Bypassing the A/C compressor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by calmwaters3030, Jun 27, 2014.
  1. Jun 27, 2014 at 7:48 PM
    calmwaters3030
    calmwaters3030 [OP] Member
    Don
    Winnipeg Manitoba Canada
    2008 Tacoma
    Does anyone know of a pulley and bracket system you can purchase to bypass the A/C compessor on a 2008 Tacoma?
  2. Jun 27, 2014 at 8:16 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Why?
  3. Jun 27, 2014 at 8:17 PM
    calmwaters3030
    Don
    2008 Tacoma
    I want to bypass my A/C compressor
    foampile likes this.
  4. Jun 27, 2014 at 8:20 PM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    If you have a 4 cyl, PM tooter. He bypassed both his A/C and his power steering.
  5. Jun 27, 2014 at 8:25 PM
    medic2230
    Murph
    Bama! Roll Tide
    Cause it's cold in Canukistan.
    Running Board Man likes this.
  6. Jun 27, 2014 at 8:43 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    why?
    Meh...
  7. Jun 27, 2014 at 9:10 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Pull the Air Conditioner Clutch Relay Fuse. Then it is just a pulley.
    Under the hood, 10 ampere fuse labled AC.
  8. Jun 27, 2014 at 9:29 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    What about the defroster?
  9. Jun 27, 2014 at 9:33 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    X2
    Invalid.
    In all seriousness tho whats your purpose?
  10. Jun 27, 2014 at 11:53 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    It is part of the AC. It will not come on then either.
  11. Jun 28, 2014 at 5:48 AM
    calmwaters3030
    Don
    2008 Tacoma
    The the compressor dosent work and the bearing is starting to squeal. I dont use A/C so I would like to remove the entire compressor.
    Jon G likes this.
  12. Jun 28, 2014 at 8:54 AM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    You might be able to bypass your a/c compressor with just a shorter serpentine belt. If you can measure the difference with the a/c compressor and without the difference should be how much shorter a belt you will need. A good auto parts store who know about belts will be a big help. Good luck with your project.
  13. Jun 28, 2014 at 10:30 AM
    1TUFFTRD
    1TUFFTRD WTF
    06 AC with a skewp
    06 With a Skewp.
    Exactly my point.
  14. Jun 28, 2014 at 12:16 PM
    calmwaters3030
    Don
    2008 Tacoma
    That would be great. I'll have my mechanic check it out
  15. Jun 28, 2014 at 12:26 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Gas mileage difference will be very minimal without AC or even a 'dead' AC pulley.
    I'd just leave it alone and not use the AC feature, instead of pulling a fuse or using a smaller belt.... IMHO :)
  16. Jun 28, 2014 at 2:01 PM
    calmwaters3030
    Don
    2008 Tacoma
    The Bearing is making noise all the time A/c off or on. I dont want to fix the pump if I don't have to I.m not worried about gas milage or horsepower. Just looking for the cheapest way to fix the problem
  17. Jun 28, 2014 at 5:40 PM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    first make sure you're not hearing an idler or the tensioner bearing.
    if it's a 4cyl, they have a non-ac belt option; may fit w/o removal depending on how the belt is routed.
    Per my 4L. '12 as comparison (assuming the front engine config is the same as 08), looks like you can pull the compressor and probably also the lower idler beneath it.... the new belt would then travel from the alternator pulley directly to the drive pulley. May be able to keep the lower idler but don't think you can leave the compressor in place.
    Suggestion: Permanently MARK the original serpentine belt Before you remove it. Mark it on the low point of the drive pulley, say 6 o'clock and mark the belt at the 12 o'clock on the ALTERNATOR pulley. This allows measure of the length of the belt used for the a/c, from specific points on the drive pulley to the alternator pulley with the a/c equipment in the way.
    Then when the parts are off, use a flexible measure to measure the new length from same points on the ac pulley to drive pulley. Subtract from the original belt marks, and that's the length to reduce the replacement belt by..
    Got to mark it BEFORE parts removal as you want the tensioner in to show installed length.
    No additional parts should be needed.
    Good Luck.
  18. Jun 28, 2014 at 7:34 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    What would that point be exactly?
    For many many many years cars did not have the defroster mode connected to the AC System at all.
  19. Jun 28, 2014 at 9:01 PM
    calmwaters3030
    Don
    2008 Tacoma
    Yes I will identify where the sound is coming from first then decide what I will do to fix the problem. They sell bypass pulleys for othere vehicles, Just wondering if anyone has heard of any for Tacomas.
  20. Jun 28, 2014 at 9:02 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I'd bet it's not the A/C but an idler. If you unplug the electrical connector at the pump it will just free wheel and will not engage. It has an electric clutch in it.
