Broken Tail Light Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wingspar, Sep 28, 2019.
  1. Sep 28, 2019 at 12:29 PM
    wingspar
    wingspar [OP] Well-Known Member
    Oregon
    2011 Tacoma 4x4 Access Cab
    If you look at the photo below you will see a piece of the clear plastic broken out and the inside is covered in dust. I can see no way to get it out. All I need to replace is the broken plastic, not the entire light assembly. Is this possible and how in the world do you get it out?
  2. Sep 28, 2019 at 2:41 PM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    You could bake it? Not sure if they are the same as headlights
  3. Oct 2, 2019 at 11:39 AM
    wingspar
    Oregon
    So, I guess replacing the tail light glass is not possible???
  4. Oct 2, 2019 at 11:41 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    I dont believe the glass is replaceable. Nor would the baking method work like headlights.
    I believe guys doing retrofit tailights are cutting the lens off the housing and then re-gluing it back when completed.
    Island Cruiser and BassAckwards like this.
  5. Oct 2, 2019 at 12:18 PM
    Tarheel22
    Tarheel22 Well-Known Member
    Raleigh, NC
    2012 Silver TRD Sport 4X4 DCLB
    none yet
    I had to replace the tail light on mine. They are pretty cheap out there, you can probably find one from someone who has upgraded to different tail lights. Very easy to swap out, took me only about 15 minutes.
    PzTank likes this.
  6. Oct 2, 2019 at 12:27 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    ^This.
    The housing is held in with a couple (maybe 3) screws accessed when from the inside when the tailgate is dropped.
    Sometimes they can be rusted in depending on the age and location of the truck.
    When you get the screws out, there are a couple of clips that hold it in. Be careful not to snap them.
    Look in the classified section here or online. I bought a used one through Amazon for fairly cheap $$ for my ‘07.
    tacoman45 likes this.
  7. Oct 5, 2019 at 10:38 AM
    wingspar
    Oregon
    I thought someone left me an Amazon link that I looked at and could not find what I want, but don’t see the link anymore. When I saw “bake it” I thought of chocolate chip cookies. I bake them at least once a week, but baking headlights? Makes no sense to me.
    The light works, it just collects tons of dust from that little crack. Replacing it would be nice, but maybe some duct tape would work to keep the dust out. Duct tape on a Tacoma? Ugh.
  8. Oct 5, 2019 at 11:24 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    If you are really trying to save a buck pull the light off and take the old style bulbs out, rinse lightly with water to get the dust/dirt out, then use a blow dryer to get it dry inside. Then clear tape (packing type) over that missing lens. Make sure it is dry so you don't get a lot of condensation inside and blow the LED lights. Worth a try if so inclined. Much easier to replace the assembly.
  9. Oct 5, 2019 at 12:33 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    You will have too replace the whole unit.
  10. Oct 5, 2019 at 1:06 PM
    Tarheel22
    Raleigh, NC
    none yet
    I think you could probably find a whole unit it great condition for something like $40. Not worth trying to fix it
    Canadian Caber and Chocobot like this.
  11. Apr 22, 2024 at 7:17 AM
    113tlc
    113tlc New Member
    2013 Toyota Tacoma
    I broke the cover on my rear tail light and was hoping to easily replace it myself. Having to replace the entire unit is way out of comfort zone :) Great thread. Thanks for all the info.
  12. Apr 22, 2024 at 7:47 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    It's one of the easiest repairs you can do on the truck. If you can turn a screw driver, you can replace it. I bet there are youtube videos on how to do it.
  13. Apr 22, 2024 at 7:55 AM
    113tlc
    113tlc New Member
    2013 Toyota Tacoma
    Island Cruiser likes this.
  14. Apr 22, 2024 at 8:04 AM
    Revelations
    2014 MGM DCSB
    Good video to watch.
    wingspar[OP] likes this.
  15. Apr 22, 2024 at 8:33 AM
    113tlc
    113tlc New Member
    2013 Toyota Tacoma
    Fantastic. Tail light has been ordered. I'll let you know how it goes.
  16. Apr 22, 2024 at 5:53 PM
    wingspar
    Oregon
    Got the notification of a new reply to this thread and imagine my surprise to see that I started this thread 5 years ago. I’ve never really done anything with the tail light as it’s really no big deal, but that video was extremely helpful. Silly easy.
    I do wonder if there is a backup light bulb that can be installed to replace the factory one that actually lights up the area behind the truck when backing into my dark driveway at night. The factory ones are worthless.
  17. Apr 22, 2024 at 6:57 PM
    Revelations
    2014 MGM DCSB
    You could install a light bar or some aftermarket LED foglights with a spdt relay. Tap one of the reverse light wires for the trigger.
    wingspar[QUOTED][OP] likes this.
  18. Apr 23, 2024 at 5:49 AM
    drainsbe
    drainsbe Well-Known Member
    Dave
    Fort Worth TX
    2015 Tacoma DCSB 4x4
  19. Apr 23, 2024 at 10:06 PM
    wingspar
    Oregon
