Butyl Tape on roof rack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kddouglas, Jul 2, 2021.
  1. Jul 2, 2021 at 7:33 AM
    kddouglas
    kddouglas [OP] Well-Known Member
    Georgetown, TX
    2020 TRD OR 4x4
    4Runner SEMA wheels. TRD Factory lift kit.
    Installing a roof rack this weekend and I see some recommend butyl tape for the install. Will butyl tape alone be enough to prevent leaks? If so, how are you using it? If there is something better, let me know. I want to be able to remove it and reinstall if needed, so don’t want something permanent. I’m afraid if I use silicone that removing it and reinstalling will be difficult.
  2. Jul 2, 2021 at 8:29 AM
    stay_tuned
    stay_tuned Limitations live only in our minds
    Bryan
    DMV
    2021 Tacoma OffRoad DCSB 6SPD BRM
    i used butyl tape when i did the Victory roof rack for my 4runner even though the install called for RTV. i had no leaks through the rain and snow. i would definitely stick with butyl and silicon washers. when i sold the rack it was very easy to remove and replace with the stock hardware.
    Traction and kddouglas[OP] like this.
  3. Jul 2, 2021 at 8:43 AM
    stay_tuned
    Bryan
    DMV
    these are the washers i used from mcmaster-carr
    kddouglas[OP] likes this.
  4. Jul 2, 2021 at 8:45 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    I used rubber washers and cheap outdoor window silicone. No leaks so far and it’s easy to remove if needed (I’d just have to reapply the silicone when installing the rack again)
    I also bought stainless bolts and washers to use instead of the ones that came with my rack....
  5. Jul 2, 2021 at 8:51 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  6. Jul 2, 2021 at 9:35 AM
    kddouglas
    Georgetown, TX
    2020 TRD OR 4x4
    Thanks everyone. I ordered the washers and butyl tape. Going to give it a shot. I’m sure the silicone is a better seal, but I want to be able to remove easily and put it back on at a later time. Not sure I’m comfortable filling the holes with silicone and then screwing in the bolts. Looks like it would push the silicone into the headliner.
  7. Jul 2, 2021 at 10:07 AM
    Traction
    Traction Well-Known Member
    WA
    2020 TRDOR
    Butyl tape is the way to go!
  8. Jul 2, 2021 at 10:08 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Sig45[QUOTED] likes this.
