70/16. Just ordered some earlier this week.
  17. Oct 16, 2015 at 9:36 AM
    VetteVert
    No rub without a lift?
  18. Oct 16, 2015 at 9:43 AM
    stempsons
    SW WA
    Not installed yet, but they're only about 1/2" bigger in width and height, so should't be a problem.
  19. Oct 16, 2015 at 9:50 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Correct. You need to go 265/70R17 to get Cs, which are the same size but use a 17" wheel. I switched to 17s for that reason.
  20. Oct 17, 2015 at 6:20 AM
    Chaboi
    Anything the C rated can't do that the E can?
