Building a Hoist for RTT??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by robbielight, Apr 3, 2017.
  1. Apr 3, 2017 at 10:00 AM
    robbielight
    robbielight [OP] paintball is life.
    robbie
    Norco, CA
    2016 TRD OR 4x4 DC SB M/T
    Bilsteins 5100s Falken Wildpeaks 33's
    Hi, So i cant install a hoist in my garage for a RTT cause my truck will not fit in my garage. So im left with either making a homemade gantry to hoist my RTT off my truck or i am thinking about attaching a crane arm to the front of my house and using that to hoist my RTT off and on.
    https://m.youtube.com/watch?v=2fYIeKilU50
    Here's a vid of someone using a crane arm attached to their house, but i have no idea how to get started on how i can install that crane arm to my house. Any ideas??
    GPsevinSixx and THROTTLE231 like this.
  2. Apr 3, 2017 at 10:06 AM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    Can't a friend help you out lifting it off and on? Am I missing something here?
    JimboAnz and uhplifted like this.
  3. Apr 3, 2017 at 10:09 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    I slide mine off the back of my truck, down the tailgate onto a movers dolly. strap it on, and it stores upright in the geee-raj :thumbsup: reverse procedure when you need to put it on
    Augie and oldtoyotaguy like this.
  4. Apr 3, 2017 at 10:10 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    I'm thinking bracket for a horizontal beam to attach the block and tackle to. Eye bolt higher up to attach a cable to so it creates a 45* angle to actually support the weight of the load.
    robbielight[OP] likes this.
  5. Apr 3, 2017 at 10:12 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    just get one of these :notsure:
  6. Apr 3, 2017 at 10:12 AM
    robbielight
    robbie
    Norco, CA
    If i had the luxury of having a friend help every time i needed help with taking it on and off, i probably wouldn't ask to make this stuff...
    My truck is also my daily driver, and my gf can barely help with lifting this thing on and off, i would like to be able to put it on and off at moments notice without having to wait for back up.
    socataco, rlx02 and THROTTLE231 like this.
  7. Apr 3, 2017 at 10:15 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Where on your truck does it mount? Roof rack, bed rack full height, half height, etc?
  8. Apr 3, 2017 at 10:17 AM
    robbielight
    robbie
    Norco, CA
    Mounts on top of my roof rack on top the cab.
    Sorry prob should have mentioned that.
  9. Apr 3, 2017 at 10:18 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    :facepalm:
  10. Apr 3, 2017 at 10:19 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Is there anything in your bed like a rack or anything? What I'm getting at is maybe you can have a couple long boards that clamp to your roof rack somehow, and you essentially just slide the RTT up the ramp, or possibly use a long ratchet strap at the front end of the rack to pull it up said ramp. Just a possible cheaper alternative.
  11. Apr 3, 2017 at 10:20 AM
    robbielight
    robbie
    Norco, CA
    Yea yea i know, should mount on my bed, but i have a retrax tonneau that i use to store expensive gear during the week, so im left with having my RTT on top the cab.
    JimboAnz[QUOTED] likes this.
  12. Apr 3, 2017 at 10:20 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    pretty slick video. Ive seen barns with that type of setup. ibeam with a rolling trolly with a chain fall on it.
  13. Apr 3, 2017 at 10:22 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Or maybe some long boards that attach to the rack from the side of the truck so there's nothing in the way?
  14. Apr 3, 2017 at 10:23 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    we use aluminum I beams in 8' sections, to hang suspended scaffolding off buildings. they have a clamping system that allows up to 24' of beam to be made, and can get it to the roof in 8' sections. check with sunbelt scaffolding (if out there) or any scaffolding supplier
  15. Apr 3, 2017 at 10:34 AM
    TastyTaco
    TastyTaco Well-Known Member
    Nick
    Vancouver, WA
    2003 Taco 3.4 DC TRD
    3" Lift, BFG K02 285/70/17, Pro Comp 45 Series 17x9 -6, ACME D2S Retrofit
    You could build something like this, or buy this one and modify to your needs if you are handy with a welder. It has a optional stand. I am not a fan of drilling into my siding, it was bad enough when I installed my nest outdoor cam lol
    Or better yet just concrete in a 4x4 next to your driveway/fence and mount the crane off that
    http://www.cabelas.com/product/VIKI...0lFSmgaAt4Y8P8HAQ&gclsrc=aw.ds#tabsCollection
  16. Apr 3, 2017 at 10:42 AM
    robbielight
    robbie
    Norco, CA
    It doesnt look like that jack would reach the cab haha, but concreting a 4x4 might not be a bad idea. thanks for that.
  17. Apr 3, 2017 at 10:58 AM
    DNasty777
    DNasty777 HEATMISER
    Dave
    Rochester, NY
    '16MGMDCLBTRDS4X4
    Check out the Wrangler forums. They use powered winchs and pullies to lift their hard tops on and off. There's aftermarket hoist systems and I don't see why they wouldn't work for you
  18. Apr 3, 2017 at 1:09 PM
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Get your side chick to help the two of you.
    EatSleepTacos likes this.
  19. Apr 3, 2017 at 1:16 PM
    BountyOR_VF2
    BountyOR_VF2 "If in doubt, flat out!"
    NorCal Bay Area
    2017 WHITE TRD TCSB OR
    The almighty Biggie~!
  20. Apr 3, 2017 at 1:16 PM
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    This might be a good place to start. Buold a frame out of unistrut and attach to ceiling of your garage.
    Edit: Just read op. Build a frame attached to your driveway.
