Broken lug nut stud
Discussion in '3rd Gen. Tacomas (2016-2023)' started by deanb1234, Jul 21, 2018.
  1. Jul 21, 2018 at 6:04 PM
    deanb1234
    deanb1234 [OP] Well-Known Member
    Dean
    18 Cement TRD Offroad
    80762549-0569-411F-B0FC-AA1BF25E020D.jpg Well I went and screwed up.
    Was plastidiping my wheels, putting the front one on I I spun a lug stud clean off.
    Never had this happen to me before......
    What do I do now?
  2. Jul 21, 2018 at 6:06 PM
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    Ni biggie. Go to a shop and have the old one pressed out and a new one pressed in.
  3. Jul 21, 2018 at 6:08 PM
    iPaint
    iPaint Well-Known Member
    Nebraska
    2017 TRD OR DC 4x4 AT
    Same thing happened to me on my ‘16. 3 of them on the left rear. Had to pound them out the back side. I’m not sure if it’s the same process on the front. Toyota wheel studs are very weak, watch the torque specs!
    stealthmode and deanb1234[OP] like this.
  4. Jul 21, 2018 at 6:10 PM
    deanb1234
    Dean
    Using an impact like I always have on all of my other vehicles, just run it till it stops and always been good! Guess I need to invest in a torque wrench....
    Lucifer1 likes this.
  5. Jul 21, 2018 at 6:10 PM
    deanb1234
    Dean
    Thanks, doesn't sound like a big deal, I was cussing and throwing lug nuts lol
    Is it safe to drive with one of the lugs missing?
  6. Jul 21, 2018 at 6:12 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Yeah our lug nut torque is pretty low, I believe it's only 83 ft lbs.
  7. Jul 21, 2018 at 6:14 PM
    iPaint
    Nebraska
    The other ones may be stretched and weakened now. On mine they broke one at a time. First one broke, take wheel off, replace stud. Put wheel back on, second stud breaks, pull off again and replace stud. Put wheel back on, third stud breaks. I wouldn’t drive it and buy a few extras just in case!
    Lucifer1 and Mr-Paul like this.
  8. Jul 21, 2018 at 6:16 PM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    Yes and No...
    Driving to dealership to fix it for few miles drive.. its ok
    But if you doing offroad and wheeling.. NO
    deanb1234[OP] likes this.
  9. Jul 21, 2018 at 6:23 PM
    deanb1234
    Dean
    Should I just have them replace all on that side?
  10. Jul 21, 2018 at 6:24 PM
    deanb1234
    Dean
    What if I have to wheel to get to the dealer?!?! ;):rofl:
    Mr-Paul likes this.
  11. Jul 21, 2018 at 6:24 PM
    iPaint
    Nebraska
    As weak as mine felt when the second and third ones broke, I wouldn’t trust it. At least back them off and look to see if the threads are stretched and the coating between isn’t cracking. If all the other studs look good and torque down good, then drive to get your sixth stud on the remaining five.
    Mr-Paul and deanb1234[OP] like this.
  12. Jul 21, 2018 at 6:27 PM
    iPaint
    Nebraska
    I didn’t replace all of mine but I always kept a few extra in the truck after that.
    deanb1234[QUOTED][OP] likes this.
  13. Jul 21, 2018 at 6:28 PM
    Mr-Paul
    Mr-Paul Well-Known Member
    Paul
    2017 Qucksand Tacoma SR5 4x4 V6 Access-Cab
    You are fine to drive it with 5 out of 6 lugs until you have the time to get it fixed.
    I just replaced 4 stripped studs (2 on the front and 2 on the back) on my Wife’s Subbie.
    Even highway speed , it will be fine for 1 missing lug.
    P.S.
    Never gonna let my wife go to ETD in Wayne NJ for “Free Tire Rotation” again.
  14. Jul 21, 2018 at 6:31 PM
    Mr-Paul
    Paul
    FYI, torque spec on the Tacoma lugs is 83 Ft-Lb. You might have got one of the off-spec lead studs that sheared- off easily. It happens.
  15. Jul 21, 2018 at 6:34 PM
    deanb1234
    Dean
    Good advice, I'll put it back on the jack tomorrow and check em out.
    Mr-Paul likes this.
  16. Jul 21, 2018 at 6:35 PM
    deanb1234
    Dean
    Good to know. But I have a feeling it was a heavy finger on the trigger of the impact lol :frusty:
    Steves104x4 and Mr-Paul[QUOTED] like this.
  17. Jul 21, 2018 at 6:36 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Your big problem that caused this problem was using the impact to tighten the lug nuts
  18. Jul 21, 2018 at 6:39 PM
    Mr-Paul
    Paul
    I never use an impact wrench to install lugs. Hand tight and then torque wrench to factory spec !!!
    I keep telling my son (ASE ceritified mechanic) the same thing and he keeps killing studs on customer repairs !!!
  19. Jul 21, 2018 at 6:48 PM
    deanb1234
    Dean
    I worked at a tire shop in high school doing easy stuff like plugs, tire changes, and balancing and that's where I learned to use an impact. Hand tighten then a few hits with the impact and send the customer on their way.
    I always knew in the back of my head I should use a torque wrench but never had an issue till tonight....live and learn I guess..
  20. Jul 21, 2018 at 6:57 PM
    Mr-Paul
    Paul
    Risk versus Reward !!! It is fine until there is a busted stud/lug laying on the ground.
    I broke a lug bolt on my 1988 VW and had to buy a Metric tap to fix that disaster when I gunned it on. That was the last time I used an impact wrench to install lugs.
    If you learn from your own mistakes, then I am a genius !!!
