Burning smell after mud in engine bay
Discussion in 'Recovery' started by LMC, May 29, 2018.
  1. May 29, 2018 at 5:29 PM
    LMC
    LMC [OP] Well-Known Member
    2015 Black Tacoma TRD Sport
    So don't want to ask a stupid question , but never noticed this before
    Went through a pretty big mud hole fast and mud went everywhere in my engine bay now I'm smelling a weird burning smell
    I'm assuming it's just the mud burning on something hot or could there be another issue happening???
  2. Jul 2, 2018 at 6:28 PM
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    You're likely correct. Check fluids to be certain, wash engine bay being careful not to flood fuses, alternator ect. Could be mud packed around exhaust as well.
  3. Jul 3, 2018 at 9:53 PM
    GoogleybearR6
    GoogleybearR6 Well-Known Member
    Andrew
    Yucaipa, CA
    2010 TRD Sport 4x4 6spd
    I've noticed that smell as well. Likely mud burning like you said. Be careful washing the engine bay I would rinse it down after a good drive so the engine is hot and let it dry for a long time. Don't get water near your ignition coils last time I washed my engine bay I wasn't careful and had multiple misfires and threw like 10 codes after I started it up
