Broken Interior door handle, how do I remove the panel with it closed....
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco2sdayz, Aug 31, 2020.
  1. Aug 31, 2020 at 10:03 AM
    Taco2sdayz
    Taco2sdayz [OP] Well-Known Member
    2003 Black Tacoma
    Hey all
    Dropped my kid off at daycare on the way to work this morning and when I opened the door i heard a sound of plastic falling into a cavity. Looked around, saw nothing and moved on. Got to work and tried to get out and nothing. the handle had no resistance on it. I climbed out the passenger side and assumed the part where the metal rod snaps into the plastic door handle broke. Im still at work so havent messed with it yet but, how do I get the door open so I can take the panel off?
    2003 double cab btw
    Thanks in advance for ideas
  2. Aug 31, 2020 at 10:30 AM
    Taco2sdayz
    2003 Black Tacoma
    crickets...well this was a long shot..
  3. Aug 31, 2020 at 10:31 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Pardon my very stupid question, but does the outside door handle not work either?
    Black DOG Lila likes this.
  4. Aug 31, 2020 at 10:32 AM
    SkunkMan17
    SkunkMan17 Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
    Can you open it from the outside?
  5. Aug 31, 2020 at 10:33 AM
    Taco2sdayz
    2003 Black Tacoma
    Not stupid, it didn't open either. But I only had a few minutes before getting into work so it might be locked. the lock was loose also like it moved freely up and down
  6. Aug 31, 2020 at 10:34 AM
    Taco2sdayz
    2003 Black Tacoma
    Because the truck locks as soon as you start it (which I have never liked)
    Agabus likes this.
  7. Aug 31, 2020 at 10:34 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    It should open from the outside unless something got fubar'ed with all the rods. I haven't done an interior handle yet but I've replaced plenty of outer handles, and they each have their own rods. There's one that goes to the interior handle and it sounds like that one's connector got broken, but I would be willing to bet that the outer handle still opens the door (hopefully)
  8. Aug 31, 2020 at 10:35 AM
    Taco2sdayz
    2003 Black Tacoma
    Ok, then that tells me that more than one piece broke. Because it locked when I started the truck but now the lock on the panel moves up and down with no resistance either
  9. Aug 31, 2020 at 10:36 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    use the key to unlock from outside then open the door. If not, you may have to jimmy it.
  10. Aug 31, 2020 at 10:36 AM
    eon_blue
    Azusa, CA
    You've confirmed it won't open from the outside?
    If that's the case then I can't really think what would have broken on the inner handle that would also effect the outer handle...weird
  11. Aug 31, 2020 at 10:37 AM
    Taco2sdayz
    2003 Black Tacoma
    I didn't try using the key to unlock from the outside, I was pressed for time by the time I crawled out the passenger side. Then that should open. Ok, thanks guys
  12. Aug 31, 2020 at 10:51 AM
    eon_blue
    Azusa, CA
    yeah let us know if you can get it to open from the outside handle, I'm betting that you can (when it's unlocked). If you can't, then you might have to jimmy it open like suggested above. I don't think the inner door panel can be removed correctly from inside the truck with the door closed.
  13. Aug 31, 2020 at 10:58 AM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    Another option is to just take off the interior door handle that is held on with just one Phillips (technically JIS) screw And then the handle slides toward the windshield and then it will be free to pull out. Once off, you can grab the metal rod that connects to the door latch and pull it to open the door.
  14. Aug 31, 2020 at 11:00 AM
    BeLance89
    Brandon
    Huntsville, AL
    Side note... this would be a great challenge to put in one of those “espcape room” attractions. Lol
    Taco2sdayz[OP] likes this.
  15. Aug 31, 2020 at 11:50 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  16. Aug 31, 2020 at 12:04 PM
    Taco2sdayz
    2003 Black Tacoma
    Good call. Im sure once I get off work and use the key to unlock the outside then it will open. But, that is an excellent idea as backup
    BeLance89[QUOTED] likes this.
  17. Aug 31, 2020 at 12:53 PM
    Taco2sdayz
    2003 Black Tacoma
    Ha. Well the outside door handle has zero resistance as well. Not sure now. Once I get home ill go from there. But, ill take the handle off on the inside and pull the bar to open the door. Hopefully. Lol
    BeLance89 likes this.
  18. Aug 31, 2020 at 1:34 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    BeLance89 and Taco2sdayz[OP] like this.
  19. Aug 31, 2020 at 1:42 PM
    Taco2sdayz
    2003 Black Tacoma
    Holy crap. This is my problem because pulling the rod doesn't do anything either. Thanks!
  20. Aug 31, 2020 at 1:44 PM
    CrustyTaco
    Todd
    Louisville, KY
    No problem! It's a cheap fix, you can get a replacement spring for $1 at Ace Hardware. It's just a pain in the butt to replace. At the very least you need to remove the driver's seat to pull the door panel. I pulled both seats and the center console because I didn't want to scratch anything.
