Built For the Internet...By the Internet Mall Crawler (AR15xAR10's Build Thread)
Discussion in '2nd Gen. Builds (2005-2015)' started by AR15xAR10, Feb 24, 2017.
  1. Mar 24, 2021 at 5:18 PM
    #4241
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Don’t get +1 in the front. I did and it’s wildly unnecessary and rubs on the frame from the extra slack. Just stick with stock length and get SS. +4 is solid in the rear.
    AR15xAR10[QUOTED][OP] likes this.
  2. Mar 24, 2021 at 5:39 PM
    #4242
    AR15xAR10
    AR15xAR10 [OP] AR10 is 5 ARs better
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    You dont think you’ll need that +1” with your new setup?
  3. Mar 24, 2021 at 5:48 PM
    #4243
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It comes with new brake lines. All LT kits do as far as I know.
  4. Mar 24, 2021 at 6:28 PM
    #4244
    AR15xAR10
    Hmm...did not consider this.
    Thank you for the help Randy :)
    EatSleepTacos[QUOTED] likes this.
  5. May 7, 2021 at 9:56 AM
    #4245
    AR15xAR10
    Just did a service at 103k
    Throttle body cleaning
    Air filter cleaning
    MAF cleaning
    New spark plugs
    fatfurious2 likes this.
  6. Mar 1, 2022 at 9:36 PM
    #4246
    AR15xAR10
    So I am amassing a list of shit I need, and shit I need to do.
    presently, i believe my driver’s side rear wheel bearing has gone out.
    so, this year I would like to do the following
    Inspect and or replace rear wheel bearings, o rings and axle seals
    Replace radiator with an aluminum AFE Power radiator
    Replace front calipers with rebuild black painted napa calipers OR upgrade to 5th gen 4runner calipers and rotors
    Crown performance stainless braided brake lines
    New rear shocks
    New front coilovers
    Underbody lighting
    Bed lighting
    Aftermarket wiring management (fuse box etc.)
    Window tint
    Different front seats
    TicoTRD likes this.
  7. Mar 7, 2022 at 6:44 PM
    #4247
    AR15xAR10
  8. Mar 7, 2022 at 6:45 PM
    #4248
    AR15xAR10
  9. Mar 8, 2022 at 11:13 AM
    #4249
    AR15xAR10
    Bearings ordered, tool ordered
    Ended up getting the bearings from Rockauto:
    TIMKEN 512294 - Left
    TIMKEN 512295 - Right
    and I got the tool from Amazon with prime shipping
    TicoTRD likes this.
  10. Apr 16, 2022 at 6:00 PM
    #4250
    AR15xAR10
    I'm still waiting for my rebuilt third member from ECGS.
    While doing so, I'm shopping for lift parts finally.
    I don't want to spend a ton of money on this project, my goal is just to refresh the suspension, and change the drive line angles so I can potentially have a better chance of not destroying any more pinion bearings in the future; if I gain 2-3' of ground clearance in the process, its a win. I just don't want the truck to look too dumpy on 32s. I do not plan on ever going any bigger than a 32. or a skinny 33. I burn through tires way too fast anymore to be running big diggers all the time :laugh:
    When the truck is no longer my primary driver, i'll be more inclinded to add armor and coilovers/shocks with RESIs.
    I'm looking at doing either toytec aluma series, bilstein 6112/5160s, OME, or something of the like. I would also like to get some more flex out of the rear. The front will have to stay as is because I want to keep the swaybar for now and I dont plan on being able to swing the $2600+ aluminum front bumper that I want for a long while.
    I will definitely need some help from the homies on what all to end up going with :pray: @Taco Guy11 @fatfurious2 @EatSleepTacos to name a few
    These things are a definite:
    Doing Stoptech stock length stainless braided brake lines in the front.
    probably ordering the 24" extended braided brake lines for the rear from headstrong offroad.
    toytec ubolt flip kit and i'll modify it to allow me to use my sumosprings with it
    I already have high clearance UCAs, new LCAs, new sway bar end links, and sway bar bushings so i'm good on that.
  11. Apr 16, 2022 at 7:07 PM
    #4251
    AR15xAR10
  12. Apr 16, 2022 at 7:14 PM
    #4252
    AR15xAR10
    I’m unsure if i should just do dakars or a different kind of leaf pack. I know i dont want to mess with AALs AT ALL. I’d rather swap in a full leaf pack. But i’m worried the medium duty dakars will be too much lift for what I want to do. They claim 2.75” over stock, which would probably be too much for what I want to do and the tire sizes i plan to stick around. I do have some constant weight on the rear end, but its probably less than 300lbs
  13. Apr 16, 2022 at 7:16 PM
    #4253
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    Just happened to come across this post. I see you said you want to keep the sway bar. If you go with 6112s and 5160s I highly recommend ditching the sway bar. I ran the rebranded 6112s (2015 TRD pro lift) and taking the sway bar off was amazing. Ride quality was so much better as it allowed the front to actually be independent but the 6112s were stiff enough that it felt completely safe even during spirited driving.
  14. Apr 16, 2022 at 7:21 PM
    #4254
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Checkout the icon rxt. I like them wayyyyy better than my dakars and they’re on the lower end of the lift spectrum. I have mine on option 2 and am at 1.75” lift.
    Edit: option 1 would be perfect for you and you can find the leafs on Amazon of all places because they’re out of stock a lot of other places.
  15. Apr 16, 2022 at 8:59 PM
    #4255
    AR15xAR10
    Do they really come with the parts to change them to all three settings? For $1000 they seem like a great bang for the buck.
    Did they come with poly bushings or should i worry about doing that later?
  16. Apr 16, 2022 at 9:00 PM
    #4256
    AR15xAR10
    I completely understand why you would say that, but i’m far too spirited for the no sway bar life
  17. Apr 17, 2022 at 3:58 AM
    #4257
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    They come with rubber bushings so zero maintenance on them and they come when new u bolts too. And yeah they come with everything to choose between the three options.
  18. Apr 17, 2022 at 7:02 AM
    #4258
    AR15xAR10
    Ayyyyye. Sounds like the way to go then.
    I doubt i’ll need the front diff drop, because I dont think i’ll even do the full 3” lift in the front. But, i’ll probably do the carrier bearing drop just to be safe. You think axle shims might also be a good idea?
  19. Apr 17, 2022 at 7:06 AM
    #4259
    AR15xAR10
  20. Apr 17, 2022 at 7:09 AM
    #4260
    AR15xAR10
    Honestly my driveline angles are beautiful when the truck is rolling down the road or sitting static. My guess is, that when i’m towing, flexing offroad, or when I stomp on the pedal, i’m getting axle wrap thats causing the excessive wear on the pinion bearings. So my goal is to completely change the whole setup, in hopes to not smoke another pinion bearing in 50-60k miles or less :oops:
