Bullet tumble/keyhole
Discussion in 'Guns & Hunting' started by NCtaco13, Apr 8, 2018.
  1. Apr 8, 2018 at 7:58 PM
    NCtaco13
    NCtaco13 [OP] Well-Known Member
    North Carolina
    2013 Gray DCSB 4x4 V6
    Just got a new Anderson manufacturing ar-15 last week and took it out to go shoot and I had about 6 out of 40 shots impact the target sideways. I was about 25 yards away working on getting my red dot sighted in before I backed out further. I got the cheapest steel cased ammo I could find, it was monarch .223 from academy sports and I'm hoping it's the cheap ammo I got and not my rifle.
    Here's some more info if this will help:
    Anderson Manufacturing multi-cal AM-15
    16" barrel, 1:8 twist
    Monarch .223 steel case 55gr ammo
    ~20-25 yards away
    Paper target with cardboard backing
    The rifle operated perfectly fine, no ammo failures or anything
    Took it home and have it a good cleaning, inspected the barrel and it looked perfect. Haven't had a chance to shoot it again, maybe this week I will. I'm going to get some higher quality brass cased ammo to see if that fixes anything
    Thanks for any help
    Key-Rei likes this.
  2. Apr 8, 2018 at 8:01 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Try a heavier grain round
    NCtaco13[OP] and 95 taco like this.
  3. Apr 8, 2018 at 8:02 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Try a heavier grain bullet, such as a 62 or 77 Grain, and try quality ammo that's 55 grain.
    Edit: Ryan beat me too it...
    NCtaco13[OP] and Radarninja like this.
  4. Apr 8, 2018 at 9:08 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    how do your spent casings look? Does it have a muzzle break?
    Key-Rei likes this.
  5. Apr 8, 2018 at 10:08 PM
    NCtaco13
    North Carolina
    Casings looked fine for the few that I did find laying around, and I just have a regular A2 birdcage on the barrel. The rifle is brand new all original parts except for the red dot that I put on it
    I will be trying some higher grain bullets this week to see what happens
    Also, will .556 make a difference? I know it's got more pressure behind it and my rifle is able to shoot a .556 but is 55gr from a .223 basically the same as 55gr from a .556?
  6. Apr 8, 2018 at 10:12 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You’ll be fine with 5.56 or .223. There is no difference in pressure between the two. Like mentioned, try a few other brands and weights to see what happens.
  7. Apr 8, 2018 at 10:13 PM
    trdude10
    trdude10 Well-Known Member
    Nick
    17 DCSB Trd OR 6sp
    Short answer is no, they are not the same. There is more pressure and therefore more velocity from a 556. If I'm not mistaken, the military is using 62grn green tips and I always had decent results with those but I had my best results with 72-77 grn with the same barrel specs as you (although different brands)
    And brake that barrel in properly!
    wilcam47 likes this.
  8. Apr 9, 2018 at 8:39 AM
    wilcam47
    Will
    Bourbon state
    try some different ammos but shouldnt be keyholing at that short of a distance. Sometimes the bullet hits the muzzle break and that will spin the bullet also. we had a brand new savage 300 win mag and the muzzle break looked bent up or crossthreaded shot it a couple times and it was hitting the break. took it back and got an exchange.
  9. Apr 9, 2018 at 11:55 AM
    NCtaco13
    North Carolina
    Thank you everyone for your input!
    Took my rifle out today with Federal .223 55gr, Winchester .556 62gr, and Monarch .223 55gr. No tumbling at all! Shot 10 rounds of each on a separate target and ran a bore snake after I was done with each different brand. I also inspected my bird cage and everything was in order with that also, no sign of a bullet impacting it in any way
    I'll keep my eye on it though, I'm planning on getting a suppressor soon and I imagine the last thing I need is tumbling
    10 shots each target (standing about 25 yards away I wasn't worried about tight groups just getting rounds on paper), wish I grabbed a picture from the first time. My rifle definetly doesn't like the monarch though, every time I did a brass check the bolt wouldn't go all the way home and I had to bash the butt on the tailgate pulling the charging handle back every time
  10. Apr 9, 2018 at 8:55 PM
    wilcam47
    Will
    Bourbon state
    you sure its key holing and not a double stack shot?
