Bump Stops
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 5Sport, Jan 6, 2024.
  1. Jan 6, 2024 at 12:24 AM
    5Sport
    5Sport [OP] Well-Known Member
    I've read through the many bump stop posts but I'm looking for an inexpensive replacement for a relatively stock truck (23 Off Road). I'll run 6112/5100 later. Has anyone tried these in the front:
    Amazon.com: Energy Suspension - 8.9104G REAR BUMP STOPS : Automotive
    They work on the front of my 21 4Runner and I'm wondering if anyone has tried these on our Tacomas?
    I'm also looking for an inexpensive rear replacement that could be done with minimum modifications. For the 4Runner the Lexus 460 has a progressive bump stop that bolts right in. It was a nice upgrade. I was wondering if anyone had found a similar type swap for the Tacoma rears?
  2. Jan 6, 2024 at 1:31 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    the Durobumps are dual durometer and nice. I have them in the rear only, I haven't yet installed the fronts (waiting to get funds for full front end). The stocks are terribly hard, especially with the flimsy OE spring pack, and I would address that first.
    CS_AR, Toy_Runner, joba27n and 2 others like this.
  3. Jan 6, 2024 at 3:43 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Look at SUMOs their are highly recommended here. I run the front and back and you will notice a difference immediately.
    9pm and bkhlrTaco's like this.
  4. Jan 6, 2024 at 3:49 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    I concur and have the durobumps front and rear.... expensive af. Are a good improvement over stock, however they don't fix very soft springs. I think of them more as a suspension compliment and if I could go back in time I think I would do leaves first then bump stops
    Chew[QUOTED] likes this.
  5. Jan 6, 2024 at 11:37 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    great point and I agree! The durobumps (or any "upgraded") are no replacement for a proper leaf spring pack.
    TS4x4 and joba27n[QUOTED] like this.
  6. Jan 6, 2024 at 3:37 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Durobumps for sure! Much smoother than Wheelers bumps.
    Chew likes this.
  7. Jan 6, 2024 at 3:46 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    I have these on my tacoma. they work (different color though)
  8. Jan 6, 2024 at 8:30 PM
    Gord0
    Gord0 Well-Known Member
    I’ve had those Energy bumps on for 2 years, they work great.
    Shveet likes this.
  9. Jan 7, 2024 at 1:29 PM
    5Sport
    Do those fit on our Tacoma's at stock height? I put them on my 4Runner and they work great so far but it has an inch lift to the front.
    What did you do for the rears?
  10. Feb 4, 2024 at 3:15 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    @5Sport - Did you ever sort yous out?
    The OEM FRONT Bump stops in the front are quite harsh.
    I saw the below bump stops suggested here. What did you end-up doing?
    I am stock height and will remain so... (I have the +1 from the factory on the PRO).
    Anyone else using these? Any feedback?
    https://www.amazon.com/Energy-Suspension-9-9135R-Tall-Universal/dp/B000CGUJHQ?ie=UTF8
  11. Feb 5, 2024 at 9:42 PM
    5Sport
    I havent done anything on the Tacoma. It works well on the 4Runner. When I drop new shocks on the front I'll do the Energy Suspension stops. Still trying to figure out what I want to do on the rear but it needs something. The rear hits hard
  12. Feb 5, 2024 at 10:04 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    +1 on Durobumps. We are looking at putting together a group buy as a new dealer for Durobumps if anyone’s is interested. if we can get 5-10 sets should be able to pass on a nice deal. Send me a DM if interested.
    PTSDTherapy, musicisevil and Liv4Spd like this.
  13. Feb 5, 2024 at 11:20 PM
    Liv4Spd
    Liv4Spd Member
    I'd be interesed.
    nudavinci64[QUOTED] likes this.
  14. Feb 5, 2024 at 11:59 PM
    nudavinci64
    Robert
    Sent you a DM
  15. Feb 16, 2024 at 1:20 PM
    AGTaco22
    AGTaco22 Well-Known Member
    Warren
    RVA
    2022 Tacoma TRD OR
    What size lift are you running? I have around 1.3" up front and I was wondering if these would be a good fit. Thanks!
  16. Feb 16, 2024 at 3:32 PM
    TacoHungry
    TacoHungry Well-Known Member
    CO
    '22 AG DCSB TRD Off Road
    T@coma2020 likes this.
  17. Feb 16, 2024 at 6:44 PM
    Robskino
    Robskino Well-Known Member
    Robert
    23 MGM sport
    Even on road driving?
  18. Feb 16, 2024 at 8:07 PM
    auskip07
    Skip
    Atlanta, Ga
    No idea how high it's in my sig what I have but I never measured
  19. Feb 16, 2024 at 8:13 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    Thanks for the recommendation. I ordered a set for the front.
    I was going to go sumo to match my rear bump stops. But Perry looks pretty good at half the price.
    Though if the Perry ones aren't good I'm blaming you lol
    CS_AR and TacoHungry[QUOTED] like this.
  20. Feb 17, 2024 at 2:06 AM
    VaToy
    Parts Unknown
    I would say yes because these trucks hit the bump stops more than we think. Potholes, speedbumps and bad roads I think they helped a lot. I'm lifted on 5100s 2 in front and a 1 inch rear. The ride is great, did I need new bump stops, probably not but to answer your question. Yes it did help.
    Toy_Runner and Robskino[QUOTED] like this.
