Broken Leaf Spring?
Discussion in 'Suspension' started by jrich44, Oct 15, 2011.
  1. Oct 15, 2011 at 11:28 AM
    jrich44
    jrich44 [OP] Well-Known Member
    Jared
    Des Moines, IA
    2024 Tacoma TRD Sport 6-MT
    I was under my truck today, jacking it up to take the rear wheel off to paint them, when I noticed the driver's side leaf spring had a leaf that didn't extend all the way to the front. It looks like it is the middle leaf and it broke just after the U bolts. I took some pictures, if I could get your input that would be appreciated.
    Broken Leaf Spring on Driver's Side:
    View of the front of that broken spring:
    Passenger's Side View (Not Broken):
    I am assuming it will have to be replaced real soon, which upsets me because both leaf spring were just replaced a few years ago by the previous owner. I don't know if they were of bad quality or what. Could too much weight in the truck break a leaf spring, I thought it would just hit the bumpstops.
    So now I guess I just need to figure out whether to buy new OEM springs or lift it while I'm buying new springs.
  2. Oct 15, 2011 at 11:52 AM
    jrich44
    Jared
    Des Moines, IA
    The truck has been in Minnesota, so I'm sure that could have caused the rust on the springs to develop so quickly.
    The only concern I have with lifting it would be replacing the shocks. I just bought those Bilsteins brand new for about $350 / set. Does anyone know if they will still work with a certain size lift, they are the recommended replacement model from factory shocks.
  3. Oct 15, 2011 at 12:08 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    What bilstein shocks are they? Pics? The 5100s and 5150s are supposed to be able to work with trucks lifted 0-3". I would definitely get a new aftermarket leaf pack though.
  4. Oct 15, 2011 at 12:16 PM
    jrich44
    Jared
    Des Moines, IA
    I believe they are the 4600 series Bilsteins
  5. Oct 15, 2011 at 12:30 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Your leafs are SHOT! Strongly recommend new ones. You can get replacements that will give you stock height, or a bit of a lift. Call the experts at ...
  6. Oct 15, 2011 at 12:42 PM
    jrich44
    Jared
    Des Moines, IA
    Ok, will do. I'll give Wheelers a call about a new leaf pack after I call Bilstein and figure out how much further those shocks I have can extend. What about the front coils, do you guys think that it would be smart to replace them as well, considering the condition of the rear springs.
  7. Oct 15, 2011 at 2:03 PM
    Norton
    No. Leaf springs are supposed to "smile". You should consider replacement if they're flat or "frowning".
    You might try DownSouth Motorsports for your shock questions. Both DSM and Wheelers offer TW member discounts and know their business very well.
  8. Oct 15, 2011 at 2:04 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    No, they are bad. Mine look the same, just no money to fix them right now.
  9. Oct 15, 2011 at 3:16 PM
    Norton
    Lift numbers are normally quoted based on the adjustment you can expect from stock. Since your leafs are sagging, you'll likely get more than 1.5" from where you currently sit. As a point of reference, I went with , which is designed to provide 1.5" of lift, and I got about 2" of lift (as referenced from my truck's pre-upgrade height).
  10. Oct 15, 2011 at 3:35 PM
    Norton
    Unfortunately, the answer is "it depends." You probably don't NEED an extended brake line, but it's a good idea. You can re-use U-bolts, only if they're in good shape. Bushings will almost certainly need to be replaced, and a brake proportioning bracket would also be required.
    Recommend contacting the experts at . They can provide you the best advice for your specific situation.
  11. Oct 15, 2011 at 4:16 PM
    jrich44
    Jared
    Des Moines, IA
    Back to my original posting... does anyone have any recommendations for new leaf packs at stock height? I would rather keep my current shocks, so I think I'll just be replacing the leaf springs. I have done some searching and haven't found too many manufacturers that offer the stock height. I don't really wan't another set from Toyota, considering they have failed twice now. Another thing I was thinking of was having a set made by a local shop, does anyone have any experience with this, or know of a manufacturer that makes a decent set?
  12. Oct 15, 2011 at 4:56 PM
    jrich44
    Jared
    Des Moines, IA
    No problem, thanks for your help
  13. Oct 15, 2011 at 8:34 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    started breaking springs on my "95" reg cab. seemed like when I'd get one fixed another one would break. finally the spring shop suggested to add an extra leaf on each side. that seemed to stop the problem. should have just replaced the whole pack with new ones,but didn't expect more to break like they did. had single broken leafs replaced on other vehicles and didn't run into this. usually one and done.
