Buying a 300,000 mile tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by steele101, Oct 16, 2020.
  1. Oct 16, 2020 at 5:07 PM
    steele101
    steele101 [OP] New Member
    gen 1 tacoma
    I'm currently looking at a 2002 Toyota Tacoma, it has 282,872 miles. I'm wondering what I need to look for and if it's smart to buy a high mileage truck?
    96BlueTacos and Black DOG Lila like this.
  2. Oct 16, 2020 at 5:13 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Check for frame rust through.
    Maintenance records on high mileage are better than low miles and no maintenance.
  3. Oct 16, 2020 at 5:14 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Frame rust should be concern number 1
    Taco critter likes this.
  4. Oct 16, 2020 at 5:15 PM
    Caliph420
    Caliph420 Well-Known Member
    Washington
    2012 SR5 2.7 AC 4x4 Manual
    Not sure if “smart” is the right adjective, if you save a ton of money vs a lower miles one perhaps, but I’d seriously look at how much $$$ your really saving. And stick some of that asides just in case.
    billybop90 and Taco critter like this.
  5. Oct 16, 2020 at 5:18 PM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    I don't normally subscribe to new threads but this one got me. What's the price and what state are u in. Unless i missed the price? And frigin welcome!
  6. Oct 16, 2020 at 5:38 PM
    Ccrowe323
    Ccrowe323 Well-Known Member
    Cory
    Florida
    2001 Tacoma 3.4 DC 5speed TRD OR
    Honestly i trust a high milage vehicle with service records and owned by a small amount of people over any low milage with no service records. Because usually yeah it may have 130k or so miles but I bet it’s never had it’s timing belt done, or any of the other little stuff that just comes with putting miles on a vehicle.
    My experience with the two Tacoma’s I’ve bought are kinda funny. My original Tacoma, a 2001 double cab almost 100% rust free, very clean inside and out, bought for 11k had 211k on it, turns out the trans had pink milkshake and I didn’t know before I bought it, but with some snooping around I found that out, guessing the original radiator was never changed and it finally gave out. Also, my engine developed a weird throttle lag with a slight improvement with a MAF sensor but still does it after redoing my intake manifold gaskets, upper and lower, cleaning throttle body, IAC, etc. Also I’m very very slowly using coolant somewhere and don’t know where, could be cylinders but my compression is decently in spec. Also the crankshaft has a very slight bit of up and down play/very minimal wobble on the crankshaft pulley at idle.
    Now on to my second Tacoma I bought as a donor for my manual swap.
    A 2001 Tacoma with 295k miles on it, was a VT truck for 10 years so has a good bit of frame rust but it’s still solid all around. Some dents and dings and some body rust as well. Other than that it weirdly developed a misfire problem after about 7k miles of daily driving, but only happens when it rains and only for the first 5 minutes of driving in lower rpm in 1st and 2nd gear but afterwards doesn’t slip a beat. Other than that it runs like a champ and I drove it around 2500k miles in the month I bought it, not a single issue at all. I bought the truck for 4k, also had bumpers and sliders etc, owned by a Tacoma world member for 10 years with a crazy stack of service history and it is a solid truck, if it wasn’t for the rust I probably would have sold my double cab and kept it and fixed any little problems that pop up.
    With that being said, that’s my experience of high milage and cared for vs lower milage with limited history.
    100k miles and $7k difference.
    Milage can matter but it really comes down to how it was cared for.
    In my opinion if it has a good amount of service records and was owned by the same person for a long time and you do a good check over and it’s decently rust free I wouldn’t think about milage.
  7. Oct 16, 2020 at 5:42 PM
    steele101
    gen 1 tacoma
    I'm in Texas, near San Antonio. The price is $6,495.
  8. Oct 16, 2020 at 5:42 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    There's no reason it can't be a great vehicle with that many miles, but there's also a good chance its a mess. No guarantees either way. It all depends on how much its been maintained and what you want to put into it.
    Make sure the frame is good, everything else is pretty easily replaceable. The engine should still be good at that age, and the transmission could be ...who knows.
  9. Oct 16, 2020 at 5:43 PM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    too much
    JudoJohn likes this.
  10. Oct 16, 2020 at 6:00 PM
    Gen2Tacoma
    North East Atlanta
    Where is the truck from? I hope its Texas vin search?
  11. Oct 16, 2020 at 6:02 PM
    Gen2Tacoma
    North East Atlanta
    See my other post about where is the truck from? But it does seem high on first guess!
  12. Oct 16, 2020 at 7:13 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    An 18 year old vehicle isn't an easy thing to make a judgement call on until knowing about the upkeep. 282k truck could have everything replaced that should be, oil changes on time, etc. and a 100k mile truck could have a hacked up harness from aftermarket electronics, leaking main seal, seized calipers, bhg, etc.
  13. Oct 17, 2020 at 1:58 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    No way to really know without getting up close and in person.
    I see vehicles trashed being a few years old with 20,000 miles others 20 years old looking like they were bought off the dealers lot last week with 250,000 miles.
    It comes to the areas of the truck you focus on the most .
    GQ7227, Dalandser and Taco critter like this.
  14. Oct 17, 2020 at 5:39 AM
    aroma
    aroma Well-Known Member
    Snottsdale AZ
    I have had 2 with over 300k. No issues. Both were 5 lug 2.4 though. I paid 850 and 1700. The price is too high for the one you are looking at.
    Jcsmith1 likes this.
  15. Oct 17, 2020 at 8:10 AM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    Post pics of the listing. Otherwise 6.5k is too much.
    I’d say 3.5-4.5 is an ok price for that many miles and that old of a truck
    Burro likes this.
  16. Oct 17, 2020 at 8:50 AM
    Burro
    Burro Well-Known Member
    SoCal
    98 v6 4x4 xtracab
    I bought my truck for $3500 with 260k on it two years ago. I'd say what they're asking is pretty high. Typically they haven't done all the bushings, suspension refresh, tie rods, lbj, u joints, common wear items, tbelt, etc. Then all of that will be on you to replace. I set aside a good chunk, (about the same as what I paid for the truck) to deal with preventative maintenance and getting it back to where it should be.
    crazytacoman likes this.
  17. Oct 17, 2020 at 10:07 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    So very easy to say the price is to high when you have 10 Toyota 4x4s in the shop .
    Might not be so high of a price if you really want a 4x4 Toyota .
    It comes down to what you can afford to spend.
    I have been looking the last 5 years all the prices are more then I have saved up so far.
    GQ7227 likes this.
  18. Oct 17, 2020 at 10:30 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    290K on my 04 3.4v6 and I slap a supercharger on it 4 months ago. Still running strong.
    Wyoming09 likes this.
  19. Oct 17, 2020 at 8:23 PM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    Did you rebuild the engine?
  20. Oct 17, 2020 at 8:45 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I've said over and over the biggest enemy of the first gen. is time, particularly in harsh climes. (TX)
    Mine w/ 190Kish miles developed a clang under pass. side last week going to Lowes. Got back to house, flexed it over a ditch and started pushing/pulling rear tire. Shackle bushing is gone..like it was stolen gone. Dry rotted and fell out after the baking over the summer on the driveway. I need CV boots, shackle bushings and new brake lines (prob. all new brakes as no parts besides pads and lines have ever needed anything in past)
    Every summer is more rubber parts to change. Granted..new trucks are too high but you won't have a maint. free vehicle unless you want to run it in the ground. After 10 yrs. and especially 15. It's really for around town. Is the engine sound? Yes. Lots else involved in a 20 yr. old vehicle tho.
    It's why I don't daily an old muscle car.
