Bumping/Jerking from front End while turning in reverse
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 4Fitch, Feb 16, 2019.
  1. Feb 16, 2019 at 11:40 PM
    4Fitch
    4Fitch [OP] Well-Known Member
    Tyler
    Manteca, Ca
    2017 TRD OffRoad 4x4 Big Box
    I just bought a 2017 Double Cab Long Bed TRD OffRoad 4x4 and everything is great, besides the sluggish accelerator. That’s is besides the point. Anyways, while in reverse and turning simultaneously, I get a slight bump/jerk from the front end. I looked like an idiot in the Costco parking lot constantly going from the parking spot to the middle of the road. Needless to say I read the brake pads by design are a bit smaller than the housing they reside in. Therefore when the truck is used to braking in the forward motion, the brake pads are accustomed in that position. While reversing the pads move backwards. As stated earlier, that is only what I have read. Does anyone have any insight and/or solutions to this problem.? Thanks.!
  2. Feb 17, 2019 at 12:04 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Are you in 4HI? Smooth pressure on the pedal should result in constant and smooth movement in 2HI.
    Marcmtb1 likes this.
  3. Feb 17, 2019 at 12:06 AM
    4Fitch
    Tyler
    Manteca, Ca
    I am in 2HI. I release the brake pedal to reverse a bit, when applying again while turning is when this occurs.
  4. Feb 17, 2019 at 6:13 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    New one to me. My first thought was 4HI.
    G.
    shakerhood, JCOOR and bulalo like this.
  5. Feb 17, 2019 at 6:27 AM
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    Pads wouldn’t do it. Make sure your caliper is tightened to the truck. Ive been in a ranger that had its brakes serviced recently...techs didn’t torque the caliper down and one bolt fell out and other one was hanging in the caliper after the assembly fell off in traffic. Took about 1500 miles to happen. That would explain a clunk in reverse.
    One or both of your front auto locking hubs may be stuck locked too. Are you somewhere ridiculously cold?
  6. Feb 17, 2019 at 6:53 AM
    Admiral_Akbar
    Admiral_Akbar Well-Known Member
    '17
    Surges when turning?
  7. Feb 17, 2019 at 7:02 AM
    Pot_Lickr
    Pot_Lickr Well-Known Member
    Ontario, Canada
    2017 Access Cab TRD Off Road
    It surges because the truck wasn't warmed up, and turning the wheel makes the RPM increase to compensate for the power steering pump load..
    When its hot it should go away..
    na8rboy likes this.
  8. Feb 17, 2019 at 7:11 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    I would like to see this article your saying about the brake pads. Never heard of this.
  9. Feb 17, 2019 at 7:18 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    I’m having the same problem but only when reversing and turning on a snow covered surface, which offers some resistance. I’m in 2hi but it ‘feels’ like it could be in 4hi.
    The first time I noticed it the temp was -30c and had been like that for a few days. If cold like that is sticking the hubs will they unstick when it warms up? There is no problem inside my heated parking garage.
  10. Feb 17, 2019 at 8:04 AM
    Garyji
    Gary
    Could be anti-skid kicking in if you are slipping in 2HI.
    G.
  11. Feb 17, 2019 at 8:58 AM
    Taquitoma
    Taquitoma Well-Known Member
    2017 OR DCSB M/T
    If you're in a snowy place, it could just be the snow compacting under the tires! It will give a similar sound and feel to binding in 4WD.
  12. Feb 17, 2019 at 9:14 AM
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    THIS IS Correct!!!
    There is a TSB out for the excessive surging when turning the steering wheel the slightest amount. I had this on my truck and the TSB took care of it. It happens in Forward as well as reverse.
    Not saying this is positively the OP's problem, but some 3rd gens show this problem. When diagnosing this problem on my truck at the dealer -the area service rep tested three trucks other than mine (new ones) and 2 of 3 had the same issue. He left (back to KC mo.) and about 7-8 months later there was a TSB that popped up. It solved my surging issues.
    Also not sure if they addressed this issue with the 19's.
    Pot_Lickr[QUOTED] likes this.
  13. Feb 17, 2019 at 9:33 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Search "Tacoma pad slap".
    Fixes can include; new pins, greasing pins, greasing the backside of the pad, replacing or adding retainer springs. Sometimes none of it works.
    RTX Taco likes this.
  14. Feb 17, 2019 at 9:50 AM
    wiljayhi
    Jim
    3G, Tuned
    That's exactly what's been happening. Is this good? Not good? Any fix for this? I've been ignoring it since it doesn't happen other that on compacted snow.
  15. Feb 17, 2019 at 10:57 AM
    4Fitch
    Tyler
    Manteca, Ca
    This sounds like the most logical diagnosis. Problem is, it does it even backing into a parking spot after driving a few miles.
  16. Feb 17, 2019 at 10:59 AM
    4Fitch
    Tyler
    Manteca, Ca
  17. Feb 17, 2019 at 11:03 AM
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    If you apply brake and gas at the same time, the gas input will be canceled.
    Let off the brake, and if your foot is still in the throttle, the truck will surge. It is common to ride the brake while reversing, this this is more common when reversing.
  18. Feb 17, 2019 at 11:06 AM
    4Fitch
    Tyler
    Manteca, Ca
    I do not have my foot on both pedals. Just releasing the brake and turning. The surge is not violent at all.! Actually very faint but I know it is there. I live in the California valley, yes it gets colder than other parts of CA but not below 25F. No snow, no mud, just pavement.
    gilligoon[QUOTED] likes this.
  19. Feb 17, 2019 at 1:00 PM
    Marcmtb1
    PHX, USA
    -22f is probably cold enough to cause the hubs to stick, but not for sure. If that’s what’s happening, yes, warming it up by driving or via weather/etc will solve the issue
  20. Feb 17, 2019 at 3:02 PM
    Taquitoma
    2017 OR DCSB M/T
    I mean it's normal given the circumstances. It's like when you drive over a speedbump your truck will bounce, it's neither good nor bad just physics ;)
