Buzzing Noise when Heater is Turned On
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yoda02Taco, Feb 10, 2022.
  1. Feb 10, 2022 at 3:58 PM
    Yoda02Taco
    Yoda02Taco [OP] Member
    Cal
    Mississippi
    2002 Toyota Tacoma 4x4 (four door/ silver)
    Anyone have a solution to this problem. When I turn my heater on there is a buzzing noise coming from behind the glove box. It is clearly an electrical noise. It does not get louder when I accelerate. It makes a buzzing sound for approximately 15 seconds, and then goes mute. It is very annoying.
    My local mechanic said that it was a resistor or blower motor resistor, if I’m remembering correctly.
    Solutions or thoughts? I want to do this job myself rather than take it to my mechanic. Thanks!
  2. Feb 10, 2022 at 4:03 PM
    Clearwater Bill
    Billy
    Largo Florida
    drop the blower and make sure theres no debris in it.
    While in there, check the connections. Any that look or smell burnt need replacement.
    Lenny Dykstradamus likes this.
  3. Feb 10, 2022 at 4:07 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    If your fan works on all 3 speeds it's not the resistor.
    Start by removing and cleaning the fan.
    The fan motor is behind and below the glovebox. Unclip the elect connection and remove the 3 screws to lower the fan and motor for cleaning.
  4. Feb 12, 2022 at 8:24 AM
    Motodad
    Motodad Well-Known Member
    South of Houston Texas
    5 first gens in the family. Still want more.
    Not enough
    It's probably the servo for temp control. Small plastic box on passenger side under radio. Easy to replace and can get aftermarket at auto parts. Just looked it up. Blend door actuator. I replaced blower and didn't fix noise. Replaced actuator and all good
  5. Feb 14, 2022 at 10:57 AM
    Yoda02Taco
    Cal
    Mississippi
    Thanks y’all I’ll start with those options and see what shakes out. Appreciate the feedback!
  6. Feb 14, 2022 at 7:13 PM
    Yoda02Taco
    Cal
    Mississippi
    Yep, It’s gotta be the servo temp control/ blend door actuator. The noise is definitely coming from that contraption. Ordering one stat.
    Motodad[QUOTED] likes this.
  7. Feb 14, 2022 at 7:17 PM
    Lenny Dykstradamus
    Lenny Dykstradamus Well-Known Member
    Lenny
    New York City
    Tacoma Warthog
    Maybe there is a dedicated fuse you can pull to test
