BSM fuse
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoRob08, Jan 2, 2020.
  1. Jan 2, 2020 at 12:49 PM
    TacoRob08
    TacoRob08 [OP] Well-Known Member
    Rob
    Fredericton, NB, Canada
    17 Sport DCLB
    gibson exhaust, OVTuned base 91, AFE intake
    My BSM has stopped working, not sure when till yesterday when I almost side swiped someone. The indicator light does not light up when I turn it on. Be damned if I can find a fuse diagram in the manual.
    Anyone know which fuse to check or has anyone had this issue?
  2. Jan 2, 2020 at 1:37 PM
    caribe makaira
    Caribbean, Puerto Rico
    The BSMS is tied into the 7.5A ECU-No. 2 fuse and the 10A IG1 No. 2, these fuses handle other systems also...
    facefirst and MGtaco2.7 like this.
  3. Jan 3, 2020 at 3:16 AM
    TacoRob08
    Rob
    17 Sport DCLB
    Thanks for the info, everything else seems to be working ok as far as I know. Have to check this weekend I guess
  4. Jan 13, 2020 at 3:33 AM
    HunterBella
    HunterBella Well-Known Member
    greg
    Langley
    2017 Tacoma Limited
    Mine decided to also die this week.
    It flashes blind spot unavailable intermittently then eventually doesn't work.
    Ive cleaned both back sensors. Cleaned the plugs with no luck.
    Ive been looking around for a wire diagram to look at more things but so far no luck....
  5. Jan 13, 2020 at 5:55 AM
    TacoRob08
    Rob
    17 Sport DCLB
    Turns out I have a faulty switch. Power goes to switch but not coming back out of it.
  6. Jan 13, 2020 at 6:42 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    It the mean time you can use your neck to help you check your blind spots.
    waltuo and BloodyTesla like this.
  7. Jan 24, 2020 at 6:47 AM
    TacoRob08
    Rob
    17 Sport DCLB
    Well $350 in the hole for a mis-diagnosis from the Toyota dealer. Told me it was the switch so I replaced it and still not working.
    I have a theory, I'm wondering if the blind spot system stopped working when I put my winter rims on. They don't have sensors in the wheels so the TPMS light is on. Can anyone that has winter rims with no sensors confirm that the blind spot system still works?
  8. Jan 24, 2020 at 8:27 AM
    JoeCOVA
    Joe
    Colorado Springs
    Completely different systems, TPMS sensors have no impact on the BSM
    over60 and shakerhood like this.
  9. Jan 24, 2020 at 9:45 AM
    TacoRob08
    Rob
    17 Sport DCLB
    So you know this for a fact? Dealer couldn't answer he honestly.
  10. Jan 24, 2020 at 10:27 AM
    JoeCOVA
    Joe
    Colorado Springs
    I dont run TPMS in the summer. When I had BSM it was unaffected.
    shakerhood likes this.
  11. Jan 24, 2020 at 10:35 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Ok, this is a bit concerning to me. I don’t want to make assumptions however, the context tells me that there is reliance on this system.
    As someone who commutes on a motorcycle I have noticed some systems are more sensitive to bikes than others. It scares me if the signal, mirror, over shoulder look is being replaced by a little amber light to tell a driver if there is something next to the vehicle.
    Hopefully it was a wake up call to not rely on these systems.
  12. Jan 24, 2020 at 11:09 AM
    TacoRob08
    Rob
    17 Sport DCLB
    I don't rely on it. I just want it to work if my truck is equipped with it.
  13. Jan 24, 2020 at 5:32 PM
    caribe makaira
    There are 3 versions of the TPWS.
    Between the BSMS and the TPWS they only share this fuse:
    Both system "talk" to the CAN-BUS.
  14. Jan 24, 2020 at 5:35 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Winter tire swap every year with no sensors. Definitely no effect on the BSM system. Not even related.
  15. Jan 24, 2020 at 5:38 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    I have BSM on on my truck but I never use it. Shoulder checked for the last 28 years of driving, not going to change because of BSM. So honk and wave as you pass.
  16. Jan 25, 2020 at 6:22 PM
    A Salt Weapon
    A Salt Weapon Well-Known Member
    T
    Southeast Alaska
    2017 Blue DCSB TRD OR
    Tagging because mine quit working about the same time too.
  17. Jan 31, 2020 at 7:43 AM
    TacoRob08
    Rob
    17 Sport DCLB
    Well just heard back from the Dealer after 6hrs of diag time. (which they are covering for mis diag last time in) Its the left rear blind spot that is faulty. $850 part. Guess I'm going without.
  18. Jan 31, 2020 at 8:36 AM
    caribe makaira
    Bummer. Head turning vs wallet drain...
  19. Jan 31, 2020 at 8:55 AM
    Camel89
    Camel89 Well-Known Member
    Houston, TX
    2016 TRD OR 4x4
    The good news is that you now have an excuse to upgrade the rear bumper. Still won't have BSM, but at least you wont be losing any additional functions.
  20. Jan 31, 2020 at 3:48 PM
    JoeCOVA
    Joe
    Colorado Springs
    I’ll sell you mine for $400
