Buying a 286,000 Mile 1997 Tacoma 4x4 2.7
Discussion in '1st Gen. Tacomas (1995-2004)' started by alan.a, Nov 2, 2021.
  1. Nov 2, 2021 at 4:04 PM
    alan.a
    alan.a [OP] Active Member
    homegrown_xt likes this.
  2. Nov 2, 2021 at 4:08 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    I'd buy it for that price for sure. Used and mid-high miles are always a gamble. Always. Never know. But that thing looks well maintained and has a lot of service records to show it. I've bought two used Toyotas with over 275k-285k miles on them and drove them to well over 350+ with few issues.
    Check the lower ball joins (didn't see that on the carfax) and drive on.
    alan.a[OP] likes this.
  3. Nov 2, 2021 at 4:10 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    Hey! That truck is in my neck of the woods, not too far from where I work! Are you local to the Santa Rosa area? Good luck on that truck, Tony is a great guy!
  4. Nov 2, 2021 at 4:12 PM
    alan.a
    I talked to the actual owner of this truck on Facebook and I will see it this sunday.
    homegrown_xt[QUOTED] likes this.
  5. Nov 2, 2021 at 4:13 PM
    homegrown_xt
    Sonoma County
    Nice, looks like a real clean truck!
    Looks like the PO kept up on the maintenance of that beauty, I may have to drive by and take a look at it.
  6. Nov 2, 2021 at 4:24 PM
    alan.a
    I live in Sacramento.
  7. Nov 2, 2021 at 4:28 PM
    homegrown_xt
    Sonoma County
    Not too far of a drive, it's getting harder and harder to find these trucks in this condition.
  8. Nov 2, 2021 at 4:33 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Don't see any pictures of the underside... any rust issues?
  9. Nov 2, 2021 at 4:37 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    Alan
    Given that this is a crazy time and if there is nothing wrong with this truck so far I would want to buy it. My advice to you is get a Toyota mechanic to conduct a preliminary inspection of the engine, transmission, drive line, suspension, electricals and the body. You could very well buy into a truck that could last you until you can no longer drive it due to old age. There are maintenance procedures that you must follow like adjusting the intake and exhaust valve lash when it is due. If you ignore this type of maintenance then you could incur some exhaust valve and valve seat damage and possibly the head.
    There is also the Timing chain, timing chain guides, timing chain tensioner, sprockets ect.. It would be good if this gets replaced although I don't know the exact interval.
    If you test drive this truck and if it lacks power then you could be looking at excessive carbon build up. This is one of the reasons why I again suggest a Toyota mechanic to look at this stuff for you if you cannot do it yourself. After a serious inspection and if the truck proves to be in excellent shape I would buy it.
    If you are a gear head these 1st Gen Tacomas are easy enough to work on.
    alan.a[OP] and 0xDEADBEEF like this.
  10. Nov 2, 2021 at 4:38 PM
    alan.a
  11. Nov 2, 2021 at 4:41 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    This for sure. There could easy be $2k plus worth of work it needs if not checked out thoroughly.
    $9k is too much imo.
    Also the 3rz + auto combo is pretty lethargic, I’d hold out for a v6 or an MT.
    Das it mang and dvalente98 like this.
  12. Nov 2, 2021 at 4:43 PM
    USMILRET
    This is an example of carbon buildup in my 1998 Tacoma 4X4 SR5 2.7 engine intake side. 98 Tacoma carbon build up.jpg
    crazytacoman likes this.
  13. Nov 2, 2021 at 4:43 PM
    homegrown_xt
    Sonoma County
    If that truck is from around here it should be pretty clean, the undercarriage of my truck looks pretty much like this picture too!
  14. Nov 2, 2021 at 4:43 PM
    alan.a
    CARFAX Vehicle History Report for this 1997 TOYOTA TACOMA XTRACAB: 4TAWM72N4VZ304883
  15. Nov 2, 2021 at 4:45 PM
    homegrown_xt
    Sonoma County
    Sunday is going to be a long time to wait!
  16. Nov 2, 2021 at 4:48 PM
    USMILRET
    Das it mang likes this.
  17. Nov 2, 2021 at 4:51 PM
    alan.a
    I will still have a family mechanic look at it before purchase.
  18. Nov 2, 2021 at 5:24 PM
    0xDEADBEEF
    Make sure that they do a compression test.
    alan.a[QUOTED][OP] likes this.
  19. Nov 3, 2021 at 7:54 AM
    OffroadToy
    Looks good! Times have sure changed... years past there's no way i'd even consider buying a vehicle with over 100,000 miles but with these Toyota's it's a different story.... 200,000 miles is considered "low mileage". :eek:
  20. Nov 3, 2021 at 8:15 AM
    alan.a
    I will see it this Sunday. Talked to the owner already
