bug deflector = added wind noise?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ywen, Jan 14, 2010.
  1. Jan 14, 2010 at 8:50 PM
    ywen
    ywen [OP] Well-Known Member
    I want to get a bug deflector for my 03 Tacoma.. I was thinking Weathertech.. Anything else better?
    My main concern is whether adding a deflector will create additional wind noise?
  2. Jan 15, 2010 at 4:29 AM
    exminnesotaboy
    exminnesotaboy Well-Known Member
    Maple Grove, MN
    01 Tacoma 4x4 V6 SR5 TRD Xtra Cab
    Bilstein 5100's / OME 881's / Wheelers 5 leaf pack / Level8 MK6/ 265/75-16 Bridgestone Dueler tires
    on my 2001, I picked up a Lund Interceptor (part number 18093, I believe). No wind noise at all. This was a bolt-on, no drill with no tape and it has not worn the paint at all. I am really happy with the fit.
    Hamer95USA likes this.
  3. Jan 15, 2010 at 4:55 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    It will depend on the deflector and the installation. I've never noticed wind noise from the newer 'aerodynamic' deflectors unless the air is whistling around their mounting points or the mounting has caused a gap in the hood-to-body juncture.
    Back in the Olde Days the hood deflectors stood straight up / vertical. Now, *those* deflectors could generate some wind noise!
  4. Jan 15, 2010 at 6:19 AM
    asphaltpilot
    asphaltpilot CAPS CAPS CAPS!
    South Florida
    PreRunner SR5
    I put an AVS Bugflector II on mine the other day and haven't noticed any wind noise. The install was literally 5 minutes. Good stuff.
  5. Jan 15, 2010 at 7:15 AM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    AVS II here no noise
  6. Jan 15, 2010 at 7:18 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I've got whatever one came with my truck when I bought it, looks like the one pictured above. Just as an experiment when I first got it I took it off for a week, never noticed any difference in noise and liked the look so put it back on.
  7. Jan 15, 2010 at 8:01 AM
    Fastracer
    Fastracer Member
    Milwaukee,Wisconsin
    2002 Tacoma 4X4 SR5 TRD
    Just install a EGR deflector no noise,no drilling and no tape quick installation,
    Love the looks. I also install ventvisors or wind deflector it help with the wind noise
    water,snow and heat in summer.
  8. Jan 15, 2010 at 9:12 AM
    ywen
    Any of these deflectors can be picked up at local auto stores?
    Does the AVS use tape or does it clip in to the mounting holes under the hood?
  9. Jan 15, 2010 at 9:41 AM
    asphaltpilot
    South Florida
    PreRunner SR5
    Auto stores do carry some defectors but it's going to be hit and miss if they carry one for your particular truck.
    The deflector I installed used four mounting hole clips.
