Broken stabilizer bar...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Imageoguy, May 19, 2015.
  1. May 19, 2015 at 9:22 AM
    Imageoguy
    Imageoguy [OP] Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
    Not sure how this happened but noticed some grease under my front fender today and saw this:
    Is it OK to drive if I remove the stabilizer bar for a week?
    Had a quick quote from my stealership, about $ 560 for a new shaft (because of broken boot) and $ 120 for a new stabilizer link. They quoted about 2 hrs of work over the phone ( $180).
    Anybody had this happen to em?
    It might have something to do with that 2`deep and wide rut I went thru at 60 MPH on a logging road a week ago...
  2. May 19, 2015 at 9:49 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Lot's of people take their sway bar off and leave it off so you'll be fine for a week. Just keep an eye on that CV, it looks pretty chewed up from the pics. Oh and take it easy in the corner, you'll have more body roll.
  3. May 19, 2015 at 9:53 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The end link broke probably due to flexing it offroad. Remove the swaybar and end links and ill bet you never put it back on again.
    Replace that CV too.
  4. May 19, 2015 at 10:01 AM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    If you take the sway bar off just be aware that it isn't on and your truck will handle differently. I took my sway bar off a while ago but I don't have the stock suspension either.
  5. May 19, 2015 at 10:18 AM
    Imageoguy
    2012 DCLB SR5
    Thanks guys, I`ll take the sway bar off until I can get it fixed along with the CV axel.
  6. May 19, 2015 at 10:23 AM
    D50boy
    D50boy Well-Known Member
    Kenneth
    Texas
    They're more for on road handling. Keeps the truck flatter on a hard curve. You'll be fine without it but don't drive it like a sports car. I'd hit up a junkyard for that link.
  7. May 19, 2015 at 10:30 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Or get new sway bar links from allpro and install yourself. Then pick up a new cv from your local auto stor for 80 dollars. watch a couple youtube vids and install a new cv yourself or pay toyota to do that
    D50boy likes this.
  8. May 19, 2015 at 11:06 AM
    Imageoguy
    2012 DCLB SR5
    Thanks, I might order that sway bar link.
    I don't think it`s a good idea for me to take out the sway bar for an extended period of time. I like driving my taco like a sportscar and I need to haul my ATV on my bed deck for work this summer, it makes for a rather high center of gravity.
    As for the CV shaft, I would prefer buying OEM since I abuse my truck on a regular basis. Not sure if I trust aftermarket for that type of part. I don't really have a lot of time to change it myself for the next while and I`m still under warranty so I`ll probably have the dealership do the work and bite the bullet.
  9. May 19, 2015 at 11:10 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    you can also see if you can buy an extended sway bar link to accomodate your lift...if you have one. it should give more flex..