  11. Apr 10, 2018 at 10:37 AM
    NCtaco13
    North Carolina
    99% sure it looked like someone just took a bullet and threw it at the target sideways there were several that impacted what looked to be completely sideways
    wilcam47[QUOTED] likes this.
  12. Apr 10, 2018 at 7:44 PM
    wilcam47
    Will
    Bourbon state
    ah, hopefully its just bad ammo and not your rifle, could be bad crimp on the ammo.
  13. Apr 10, 2018 at 7:57 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Like others have said that's a light round and a tight twist in a short barrel. Also steel case is just bad in general, really hard on all components, steel case typically implies low quality and therefore more likely to have issues such as what you've experienced.
    I'm certainly no expert but in my research when building my MSR I consistently came across a rule of thumb of 16"-1:7 18" 1:8 and 19"+ 1:9 twist.
    Ultimately I would go back to the range and try new ammo something reasonable quality with brass case.
    Also make sure all your bits and pieces are tight, barrel nut and muzzle device in particular.
    What muzzle device do you have? That could play factor.
    Congrats on the new toy!
    (Sorry you're having issues, if they persist perhaps seek warranty repair?)
    Pictures of the new stick?
  14. Apr 10, 2018 at 8:47 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Barrel length doesn’t really factor into twist rate at all. If you want to shoot light bullets get a 1:9 or higher twist. If you want to shoot heavies get a 1:7 twist. A 1:8 will do fine with most bullets between 55-77gr.
    The OP’s issue was probably slightly undersized bullets in the cheap ammo meaning they didn’t engage the rifling enough to be stabilized despite being a suitable weight for the barrel twist.
    A poor crimp job on the ammo won’t cause tumbling either, just inconsistent velocities and poor accuracy. The bullet would still fly true once it left the barrel.
    95 taco, Key-Rei[QUOTED] and wilcam47 like this.
  15. Apr 10, 2018 at 9:00 PM
    Key-Rei
    Key
    Florida
    That's what I was thinking with the ammo, poor machining leading to loose fit. Basically ricocheting the bullet down the barrel.
    Good to know about the twist rates vs bullet weights. Like I said, I'm not a rifle expert by any means. Just built my first MSR this year.
  16. Apr 11, 2018 at 12:41 AM
    NCtaco13
    North Carolina
    Only picture I have of it so far, been too busy working and shooting it to take more pictures lol
    Key-Rei likes this.
  17. Apr 11, 2018 at 1:05 AM
    Key-Rei
    Key
    Florida
    Nice!
    Looks like the standard A2 flash hider so shouldn't be any issues there.
    Being that it's a fully assembled weapon from factory, nothing nonstandard attached to it, I suspect it's just an ammo issue.
    My lower is actually from Anderson Manufacturing.
  18. Apr 11, 2018 at 1:37 AM
    NCtaco13
    North Carolina
    I'm pretty sure it was an ammo issue, I'll be using brass cased ammo from now on from a decent company, my rifle did not like the steel cased ammo at all. I'll be keeping an eye on it though I've never seen so many rounds tumble with just 40 shots
  19. Apr 11, 2018 at 8:47 AM
    wilcam47
    Will
    Bourbon state
    The pink chair will cause it to keyhole;)
    NCtaco13[QUOTED][OP] and 95 taco like this.
  20. May 25, 2018 at 8:27 PM
    trustyrusty436
    trustyrusty436 Well-Known Member
    2018 Tacoma, auto, 2.7, RWD Access cab, long bed, Utility model
    LCE exhaust header, AF Dymanics CAI, MagnaFlow cat back
    The freebore Dia. on a 223 is .224 on the 556 it is .226, that's 2 thousands wider at the neck of the 556, the 556 neck is also longer than the 223. This will cause the 223 chambered rifle to crimp neck of the 556 round, causing a pressure spike of about 30% or more. So I personally would not shoot the 556 in a 223 rifle, because of this. If your gun is chambered for 556, you can safely shoot either one. Also I have a DPMS Panther, that for some reason I thought was a 223, so I only have 223 ammo. Well I looked at it again, just to be sure of the chambering and it is mark CAL.MULTI and is actually a 556 NATO! So I guess one needs to look at ones rifle to make sure what you really have!