  14. Oct 15, 2011 at 8:59 PM
    Norton
    Coil replacement probably makes sense, given your truck's age and the springs' natural tendency to compress over time. Wheeler's can help with this as well. Normally, I'd suggest , but I'm not sure what they offer at a stock height. Another option to consider are Bilstein 5100 shocks paired with your existing coils. They can be set for stock height or to pre-load the springs. (This provides moderate "lift", returning older springs to their original height.) Note that DownSouth Motorsports has the best deal on 5100s.
    I apologize for not being more specific in my previous recommendation to call . :eek: They carry a that's designed to provide stock height.
  15. Oct 16, 2011 at 9:21 AM
    jrich44
    Jared
    Des Moines, IA
    I have looked around a little more, and from what I have read, the Wheelers leaf packs have been known to break after a year or so and Wheelers says it's normal. If that's the case I will definitely not buy from them. So I looked for other options and came across Skyjacker and their lifetime warranty, much better than Wheeler's 1-year warranty. The problem with the Skyjackers is they offer a couple inches of lift, will these work with the factory length shocks I have (Bilstein 4600 Series), I couldn't find any specific length information for them yet. Or if that wouldn't work, could I take out a leaf of the Skyjackers pack? Any suggestions, basically I would like a solution that doesn't involve new shocks.
  16. Oct 16, 2011 at 9:40 AM
    jrich44
    Jared
    Des Moines, IA
    I'm sure the majority of their products are fine, but I have read multiple threads now saying they broke leaves after a year or so. Also, a one year warranty on leaf springs doesn't say much about Wheelers' confidence in what they sell.
  17. Oct 16, 2011 at 9:45 AM
    jrich44
    Jared
    Des Moines, IA
    Here is one of the cases I found, it's from the Toyota Nation forum:
    "I'd suggest you return them while you still can. Apparently, a lot of people have good luck with Wheeler's, but if things go wrong (and they do) you're SOL.
    I bought a set of leaf springs to replace the broken set on my '00 Tacoma. Eighteen, 100% on-road, light load months later, the Wheeler's set is broken, and out of warranty (one year). I called to express my dissatisfaction, and was told that an 18 month life expectancy is not out of the ordinary, because the design is poor (a near-direct quote from Jason).
    At this point, a replacement would hardly be satisfactory, since replacing Toyota springs in New England means torching apart and replacing all the hardware as well, so I'd be out a day's labor and $100 bucks out of pocket, at best.
    My mistake, I guess, I didn't realize "Wheeler's Off Road" meant my truck would be off the road soon. Maybe I'm nuts, I just think a set of "upgraded" leaf springs should last longer than a loaf of Wonder bread."
  18. Oct 16, 2011 at 10:42 AM
    Norton
    Interesting find, jrich44. Having done a bit of my own "looking around," however, the thread from you quoted is the only one I found describing the problem you allege. As I understand the archive in which I found it (because it's over two years old), one person had a problem. Care to provide links/specific on the the "multiple threads" you've read, preferably something newer than the middle of 2009?
    Don't go crazy yet, Nathan. I just PMd the Wheeler's staff to get their take on this. In the meantime, I can tell you there are quite a few TW members running Wheeler's 4- & 5-leaf spring sets, both of which are made by Alcan. I have yet to hear of one who's dissatisfied.
  19. Oct 16, 2011 at 2:35 PM
    jrich44
    Jared
    Des Moines, IA
    I think you guys are right, that thread I found must just have been a fluke with Wheelers' leaf packs. So I think my best bet is to go with them, now I just need to choose between the 4-spring pack or the 5-spring pack. The 4-leaf pack wouldn't give any lift, therefore I would have no need to replace shocks. On the other hand, the 5-leaf pack would be nice because I'm sure it would last longer until the springs sag as well as being able to handle a little more weight because of the extra spring, but it is listed as providing 1.5" of lift. Could anyone give me any advice to whether or not that would be too much lift for my shocks to travel, again they are stock replacement, meaning same length I believe, Bilstein 4600 Series, brand new.
  20. Oct 20, 2011 at 10:15 PM
    Norton
    Received a reply on my Wheeler's inquiry this afternoon, from Tech/Sales Associate Johnny Kurz. Here are some pertinent excerpts:
    - We've had great results with our springs and I have no worries about any nasty surprises at all
    - Reliability/longevity, like everything, is all about how they're used
    - We will stand behind our products, and help our customers out the best we can if they encounter a problem.
    - We are limited by the manufacturer's warranty, but will do our best to help nevertheless
    - We have never told a customer they are "SOL"
    - I can guarantee we would not let you be SOL...
