Broken Leaf Springs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by morg59, May 5, 2014.
  1. May 5, 2014 at 2:20 PM
    morg59
    morg59 [OP] New Member
    Salt Lake City
    01 Double Cab
    Has anyone ever seen this happen?
    Leaf looks like it broke in the middle. Put a large groove in my tire as well.
    What should I do to fix it? Any help is appreciated.
  2. May 5, 2014 at 5:03 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Uh, yeah at the very least your spring clamp is busted allowing the leaf to rotate. But more likely that the leaf is broken. time for new springs.
  3. May 5, 2014 at 5:04 PM
    Box Rocket
    Adam
    Syracuse, Utah
    Looking at that again.....is that an AAL? If it is it's probably too short to be held in place by the spring clamps. Get that thing outta there.
  4. May 5, 2014 at 5:16 PM
    PPansini10
    PPansini10 Well-Known Member
    Paul
    NJ
    09' DCSB 4x4 TRD Sport
    not sure if its an AAL but if not then the same shit happened to my stock springs a year or so ago.. apparently its not that uncommon
  5. May 5, 2014 at 5:41 PM
    morg59
    Salt Lake City
    01 Double Cab
    any suggestions on what springs to get as replacements?
    Sent from my Nexus 5 using Forum Fiend v1.2.6.
  6. May 5, 2014 at 7:04 PM
    MoonCrawler
    MoonCrawler Well-Known Member
    Sacramento, CA
    2003 Tacoma V6 4x4 TRD
    It does look like an AAl, but I don't know why it has rotated out like that. The u-bolts should prevent that from happening. But there are three leaves above it and that is the number for the stock springs.
    How long does it extend on the other side?
  7. May 5, 2014 at 7:10 PM
    geoff06
    geoff06 261k and counting
    WI
    '01 PreRunner Xcab lifted
    3" lift, Bilstein 5100/OME coilovers, rear AAL, Swiss camper shell, Rough Country 9000 rear shocks, 265/75/16 AT's on stock steel rims painted black, All-Pro 1.5"F/1.25"R wheel spacers, airbox elbow mod, Flowmaster Super 44, Davico post-cat, I took off my DIY angle iron bed/light bar!, bed wheel well shovel-mount, blacked out grill emblem, Poineer DEH-P3900 head unit, Alpine Type R front component speakers, Pioneer Coaxial rears, Dynamat in door panels, scratchbuilt aluminum holders for my ipod nano and phone, and for some reason, I painted the headlight fillers black...
    :eek: Yikes! I've never seen that happen before. What were you doing around the time it happened?
  8. May 5, 2014 at 7:16 PM
    Zer0
    Zer0 Well-Known Member
    SGV, California
    99 PreRunner
    you want good cost effective leafs? get Dorman leafs....run you about 100 bucks each. I have Dorman leafs and theyre great let me tell you. I paired them with some 38 dollar KYB and let me tell you they great too!
  9. May 5, 2014 at 7:33 PM
    MoonCrawler
    Sacramento, CA
    The end of that leaf that is in the picture.......that's not where it broke. That was cut that length long before the rust started happening. You can see the rust mark on the leaves above it as well, showing its original length. In order for it to have rotated out like that, it would have had to crack somewhere between the u-bolts. If not, they would have kept it in line. Check there.
    You don't necessarily need new springs. You just need to replace that broken AAL (and the one on the other side). You can see it's far more rusted out than the rest of the leaf pack. Granted, the stock leaf packs suck ass, so its not a bad time to replace them anyhow, but it costs a little more.
  10. May 6, 2014 at 7:51 AM
    Box Rocket
    Adam
    Syracuse, Utah
    Depends on if you want lift springs or not. Where are you in SLC? I work downtown if you want to take a look at what's on my truck sometime. I'm happy to offer suggestions whichever way you want to go. I'm happy to take a look at your springs too and help see exactly what the problem is.
  11. May 6, 2014 at 10:20 AM
    DreamMachine
    DreamMachine Active Member
    All good suggestions on the leaf spring... but let's not ignore the tire. You'll need to replace that too! :eek:
  12. May 6, 2014 at 10:31 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yeah thats a nasty spring mis alignment, I'd either fix or replace the leafs all together, but def. should be broke down inspected if you intend to rebuild them (thats what Id do) might of even sheered axlepin allowing the leafs to loosen up breaking & flopping sideways
  13. May 6, 2014 at 10:41 AM
    Smoke
    Smoke Well-Known Member
    Eastern Ontario
    2006 SR5
    Seen it happen many times on vehicles that are used offroad and flex ALOT. Aka Jeeps, Samurais, FJ40s, etc.
    Its from reverse arch and stress on the leaf.
    Replace both sides at once and back to the trail you go. Its like replacing brakes but you only do it once every 10 years at worst. lol
  14. May 6, 2014 at 10:46 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Or like a few here that think they drive 1 tons & overload them ......I see this breaking leaves more than anything else, but extreme flexing will fatigue to failure as well...
  15. May 7, 2014 at 7:32 PM
    nswsparky
    nswsparky Well-Known Member
    Chad
    Minnesota
    '03 TRD, SAS, ARB's F/R, Atlas 4 speed
    D44, SAS, 3 link coilovers, ARB's, Ford 8.8, Atlas 4 speed, cutting brakes.
    its not broken just came misaligned, pound it back in with a BFH. Would happen all the time on my Cherokee just keep an eye on it. It takes a while for it to travel out that far. And Check the u-bolt to make sure they are still tight. And if It was me I would still run that tire, no belts exposed.
  16. May 8, 2014 at 4:53 AM
    Smoke
    Eastern Ontario
    2006 SR5
    ahh I cant tell from the pictures because there are like 3 pixels per picture. lol
  17. May 8, 2014 at 6:57 AM
    DreamMachine
    I'm sorry, I disagree with you on every account. Look at the angle of the leaf. From the visible tip of the exposed leaf follow the center line back to where it would exit out the back. It would have to be going straight through the rear u-bolt.
    OP needs to post more pictures of the leaf from all angles.
  18. May 8, 2014 at 7:14 AM
    Smoke
    Eastern Ontario
    2006 SR5
    Ones with higher res would be nice... lol
  19. May 8, 2014 at 9:53 AM
    nswsparky
    Chad
    Minnesota
    So you don't think the front end of that leaf is sticking out the opposite direction. I don't know it could be it is close. If only the back part of the leaf is sticking out then yes it would be broke.
    I can say on my Cherokee the leaf never stuck out that far but the tire was only like and inch away from the leaf so the tire would stop it before it got that far.
  20. May 8, 2014 at 10:13 AM
    DreamMachine
    No It's not physically possible for that leaf to turn a that angle unless the u-bolt on the opposite side of the axle were missing. Which it isn't.
    The springs still appear to have arch in them. Just order another set of AAL's and 4 new Ubolts (Important) and it should be good to go. At least, given the information in front of me, that is what I'd do. I'd also replace that tire.
