Bull Bar Mounting Nuts... Stripped
Discussion in '1st Gen. Tacomas (1995-2004)' started by 02YotaGuy, Jul 13, 2010.
  1. Jul 13, 2010 at 9:15 AM
    02YotaGuy
    02YotaGuy [OP] Guy With A Red 80 Series
    Matthew
    Springfield, VA
    94 FZJ80
    Bumper, Winch, 315s, Sliders, OME HD lift, Custom rear swingout, roof rack, drawers, way too much to list.
    Like the title says... I took off my Bull Bar today to put a full brush Guard on and the nuts on the inside of the frame are stripped completely... I can put the bolt all the way in and it falls right out... anyone else have this happen... It looks like my only option at this point is an ARB style front bumper.
  2. Jul 13, 2010 at 9:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can tap the holes, and use a larger bolt.
  3. Jul 13, 2010 at 9:20 AM
    02YotaGuy
    Matthew
    Springfield, VA
    94 FZJ80
    That's a good idea, but sounds labor intensive and difficult... and if I find a solution then I don't have an excuse to buy an ARB. It's just kinda irritating, I spent a long time sanding and priming and painting the Brush Guard... I guess I'll just sell the Brush Guard and Bull Bar.
  4. Jul 13, 2010 at 9:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its not hard at all. Get a Tap and Die set, and use the correct size needed. A few twists, and your good to go!
  5. Jul 13, 2010 at 9:35 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    sounds like a good reason to ditch the brush gaurd to me:D
  6. Jul 13, 2010 at 9:55 AM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    Tap and die! It's easy but I can't argue with "needing" new toys. :)
  7. Jul 13, 2010 at 10:05 AM
    02YotaGuy
    Matthew
    Springfield, VA
    94 FZJ80
    I'll look into it, But I'm moving to the other side of the world... And I'm considering selling the truck and buying a newer Taco... My wife already gave me the OK...
  8. Jul 13, 2010 at 10:10 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Really easy. Just go down to your local hardware store, find the size of bolt you plan on replacing with and pick up a single tap for that same bolt size and thread.
    You can get a whole tap and die set if you really want, but you can also just buy the single piece you need. A kit can be from $30 to hundreds, but you can also just get a single tap for under $5. There's a special handle you can use, but before I got my set, I'd just use a wrench.
    Another possible option if you can get to the open end of the bolt is to just toss on a lock washer and nut on the bolt. No real reason to use a threaded bracket if you have access to the end of the bolt.
