Brush guard and Winch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nerwinski, Jan 6, 2025.
  1. Jan 6, 2025 at 10:06 PM
    Nerwinski
    Nerwinski [OP] OliveDrab_Jake
    Camino, CA.
    '09 TRD Off Road 6spd Access Cab
    Bilstein 5100s Bilstein mid-duty coil springs Volant intake
    I really want a brush guard and a winch but it seems as though I have to pick one or the other.
    Warn used to make their Trans4mer Brush guard w/ winch plate for the second gen tacoma but it doesn't seem like they do anymore though I've yet to reach out.
    Im curious if it would be possible to run a brush guard and an integrated or semi-integrated front bumper winch plate at the same time; if they use the same mounting locations and/or of they'd both fit.
    Now I know someone is gunna hop on here and tell me to get a winch bumper. I understand your points and they are valid but don't waste your time.
    Anyways if anyone knows of an existing products I might check out, or if they have info about running both, please let me know. Any info would be much appreciated.
  2. Jan 6, 2025 at 11:00 PM
    illjimae
    illjimae Well-Known Member
    gl, it took me awhile to find a trans4mer and 100 percent worth it if you can find one. Had to drive up to Washington from Cali.
  3. Jan 9, 2025 at 3:54 PM
    AnotherDude
    AnotherDude Well-Known Member
    I have been considering this in combination with a brush guard. I have not looked into compatibility as it's possible they use the same mounting points, but I think there are workarounds. Most likely involving cuts through the integrated skid plate.
    Nerwinski[OP] likes this.
  4. Jan 9, 2025 at 4:01 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    That's what I have but all I have left is the Winch Plate, I cut the rest of it off since the upper area started to shake so bad as it got older. TACOMA #2 January 2024.jpg
  5. Jan 9, 2025 at 6:36 PM
    TacoTuesday1
    FL
    Not sure why you would have a brush guard.
    a steel bumper will give protection, looks, recovery, guard brush, and mount a winch.
    Weak “brush guard” damage multipliers are stupid.
    That is why this is the case.
    the market goes lemme get some good shit. Suppliers go let me make some good shit and sell it to fulfill the demand. Not dumb shit.
    if you’ve had your truck long enough someone has crashed into it. Making it free. And protecting the investment. That a brush guard does not do.
    GilbertOz likes this.
  6. Jan 9, 2025 at 8:20 PM
    Nerwinski
    Camino, CA.
  7. Jan 11, 2025 at 12:34 PM
    Ajclouse
    Ajclouse Member
    VA Blue Ridge Mtns
    3rd Gen TRD Offroad Dbl Cab 5' Bed all factory
    Slotted rotors and Truck/SUV pads so I don't have to say none. Running boards may not be factory (previous owner) but everything else is.
    Until I saw everyone shitting on them I was interested in a brush guard. Why so bad? I want one as my property (where I do majority of offroading) is infested with Silver Berries/Autumn Olives. Dunno if you have those in your part of NC (I grew up near Greensboro and didn't see my first until VA) but they grow fast encroaching on paths and the thorns can gouge the metal. It's just cosmetic (initially, then rust, then holes) but I figured a brush guard would suffice. Something better than cheap tube metal with bird shit for seams, but I'm here for suggestions.
    Also, it's easier for me to count days I haven't seen deer out and about. Just replace front bumper with a steel one? I want a winch eventually too...
  8. Jan 11, 2025 at 8:22 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    If you are literally just hitting light brush and nothing else they're fine.
    The problem comes when you hit anything heavier than light brush, then they act as levers that will twank your front frame mounting points and still allow plenty of additional front-end damage besides. Crushed headlights, possibly crushed front grill/radiator, etc.
    A full coverage steel bumper, preferably with full tubes above, that has brackets that transfer at least half the load directly to the vehicle frame (not just the crash-beam support points or whatever) will do a lot better in any real collision, including deer & possibly even moose.
  9. Jan 12, 2025 at 3:53 AM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    Cover the truck in paint protection film and get an ARB bumper. It has some sort of hoops for brush
  10. Jan 12, 2025 at 9:22 AM
    TacoTuesday1
    FL
    1. a brush guard is not going to protect the truck
    2. a brush guard costs money, to make the truck worse
    3. a brush guard is a damage multiplier based on the pivot points it mounts to
    4. they look stupid
    a steel bumper with full hoops is going to give you the following
    1. good looks
    2. mounting locations for lights, winch, and more
    3. protect the vehicle on the street from Hyundai's and Kias
    make it stronger off road, and better clearance
    protect against nature like deer
    It protects the investment. That's what the truck is. Spending $18k on an overpriced truck for it to be written off by a simple Kia because it wasn't protected, is not wise.
