Broken hose to air intake
Discussion in '1st Gen. Tacomas (1995-2004)' started by MGM_Grand, Jan 5, 2020.
  1. Jan 5, 2020 at 1:41 PM
    MGM_Grand
    MGM_Grand [OP] Well-Known Member
    Denver, CO
    2017 MGM DCSB TRD OR
    I stole this photo from another thread because I don't have one available right now and highlighted it myself. I'm trying to figure out how urgent a problem this is... I just discovered it.
    2002 Tacoma SR5, Access Cab, Manual Transmission. The highlighted hose is broken at the 'X' in the image. There's fluid all over the oil fill port - I can't tell what sort of fluid. I've had no issues with driving the vehicle as of yet, but recently got the power steering fixed. What's super jank is it looks like the hose was attempted to be "repaired" with camo duct tape - I'm uncertain how long it's been like this.
    FSM's aren't the most helpful right now - they're kind of hard to navigate. Easiest would be a labelled image of the engine bay, but no luck in that department either. Anyone know what this hose connects, if it needs to be fixed ASAP, and what fluid is spraying over my engine compartment?
    Thanks in advance for the knowledge.
  2. Jan 5, 2020 at 2:19 PM
    SkunkMan17
    SkunkMan17 Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
    Can’t really do a whole lot without pics from your engine bay or more info on the color of this liquid so fourth.
  3. Jan 5, 2020 at 2:21 PM
    MGM_Grand
    Denver, CO
    I'll get a photo, but the hose is the same - shouldn't matter if the pic is from my engine or another.
    The fluid is black and sticky - extremely viscous and it's not flowing. But that describes a lot of used engine fluids... Based on where it's been deposited, it seems to have been coming from the driver side portion of the truncated hose.
  4. Jan 5, 2020 at 2:23 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    that hose is for the Evap system. get a long hose to run across the engine bay and replace it. oil on the cap is likely engine oil from messy oil changes over the years and more than likely leaky valve cover gasket
    that hose should have nothing in it. (unless fuel somehow got into the charcoal canister and has broken down the charcoal)
  5. Jan 5, 2020 at 2:29 PM
    MGM_Grand
    Denver, CO
    Ooooh, so is this this part of the line that backfills the tank with air as gas is used up? That would explain why it terminates behind the air filter. Should be easy enough to replace with the right hose length/diameter and band clamps.
    The fluid is harder to explain, since it's also deposited on top of the cap.
    Sorry for my ignorance. So many people here are such a wealth of knowledge.
  6. Jan 5, 2020 at 2:32 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I would just go ahead and replace all of the vacuum hoses, they're probably nearly toast anyway. I did one of the shop kits from siliconeintakes.com, so far so good.
    MGM_Grand[OP] likes this.
  7. Jan 5, 2020 at 2:32 PM
    Empty_Lord
    Dan
    its more than likely just engine oil and probably debris thats sludged up.. my donor 4runner motor was covered in that shit
    MGM_Grand[QUOTED][OP] likes this.
  8. Jan 5, 2020 at 3:43 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
  9. Jan 6, 2020 at 2:29 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    That hose vents the gas fumes into the engine to be burned not like in the old days to the air
    Just how long has that truck been sitting??
    Quite possible that black your seeing is just old oil mixed with dirt then sitting
  10. Jan 6, 2020 at 8:16 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Stick around here for a year and you too will have accumulated a wealth of knowledge! :thumbsup:
  11. Jan 6, 2020 at 9:05 AM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    So. My hose was broke as well. Went to auto zone they don't have the correct diameter hose. Does anyone know where to get a hose with this diameter?
  12. Jan 6, 2020 at 11:04 AM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
    Advance Auto has a kit from Mr Gasket that has the correct size/ silicone
  13. Jan 6, 2020 at 12:05 PM
    Fatal_Paradox
    Bardstown, KY
    Does anyone know the OEM part number ?
  14. Jan 6, 2020 at 1:06 PM
    MGM_Grand
    Denver, CO
    If anyone knows the measurements, I bet you could get an equivalent tube and clamps from ACE or any hardware store for cheaper. It just needs to tolerate extreme temps, which most tubing can do.
  15. Jan 7, 2020 at 6:20 AM
    Fatal_Paradox
    Bardstown, KY
    I have the clamps still, but Can't find the correct diameter hose anywhere.
  16. Jan 7, 2020 at 9:11 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    Not sure what the dia is, but did you check mcmaster-carr?
    Wyoming09 likes this.
  17. Jan 8, 2020 at 1:48 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I bought 100' rolls of vacuum tubing from McMaster-Carr in every size I needed .
    It is not a odd size I can`t see why it is so hard
    Are you measuring where it is swelled from going over the nipple??
    If need be put a piece of steel or copper tube in as a splice till you get the correct size.
    I will go measure and update as soon as I put my feet on .
    cruiserguy likes this.
  18. Jan 8, 2020 at 4:35 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Yeah just being vacuum piping (Toyota name for it, not mine:D) size just needs to be close enough. Metric and SAE should have something close enough. It's just vacuum piping:rofl:
    I like saying that for some reason :D
  19. Jan 8, 2020 at 4:35 AM
    cruiserguy
    Elijah
    SEKS
    Ooohhhh, are you trying to find identical outside diameter?
  20. Jan 8, 2020 at 6:04 AM
    Fatal_Paradox
    Bardstown, KY
