Broken tailgate handle internals?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MTBtaco1200, Jun 1, 2019.
  1. Jun 1, 2019 at 10:07 AM
    MTBtaco1200
    MTBtaco1200 [OP] Member
    Cole
    2014 DCSB Sr5 Texas edition 4x4
    RC 3in/2in lift, road armor rear bumper, RC bull bar, two 10in subs on 600 watts. Falcon wildpeak 33s.
    I couldn't find any threads about stock handles breaking.... So my tailgate handle always felt very hard to open (had to pull hard and it would engage at end of stroke) one day I was in a rush and opened it fast only to hear a loud snap and something break and drop downwards internally. Now the tailgate is locked on and the handle has zero resistance. Anyone experience this? If so, how much did was the repair or would it be easy to fix on my own? (Sr5 handle with built in camera)
  2. Jun 1, 2019 at 10:22 AM
    mrl390
    mrl390 Well-Known Member
    2019 Tacoma Double Cab TRD Off-road
    There are long metal rods that go from the latches to the handle. Most likely the plastic clips that attach the rods to the handle broke. Sounds like one or both of your latches were crusty and hard to pop open which likely caused the resistance that broke the clips. You’ll want to replace the clips but also hose down the latches with pb blaster or wd40 to loosen them up so this doesn’t happen again.
  3. Jun 1, 2019 at 10:24 AM
    mrl390
    To open the gate, remove the panel on the inside of the gate and then just pull on the metal rods by hand to open the gate.
  4. Jun 22, 2019 at 6:52 PM
    deerslayer75
    deerslayer75 Well-Known Member
    Tim
    jersey shore
    11 TRD sport Dblcab Lngbed
    pop-n-lock, mcgard tailgate lock, chrome tube steps, bed extender, chrome brush guard, Fold a cover (G-4) tonneau, weather tech floor mats and rain gaurds, sock monkey: TRD 3rd brake light and whitetail decals, LED bed lights, blue map & dome, 3rd brake light and license plate LED mod, illuminated 4x4 switch, fishing rod holder mod, scangauge II, Remote start & alarm, TW sticker, Flyzeye cupholder light mod
    I believe the problem is you can't remove the inner plastic cover if the tailgate is closed
  5. Jun 23, 2019 at 6:52 AM
    nasaengr
    nasaengr Well-Known Member
    Red15 DC OR
    To remove the inner panel with the tailgate closed first take out the 7 bolts on the top with a T30 star bit. Then pop off the plastic cover on the top of the tailgate. Remove the rest of the T30 bolts from the panel and slide the panel out vertically. Might need some silicon lube to help it past the two rubber bumpers. Now manually reach in and pull the levers to release the gate.
