Bushwhacker Flares and trimming
Discussion in '3rd Gen. Tacomas (2016-2023)' started by glitch1213, Mar 1, 2018.
  1. Mar 1, 2018 at 8:50 PM
    glitch1213
    glitch1213 [OP] Well-Known Member
    2024 Tacoma TRD Offroad 4x4
    hey guys. My rig is in the shop getting some upgrades and one is bushwhacker flares. I’ve seen most guys talk about trimming a couple inches off, and can see what they mean when I look at pictures. The shop that has my truck said if I want to trim the flares, I need to drill holes in my stock fender to mount them. Is that the case? I’ve attached two pics of trimmed fenders and was wondering how they accomplished this? I highlited in red the area I can see they trimmed on the last pic. Please help!!
    Modesto Tacoma likes this.
  2. Mar 1, 2018 at 8:54 PM
    11Bguy
    11Bguy Well-Known Member
    Va
    2017 DCSB TRD
    Icons/ JBA UCA's
  3. Mar 1, 2018 at 10:07 PM
    TWTaco
    TWTaco Well-Known Member
    Dave
  4. Mar 1, 2018 at 10:10 PM
    TWTaco
    Dave
    MESOJDM's Quicksand Build thread
    glitch1213[OP] likes this.
  5. Mar 2, 2018 at 5:02 AM
    glitch1213
    Thank you!
  6. Mar 2, 2018 at 6:42 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Once you trim the bushwacker flares, you will loose the mounting points that are up inside the lip. So your only option for mounting would be to drill holes into the fender and put bolts though. I have a write up of what hardware to use and you will need spacers behind the bolts.
  7. Mar 2, 2018 at 6:51 AM
    Ras61
    Ras61 Well-Known Member
    Arlington VA
    '12 4wd TRD Sport Dbl Cab
    Icons front, Bilstiens 5125 rear, 35/12.5/17 MT/Rs and some trimming
    A bunch of guys have done it on second gens. On a second gen, I didn't need to drill any holes. I just used the holes that happened to line up, and then put in the Bushwacker cosmetic screws in the ones that didn't line up. Other than that, I did exactly what @mesojdm did (super sweet build by the way). The only issue was the two types of screws don't totally match, but they are close. I'm happy with the result. Sadly I don't have any close-up shots.
    glitch1213[OP] and MESO like this.
  8. Mar 2, 2018 at 6:55 AM
    glitch1213
    That would be awesome! Is it in the build thread or can you shoot that over in a dm?
  9. Mar 2, 2018 at 10:43 AM
    glitch1213
    Ras61 and TWTaco like this.
  10. Mar 2, 2018 at 10:45 AM
    MESO
    State of Jefferson
    Here is some more info
    Parts from mcmaster
    Remove all the fake bolts, mount them up from the bottom like you have and mark the holes. Remove flare and drill.
    You will need to space the flares off so they make proper contact when you tighten them up(hence the nylon spacers) listed in my above parts
    Bolted on(you might be able to get away with a slightly shorter bolt.
    And on! I actually had no choice but to mount them this was because as you can see I chopped half the bushwacker flare off(which is where it originally mounted)
  11. Mar 2, 2018 at 10:46 AM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    are those VTX wheels? what center cap is that?
    Ras61[QUOTED] likes this.
  12. Mar 2, 2018 at 10:48 AM
    glitch1213
    mikestaco17 and MESO like this.
  13. Mar 2, 2018 at 11:42 AM
    Ras61
    Arlington VA
  14. Mar 5, 2018 at 6:22 PM
    glitch1213
    Got the truck back. Looks good but didn’t trim as much as the flares as I hoped. Any in north OC up for trimming fenders?
  15. May 8, 2020 at 12:06 PM
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Dredging this thread up from the depths; thanks for the fastener list @MESO, just ordered and started cutting the rears today!
  16. Jan 22, 2022 at 5:04 PM
    bhova
    bhova Well-Known Member
    Brian
    805/SoCal
    14 TRD OR 4X4
    Camburg trail series 2” LT. ADS 2.5 coilover. All Pro expedition leaf springs w/Bilstein shocks.. TRD catback exhaust. Bushwacker fender flares. TRD Supercharger. 3 degree cam gear. LRA 33 gallon fuel tank. CBI front bumper. Fab Four rear bumper. All Pro sliders. Anytime fr/rr camera. 35” Falken RT01. Raptor lined exterior.
