Bucket swap for bench!! possible?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ferraperez, May 23, 2014.
  1. May 23, 2014 at 4:17 PM
    ferraperez
    ferraperez [OP] Member
    East Palo Alto, CA
    Looking for a Regular Cab 4x4 tacoma
    searching for a good tacoma
    Is it possible to swap the bucket seats from a 2003 regular cab 4x4 tacoma to a bench seat with little work? by little work i mean just unbolting the buckets and installing the bench with out having to do any modifications to airbags or anything else?
    will they fit in perfectly?
  2. May 24, 2014 at 11:51 AM
    TimPall13
    TimPall13 Well-Known Member
    Tim
    Sandy Oregon
    3link SAS 02 SR5 Limited V6
    Lift: TrailGear 3link SAS with Fox 2.0 Coil overs in front. Custom Alcan Leafs with relocated Fox 2.0 shocks in rear. Sitting at 6in of lift. Armor: Relentless Fab Front bumper with home made hoops and Warn VR Evo 10s winch. Relentless Fab Rear bumper with swingout gate. Gears/Grip: 4.88 gears with ARB Air lockers front and rear. 35x12.5 Mickey Thimpson Baja Boss MTs on 17in Trail Ready Beadlock wheels. Lighting: 6000k 55w HID head lights in Retrofit Prejectors, KC Slim Light LEDs behind a Grillcraft grill and on CBI windshield mounts, And LED rock Lights. Performance: 6" deckplate mod, URD Crank Pulley, K&N air filter, ISR mod, and a AirRaid throttle body spacer, magnaflow muffler. Audio: Alpine speakers and sub running on a Alpine 5ch amp. All ran with Stinger wire kit, and a Alpine touch screen reciever. Extras: 15% Window Tint, Spray in bed liner, LineX coated factoey fender flares, Custom Roof rack/Track system, SoftTopper Canopy, Viair Dual 444c Onboard air with dual 2.5Gal tanks.
    Should be easy. i have a 02 with the flip up center consol that allows 3 people to sit up front. should just have to pull the seats and center consol and put in the new.
    Tim
  3. May 24, 2014 at 7:15 PM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    No problem - just unbolt the old one and bolt the new one in. It should line up just fine. I had an '00 that I swapped the buckets for a bench, then later swapped that for a 60/40 bench. The only problem was making the seatbelts work - the receiver for the buckets was part of the seat, and I had to buy the one that mounted to the floor for the bench seat. Junkyards will have them - let me know if you need a recommendation, there's an awesome Tacoma junkyard near me that ships.
    beikokupilot and TicTAComy like this.
  4. Jun 28, 2014 at 5:44 AM
    LarryInSC
    LarryInSC Member
    Larry
    South Carolina
    02 Regular Cab, base model
    Faded paint, missing carpet, torn seat fabric
    I'm looking at doing just the opposite: swapping the bench seat for buckets on my (new to me) '02 regular cab. The drivers side of the bench seat is pretty saggy and the cloth is torn on the seat-back (at the usual place).
    My question: will bucket seats from an extended or double cab fit in a regular cab? Is it easy to pull the hardware for the bucket seats? Will I need anything besides the sliding rails?
    Thanks for your help.
    --Larry in SC
  5. Jun 28, 2014 at 6:11 AM
    LarryInSC
    LarryInSC Member
    Larry
    South Carolina
    Another question: will 2nd generation Taco seats fit the 1st generation?
  6. Jun 28, 2014 at 12:03 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    bench on a reg cab is different (from what I've read)
    buckets and 60/40 mount using some of the same holes but need to use the tunnel for mounting buckets (xcab has these already there whereas reg cab did not)
    this is one of the first reg cab with factory buckets I've seen, and usually they go bench to buckets not reverse :p
    beikokupilot likes this.
  7. Jun 29, 2014 at 8:00 AM
    PhdNPrerunners
    PhdNPrerunners Well-Known Member
    Justin
    The Woodlands, TX
    1999 4Runner SR5 4WD
    Just curious why would you want to get rid of the buckets for a bench seat? That is the first single cab I have seen that has power options.
  8. Jul 1, 2014 at 10:06 AM
    LarryInSC
    LarryInSC Member
    Larry
    South Carolina
    Thanks for that info guys.
    Previous owner pulled the carpet out of the truck, so it should be pretty easy to see how everything mounts. There are a bunch of unused holes under the bench seat where other stuff mounts.
    My bench seat is not comfortable. It's worn out--fabric and foam.
  9. Jul 1, 2014 at 11:06 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    you can always take it to a shop and get it rebuilt.
  10. Jul 1, 2014 at 3:19 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    damn i would trade my bench seats w/ cash for buckets in a heart beat
  11. Jul 2, 2014 at 7:30 AM
    mustangstephen
    mustangstephen raise hell, drink beer
    Stephen
    by da creek
    02 Tacoma TRD
    Homebrew bumpers and sliders, 5100s & Eibachs up front and mutt leaf pack out back, 285s & Wheelers type B, sway bar deleted. Wife's ride: 01 4Runner 4wd sport. Stock with exception of TRD taco coils, and shift kit.
    Anyone have (pics) of duals with a bench seat? I'd almost like a bench but I'm sure I'll get duals eventually and if the seat gets in the way of fairly easy shifter installation I'll forget it.
  12. Jul 2, 2014 at 8:48 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    A saws all down the middle of the bench would fix yalls problem
  13. Jul 3, 2014 at 8:23 AM
    sshirley
    sshirley Well-Known Member
    Sam
    Austin
    2000 Tacoma SR5 with 400k miles
    Stuff
    Freaking Simple!!
    I put SR5 4runner seats in mine, 3 feet line up perfectly one we cut off and bolted onto the new seat. once you line it up you will see exactly what I did.
    paid $32 a piece for mine from wrench a part.
    beikokupilot and Hamer95USA like this.
  14. Jul 23, 2014 at 8:36 AM
    Saggio
    Saggio Active Member
    I want bucket seats! Anyone selling theirs?
  15. Jul 23, 2014 at 12:57 PM
    TacomaTRD4x402
    TacomaTRD4x402 Well-Known Member
    So Cal
    '02 Tacoma TRD 4WD 3.4 5spd S/C Long Travel
    Send me a picture of your current setup. You have the 60/40?
  16. Jul 23, 2014 at 2:42 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Yea i have the 60/40. not sure id be willing to put cash into the deal anymore though because I'm thinking of going with some sparco seats in the end. My driver seat has one tear on it. Other than that they are in OK condition..
  17. Jul 23, 2014 at 10:10 PM
    TacomaTRD4x402
    So Cal
    I just finished swapping out my driver side seat with a Corbeau Baja RS so now I have a spare driver side bucket. I'd like to try a driver seat from 60/40
  18. Jul 23, 2014 at 10:39 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    alright ill get you pics. its that blueish/grey color.
  19. Jul 24, 2014 at 5:32 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OP has a reg cab (usually solid bench), it's different for an xcab which has all the mounting points for buckets and 60/40, so yes yours was easy. :)
  20. Jul 29, 2014 at 10:42 AM
    Saggio
    I would LOVE to swap my bench for buckets!!
