BSM light never comes on and doesn't work when turned on
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sureshot, Mar 31, 2023.
  1. Mar 31, 2023 at 12:35 PM
    sureshot
    sureshot [OP] Well-Known Member
    Middle TN
    2016 TRD Sport
    Nothing yet...
    I'm test driving a 2016 tacoma sport today and the blind spot monitoring system is not working... I had this on my last tacoma and it worked fine and I know what to expect.
    I push the button to turn it on and the light doesn't even turn on... and of course the system doesn't show the warnings when a vehicle is in the blind spot.
    Is this a fuse or is this potentially both sensors are bad?
  2. Mar 31, 2023 at 12:40 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Possibly either one. But my bet is on bad sensors. If not kept clean, or area that salt is used on roads. They are shot.
    Chew likes this.
  3. Mar 31, 2023 at 1:03 PM
    caribe makaira
    Caribbean, Puerto Rico
    Since the system doesn't have a dedicated fuse and you have not mentioned any other signs/failures of other systems, I'd say sensors. The sensors themselves are the ones that send the juice to the indicators.
    Chew likes this.
  4. Mar 31, 2023 at 1:13 PM
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    When you first turn the key to the "On" position do the indicators light up like all the cluster lights do?
    I'd assume if the sensors themselves were bad there would be a message on the center cluster display as well.
    Sounds to me like the system has no power, and since the system isn't being powered then that message won't pop up because computer isn't expecting the system to be on and functioning. But that all depends on your answer to the other questions.
  5. Mar 31, 2023 at 1:18 PM
    caribe makaira
    The indicators are inside the mirrors. I'm not aware there is any Blind Spot Monitor System anywhere on the dash at anytime.
  6. Mar 31, 2023 at 1:19 PM
    Murd3rd
    That's what I'm talking about. I have the same system on my 19OR. Do the indicators turn on and do what some call a "bulb check" when the truck is first turned on... Similar to what the cluster does...but not in the cluster, the lights in the mirrors.
  7. Mar 31, 2023 at 3:07 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    it's probably an expensive repair, so get them to fix or deduct.
  8. Apr 4, 2023 at 2:34 PM
    sureshot
    Middle TN
    2016 TRD Sport
    Nothing yet...
    Thanks for the info... I bought the truck and it has 191k on it (2016)... it looks like it came from Michigan, so my guess is salt killed them.
