Brotherhood of the wrong drain plug... Preferred transmission fluid pump.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AJ112, Dec 17, 2018.
  1. Dec 17, 2018 at 9:06 PM
    AJ112
    AJ112 [OP] Member
    AJ
    2013 Prerunner
    So, yeah... Created a bit of a maintenance opportunity for myself. Looking to purchase a material / fluid pump to perform a transmission fluid change. Would like a cheap, reliable and fast electric pump ... Not sure if you can choose all three (cheap, reliable and fast). Whatchya got?
    AJ
  2. Dec 17, 2018 at 9:12 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Do you have a tow package? You can use the transmissions internal pump. No need for fancy equipment.
    Hook up the cooler Inlet to a hose submerged in a bucket of fresh WS and the cooler outlet to a hose draining into an empty bucket and start the truck.
    steelhd, AJ112[OP] and inwood customs like this.
  3. Dec 17, 2018 at 9:23 PM
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    Hand pump at Walmart. Hand pump offers better control.
    Did the same thing once. Good luck.
    AJ112[OP] likes this.
  4. Dec 17, 2018 at 11:03 PM
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
  5. Dec 18, 2018 at 3:55 AM
    AaronNY
    AaronNY Well-Known Member
    Syracuse NY
    2011 MGM 4x4
    Bilstien 5100s Hella 500s and 700s
    Not electric but i auggest a mityvac 2 way fluid evacuator. Has suction and blow. Comes in handy changing oil on vehicles you dont want to take the skid plate off of to get to the drain plug. Just stick the hose down the dipstick tube and pump the oil out. Ive used it on a few transmissions now without dipsticks to add fluid.
  6. Dec 18, 2018 at 4:38 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    i ran a clear hose through the engine bay, hooked up a funnel and poured in.
  7. Dec 18, 2018 at 6:58 AM
    Trouble_The_Tacoma
    Conrad
    Also, I have a scanguage 2, it helped to be able to check the proper temperature for the transmission fluid. Truck has been fine since I had "the accident" (about 20,000mi ago) but I still plan on having fluids drained and replaced around 60,000mi for peace of mind.
  8. Dec 18, 2018 at 7:04 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Another alternative is a $10 pump sprayer from Walmart. YouTube has videos.
    Tacosail, AJ112[OP] and landphil like this.
  9. Dec 18, 2018 at 8:03 AM
    seedy_tea
    seedy_tea Well-Known Member
    chris
    Cape Cod
    2009 TRD-OR DC
    +1
    jkuniverse and AJ112[OP] like this.
  10. Dec 18, 2018 at 8:12 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Yes, sprayer pump works great.
    Tacosail and AJ112[OP] like this.
  11. Dec 18, 2018 at 8:15 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    The internal pump won’t suck in the new fluid. You either need gravity or the pump the OP is looking for.
    b_r_o and AJ112[OP] like this.
  12. Dec 18, 2018 at 8:21 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Simplest - cheapest - easiest way to refill transmission. Clear vinyl tubing - 1/2" ID - 5/8" OD
    The 5/8" OD tubing fits in the fill hole nice and snug. No waddling around or falling out.
    Same goes for the rear differential - only here you use a length of 7/8" heater hose and a 3-4" long plastic tube(1/2" Wide) that fits in the end of the hose that goes into the fill hole. Hold in place with a hose clamp. See plumbing/gardening sections at HD/Lowes The rest of the hose is routed up over RR tire and a funnel is fitted into that end. Pour in the gear oil. Much easier than fooling around with a pump while underneath the vehicle.
  13. Dec 18, 2018 at 9:30 AM
    ejl923
    Eric
    Western Mass
    yup, 1/2 recommended. When i did this, i had bought a hand pump that attaches to the bottles, and it took forever. so out came the clear hose and bam, its the way to go. I think i did the front diff the same way, dont remember, but its not as much volume so not as big a problem
  14. Dec 18, 2018 at 9:37 AM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    I just get under the truck, take a gulp of fluid and spit it into a 1/2" tube. Takes a little longer, but you really feel like you accomplished something when you're done.
    b_r_o and Bocsy44 like this.
  15. Dec 18, 2018 at 11:36 AM
    Trouble_The_Tacoma
    Conrad
    Is that why your Avatar photo looks like that? How much of that stuff did you drink? :rofl:
  16. Dec 18, 2018 at 2:57 PM
    AJ112
    AJ112 [OP] Member
    AJ
    2013 Prerunner
    Trouble I ordered the little Carista ($13) hoping it provides Temp info. It looks to be pretty limited as to what you can do on Gen2-3 trucks. I'm sure I'll wind up a Scanguage in the coming days. My Brother is a ASE Master and owns an Independent shop focusing on premium imports. He's had the big-boy talk with me several times over the years.
  17. Dec 18, 2018 at 2:57 PM
    AJ112
    AJ112 [OP] Member
    AJ
    2013 Prerunner
    Sharpish I do indeed.
  18. Dec 18, 2018 at 3:05 PM
    AJ112
    AJ112 [OP] Member
    AJ
    2013 Prerunner
    EJL if the Wife is around (Certified to pour lubricants and correct every decision I make while driving) this is the way I'll go. If it's a solo service... I'm gonna be smashing that little pump for a couple of days.
  19. Dec 18, 2018 at 3:22 PM
    AJ112
    AJ112 [OP] Member
    AJ
    2013 Prerunner
    Aron, I picked up a little hand transfer pump at the WallyWorld, a stitch and a quarter of half inch vinyl tubing and ordered a brand spankin' new, 2-way Mityvac from the Amazons (It was time for a new one and I wanted to treat myself with something pretty.) Keeping my options option. Picked up 4-quarts of WS from Mister Toyota Dealer so I can get to work Thursday Morning, but going to do the filter and a full change (probably Redline) this weekend.
    I feel terrible, I used to put the little guy on the jack-stands once a month and wash his cute little belly, now he's sitting all alone in the driveway with an empty transmission pan while I Christmas party it up with my 71 year old mother... "Tis the Season for Natural Light" she always says. (She's a bit of a Redneck, always complaining on the local AM radio call-in show how the grocer wont take shotgun husk in trade. That really grinds her gears.)
    AJ
  20. Dec 18, 2018 at 3:37 PM
    AJ112
    AJ112 [OP] Member
    AJ
    2013 Prerunner
    Marine, I cannot help but notice your most excellent choice of masking tape on that posted photo. Are you giving it honest work, or using it for household painting?
    AJ
