Busted spider gear maybe worse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eman1234, Jan 10, 2014.
  1. Jan 10, 2014 at 4:40 PM
    Eman1234
    Eman1234 [OP] Active Member
    Erik
    Ok so I have 05 6 speed Tacoma with 33inch BFG mud terrains on it. I'm sure this has been asked before but my problem is a little different. I took off real hard pulling out of parking lot, got spinning wheel hop then pop couldn't move and has grinding noise trying taking off in any gear. 4wd won't move the truck either. I'm sure it's a spider gear but what worries me is just sitting there wether idling or truck off, with clutch engaged it's really hard to get it into any of the gears which makes me think it's a transmission problem too. Any opinions would be great thanks
  2. Jan 10, 2014 at 6:45 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Sounds like your clutch disc blew apart.
  3. Jan 10, 2014 at 8:39 PM
    Eman1234
    Erik
    It's weird too. A few people tried to help me push it to the side a bit and in neutral , p brake disengaged, it stopped after being pushed a half a foot. Like it was in gear. We couldn't move it.
  4. Jan 10, 2014 at 8:48 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
  5. Jan 10, 2014 at 8:54 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    x2 Remove the rear driveshaft and leave it in 2wd and see if it moves freely with the parking brake disengaged.
  6. Jan 10, 2014 at 9:02 PM
    2000GTacoma
    Snow Hill NC
    I meant to try to push it off the road not to drive it.
  7. Jan 10, 2014 at 9:18 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Don't know for sure but the 2nd gen 6-speed trans. & clutch assembly is pretty weak, this is a known issue w/ some TSB's attached to it..
  8. Jan 10, 2014 at 9:41 PM
    joes06tacoma
    Joe
    Central Coast, CA
    It's known that the ring and pinion on the E locker rear end is weak. Wheel hop with sudden traction sounds like the right recipe for breaking one.
    If you put it in 4wd and try to move it, does the engine load up like it's going to stall? That's what I would expect with broken R+P, the rear is locked up from the shattered gears.
    Clutch is also known to be a problem, but doubt it would break from wheel hop.
    I would jack it up, remove rear driveshaft bolts at the rear diff and see if you can rotate the pinion yoke.
    Not sure about the shifting, maybe from drivetrain being bound up from running in 4wd trying to move the truck?
  9. Jan 10, 2014 at 9:42 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    OH WHAT A FEELING.....
    WOW
  10. Jan 10, 2014 at 10:40 PM
    BradyT88
    BradyT88 Well-Known Member
    It's got to be in the tranny/clutch. When I blew up my rear end, 4wd had no problem dragging the rear end and crunching the broken gear pieces.
    When you tried to drive it, did it try to move at all or just rev up like it was in neutral?
  11. Jan 10, 2014 at 10:55 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I have to say I agree with Beavis and DoorDing on this one. Won't move in 2wd OR 4wd out of gear and it will not push or roll.
  12. Jan 11, 2014 at 6:56 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Blown ring gear, 4X4 won't help if the rear diff won't turn with out removing the drive shaft.
  13. Jan 11, 2014 at 6:58 AM
    moondeath
    Pa, Gardners
    Thanks guys!:p
  14. Jan 11, 2014 at 8:17 AM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    Not really...
    If you have the trans in neutral the input can be spinning but the output is not connected and will not spin.
    If OP blew up his clutch that should be apparent from engaging/ disengaging the clutch with the engine running. My bet is that it isn't the clutch since The truck will not roll in neutral.
    OP - put the rear axle on jack stands and remove the driveshaft, you need to narrow down whether the issue is in the trans/t case or rear axle. Anything we say without that info is just a guess.
  15. Jan 11, 2014 at 8:25 AM
    Toyoland66
    Colorado
    09 GX470
    Mostly stock on 35s
    Also, probably not the spider gears. If it were spider gears you may have a scenario where the vehicle will not move while in gear, but will roll when pushed in neutral. Busted spider gears will allow the ring and pinion to spin but not transfer the power to the axle shafts.
  16. Jan 11, 2014 at 8:42 AM
    BradyT88
    It will turn, it will just make some crunching noises as it does it. haha
    It is possible he didn't give it enough throttle to hear said crunching noises when he tried to move though.
  17. Jan 11, 2014 at 8:52 AM
    moondeath
    Pa, Gardners
    OP said that it's hard to get it into gear and that it grinds. Obviously a rear diff wouldn't cause this. It's something related to the transmission.
  18. Jan 11, 2014 at 9:23 AM
    Eman1234
    Erik
    So even in 4wd as soon as clutch lets off just Instant grinding noise no movement. I towed it already going to get it in to a shop wen I can, not that there's many good shops around here. I'm thinking it's maybe both clutch and rear end. I guess if it is I'll just beef everything up. Better clutch new gears. I just hope the transmission ain't screwed I lifted truck up and in neutral I can spin the tires it's weird. But there's also like a half foot of play then it catches something both back and forth.
  19. Jan 11, 2014 at 9:36 AM
    BradyT88
    Half a foot seems like a lot... Hard to say though.
    This is normal play in the rearend. I'm in park with the other tire on the ground.
    http://youtu.be/uoRq3xXg4dM
  20. Jan 11, 2014 at 9:57 AM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    If hard acceleration with 33s blew the trans and/or rear end I'd be very disappointed in Toyota.