    4. a step surface to work on the truck
    5. if somebody hits you prior, which is common, they're going to pay for it. Same goes for the rear.
    6. Wrap around. Take for example ARB front. It wraps around (coverage)
    7. visibility safety. ARB lights add more lights. It's a steel bumper. If a person sees it and is 1% less likely to pull out, I'll take it.
    8. Evens the look. Odds are you've been hit in the rear and got a free steel HC rear. That looks odd with no front.
    9. Recovery points
    10. Durability. I'm pretty sure the coating is durable
    11. Crash safety. It's gonna do better in a crash.
    Ajclouse[QUOTED] likes this.
  11. Jan 12, 2025 at 11:47 AM
    Ajclouse
    Ajclouse Member
    VA Blue Ridge Mtns
    Thanks. I've managed to never been in more than a parking lot bumper knock so I just don't think about collisions. I know it'll happen eventually so I'm glad I asked. Tax refund might not last long this year...
    ARB seems to be the go to. Especially with the crash ratings. I know IIHS has standards and the like, but they only test up to 35-40 mph I think, assumption being the driver will manage to slow down some before impact (or nobody ever passes 60+ mph crash tests). Road illumination is another good bonus. Thanks again
  12. Jan 12, 2025 at 1:12 PM
    Nerwinski
    Camino, CA.
    The question wasn't, brush guard or bumper? It was, can a brush guard and an integrated Winch plate be used in conjunction and/or are there any products like the warn trans4mer still being produced?
    Still, despite the forewarning, everyone has to chime in and demonstrate how smart they are without actually answering the question.
    WhY wOuLd YoU gEt A bRuSh GuArD?!
    Because I think they look cool on trucks that're otherwise stock, a mounting option for some lights, and to guard my frontend from the brush I frequently drive through. Yes I know I can achieve all that with a bumper and get even better protection. I don't care, I think that would look stupid, like when footballers practice with their helmets on only. I'm not concerned about added protection. My want for a brush guard is mostly cosmetic, my inquiry about running a winch plate concurrently is simple curiosity.
    Please, if your only addition to the post is the benefits of a winch bumper, just move along.
  13. Jan 12, 2025 at 1:26 PM
    Little Lion
    Little Lion Well-Known Member
    2018 Barcelonian Sport MT
  14. Jan 12, 2025 at 1:47 PM
    The Field Archer
    The Field Archer Well-Known Member
    North New Jersey
    15 Tacoma Double Cab 4x4 TRD Sport
    Rough crowd!
    It's your truck and if that's the look you are into, more power to ya!
    I thought Warn had one but no luck finding it online. If nothing is available, maybe go hidden winch mount and then have the non winch brush guard that are still available, still a choice of those out there.
    Best of luck with your search! Ignore the ones that think everyone needs an extreme rock crawler set up, like theirs!
    BTW, this was my 91, just sold it last year!
  15. Jan 12, 2025 at 3:18 PM
    GilbertOz
    GilbertOz Driver
    CA
    Who cares what minor benefits a brush guard might bring for minor events like running into br
  16. Jan 12, 2025 at 3:21 PM
    JMcFly
    Central FL
    2012 Tacoma SR5 4x4
    The ARB bumper should meet OPs requirements plus it’s a quality unit for a winch with solid recovery points.
    Brush guards aren’t my cup of tea but some people like them so why not suggest a good brand
  17. Jan 12, 2025 at 3:22 PM
    GilbertOz
    GilbertOz Driver
    CA
    I agree with you completely.
    I just had to post the meme because your username contains "McFly."
  18. Jan 12, 2025 at 3:29 PM
    JMcFly
    Central FL
    2012 Tacoma SR5 4x4
    ha, cool.
  19. Jan 12, 2025 at 7:49 PM
    Nerwinski
    Camino, CA.
    Exactly what I'm wondering, if the two can be used at the same time. I feel like their mounting locations will conflict with one another.
    That's an option I'd not yet considered. Definitely going to look further into it. Much appreciated.
    Little Lion[QUOTED] likes this.
  20. Jan 13, 2025 at 7:02 AM
    UMC
    UMC I will not comply
    Thomas
    South Fork of the American river.
    13 TRD Sport DCLB 4x4
    35's & rear locker
