Bump steer?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deathpunch8210, May 8, 2018.
  1. May 8, 2018 at 4:18 AM
    deathpunch8210
    deathpunch8210 [OP] Well-Known Member
    Josh
    Bakersville,NC
    08 tacoma crew cab
    3in. Rough country leveling kit. Aftermarket headlight & taillights
    Anybody running rough country 3in. lift? If so do y'all have bump steer? My 08 Tacoma cdsb has it and I can't find anything bad in my suspension. Any feedback will be appreciated. Thanks
  2. May 8, 2018 at 5:45 AM
    badger
    badger Well-Known Member
    07 SR5
    Bumpsteer isn't caused by anything "bad' in your suspension. It is a function of the steering and suspension geometry. Eliminating bumpsteer in a race car with limited suspension travel is a chore. Eliminating it in a truck with longer travel is next to impossible. Lifting the Tacoma increases the angle of the tie rods, which puts them in an operating range where the rate of change of the effective length of the rod is greater / per inch of compression. It will also momentarily cause a toe out situation, which will make the truck hunt before settling back straight. About all I can think of is to check your toe setting and put it near the top of spec. That should help a little.
    DoorDing, Yukon and mtmudrunner like this.
  3. May 8, 2018 at 9:53 AM
    deathpunch8210
    Josh
    Bakersville,NC
    08 tacoma crew cab
    Thanks maybe ill look into aftermarket a-arms
    DoorDing likes this.
  4. May 8, 2018 at 10:08 AM
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    DCSB 12 slightly lifted Tacoma
    Ripped off all four mudflaps. Scratches all down both sides 6112’s up front on 3rd notch 5100’s in back with Toytech 1” block Skids & sliders from SOS Concepts I got rid of the 1” block and put on Wheelers 1 1/2” progressive AAL. SPC UCA. Be sure your standing on the drivers side when reading the instructions! I swapped sides so many times that I can swap UCA’s in 15 minutes. I put in the 3/4” spacer to eliminate the Taco Lean, and just got my 4th alignment. Traded the OEM rims for 17” Sport rims and a bora bora 1” spacer. I got my Firestone 285/70/17 MT2’s. Pelfreybilt gas tank skid and hi-lift jack should be here Friday. Looking at bumpers, but I think they will wait for next year. So far I’m happy with my build. I’ve done it all myself, leading to a lot of cussing and frustration, but it’s all mine.
    Mine is lifted about 2 1/2”. I had handling problems once I got up to speed because of too much camber. I replaced the UCA’s and got the alignment straightened out. It was a huge difference.
    I still have some of what your talking about, but only at 5mph or less.
    I had to kick a little on the alignment though. The first guy got it within specs.
    I took it back and explained that I didn’t spend $400.00 to get it within specs.
    The second guy got it perfect.
  5. May 8, 2018 at 10:11 AM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    What specs did you get?
  6. May 8, 2018 at 10:17 AM
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    Uhhhhhh. I can tell you tomorrow. It’s back in there because I put the 3/4” taco lean spacer in. The camber is at 0,,, that much I know.
  7. May 8, 2018 at 10:19 AM
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    A lot of people don’t like the work that dealerships do, but mine now understands that good enough, isn’t.
  8. May 8, 2018 at 10:22 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    UCA's won't change any bump steer in the steering geometry. More caster *can* changed the perceived amount of bump steer, but the numbers won't change.
    The math is easy if you want to measure.
    Darkice, ready6delta, MotoEd and 2 others like this.
  9. May 8, 2018 at 10:23 AM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    Its your alignment. You dont necessary need to get new UCA's but you gotta get your alignment fixed.
    https://www.tacomaworld.com/threads/lift-alignment-specs.26692/
  10. May 8, 2018 at 10:28 AM
    Comatose
    Miguel
    San Diego, CA
  11. May 8, 2018 at 10:58 AM
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    With my 2012 the amount of positive camber was visible, and with stock UCA’s it was as good as it was gonna get. I don’t know about specs, but I do know how it drove before and how it drives now.
    Maybe we’re talking about different steering characteristics, but IMO, it sucked after I lifted it, until I put on adjustable UCA’s.
  12. May 8, 2018 at 11:10 AM
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    I don’t believe there’s any magic answers here, and I’m probably just adding to the confusion.
    Not trying to take away from anyone else’s thoughts or answers, just telling ya what worked for me.
    Next week I’ll probably notice something funny in my steering wheel and come back here and do more searching.
    It’s a sickness,,,,,
  13. May 8, 2018 at 2:19 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    When your rig is 3 inches higher than stock the tie-rod arm drops 3 inches going from the rack down to the knuckle. When the tire(s) go over a bump the distance between the inner tie-rod/rack and the knuckle is decreased. The length of the tie-rod cannot change so the only direction it can go is to push the wheel out (toe out).
    Are there mount kits available to drop the rack down and make it level with the knuckle? Is there even room to drop the rack down? I'm not sure..
  14. May 8, 2018 at 4:55 PM
    magnetic4x4
    magnetic4x4 Well-Known Member
    2013 Magnetic Gray DCSB XSP-X 4x4
    If your tie rods and control arms swing at the same angle, which they do, you won't have bump steer. You'd have bump steer if you dropped your rack down. It doesn't matter what angle it has as long as it's the same. It will ride best when everything is level, like at stock height, though.
    Darkice and b_r_o[QUOTED] like this.
  15. May 8, 2018 at 5:37 PM
    deathpunch8210
    Josh
    Bakersville,NC
    08 tacoma crew cab
    Thanks guys for the info. Got uca suggestions?
  16. May 8, 2018 at 6:15 PM
    badger
    07 SR5
    It's not the angle, it's the center of rotation. The Tacoma does not have the center of rotation of the tie rods on the same center of rotation as the control arms. The greater angle with the lift puts the rods where the rate of change of effective length is greater. Closer to horizontal, the rate of change is less.
    b_r_o likes this.
  17. May 8, 2018 at 6:29 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    SPC LR. I feel they're the best bang for your buck.
    TRDZILA likes this.
  18. May 8, 2018 at 6:40 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Hmm.. and that center of rotation gets increased when the steering wheel is turned right?
  19. May 8, 2018 at 6:57 PM
    magnetic4x4
    I had actually thought about that, but it looked close, so I just assumed they were the same.
    I did an engine swap in a Subaru a few years ago, and had to move the rack down a bit to make room for the new engine and it had a bad case of bump steer. I never got around to dropping the tie rod end at the spindle before I sold the car.
  20. May 8, 2018 at 7:02 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    I'm not a mechanic, & I hadnever done an alignment, but I completely understood the SPC's & did my own alignment to:
    Caster 4.4° 4.4°
    Camber -.1° +.1°
    Toe 0° 0°
    If I can get those numbers @ home w/no alignment rack, not a mechanic & no previous alignment experience then I'm sure an alignment tech can figure it out.
