Broken front bumper mount
Discussion in '3rd Gen. Tacomas (2016-2023)' started by longhairedhippy, Nov 30, 2024.
  1. Nov 30, 2024 at 1:40 PM
    longhairedhippy
    longhairedhippy [OP] I never go full redneck
    Ray
    Seattle, WA
    2019 MGM TRD OR SB
    Bunch of stuff bolted on, some cool, some not
    So I've got a DV-8 bumper that I've not been super happy with, however I've just been making it work. I have gotten yanked out of messes and used my winch at least a dozen times since I've had it mounted on there. The bumper itself it two pieces and the part mounted to the frame has always been stout, however the front part of the bumper, the bolts would loosen occasionally and it would sag.
    I was getting ready last night to go out into the snow today and noticed the bumper was sagging again, so I went in to tighten up the bolts and realized I have broken the front mounts. One has already let go, the other one is cracked about 1/2 way, I was basically riding on borrowed time.
    I was going to just cut them off, weld a new plate onto the front, box it in on the top and bottom, and then just put the bumper back on however before I start cutting (and fucking) things up, I thought I would see what the fine folks on here thought.
    Options?
    NoOne likes this.
  2. Nov 30, 2024 at 1:51 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    A lot of people weld on plates like your thinking with gussets to strengthen. You’re on the right track. It’s def a weak point considering how we use it. Do you have any additional braces or just the front mounts? A lot of bumpers will sell you a brace to help keep it on.
  3. Nov 30, 2024 at 2:44 PM
    longhairedhippy
    Ray
    Seattle, WA
    2019 MGM TRD OR SB
    Unfortunately no. I didn't know what I was doing and just went for one of the cheapest bumpers I could fit a light and winch, and I believe I have gotten what I paid for. It just bolted straight to the factory mounts, using the existing bolts and nuts. In hindsight, I think it was meant to be more decorative than functional, as it's taken some work to get it functional.
    NoOne and Chew like this.
  4. Nov 30, 2024 at 6:40 PM
    BOZOJUICE
    BOZOJUICE Well-Known Member
    2016 dclb offroad 4x4 MGMSOLD/2023 ICE CAP PRO
    Maybe the RCI or C4 fab support mounts can fix that issue. Good Luck PaL
    NoOne and longhairedhippy[OP] like this.
  5. Dec 1, 2024 at 9:47 AM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    That’s exactly the problem with the low end bumpers.
  6. Dec 1, 2024 at 9:54 AM
    Tacosauro
    Tacosauro Well-Known Member
    23 SR5 V6 & 24 TRD OR
    roof rack
    After market bumpers are garbage, Chinese steel. Only actual after market bumper is ARB Bumper. ( Which is why, Toyota actually does use it on 4th gen tacoma )
    I would sandblast that rust off before it spreads inside the frame.
    Even the other side seems to be cracking up.. Unsafe to mount anything on that.
    Take it to welder and see what they say, they will need to cut that off I am sure, because of cracks
    longhairedhippy[OP] likes this.
  7. Dec 1, 2024 at 11:46 AM
    longhairedhippy
    Ray
    Seattle, WA
    2019 MGM TRD OR SB
    Unfortunately when I started off with this truck, I had more money than sense :D
    NoOne and helix66[QUOTED] like this.
  8. Dec 1, 2024 at 11:48 AM
    longhairedhippy
    Ray
    Seattle, WA
    2019 MGM TRD OR SB
    Yeah, I'm going to replace both sides, the side that hasn't completely broken off so far is cracked halfway down. I'm just glad I found this in the garage instead of staring at my bumper laying on the ground out on the trail.
    NoOne, LOLLY and helix66 like this.
  9. Dec 1, 2024 at 11:52 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    There are various frame to bumper reinforcements. The picture is BAMF
  10. Dec 1, 2024 at 1:30 PM
    dezert.taco
    dezert.taco Well-Known Member
    Nate
    Northern Nevada
    2018 Tacoma
    longhairedhippy[OP] and LOLLY like this.
  11. Dec 1, 2024 at 1:32 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
  12. Dec 1, 2024 at 2:53 PM
    helix66
    DPRC
    2017 DclB TRDor MgM
    Pretty sure you mentioned about welding, at least you have that ability and skill to make it better!
  13. Dec 1, 2024 at 3:08 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    In addition to replacing the cracked plates, maybe you could modify the bumper to mount the way I designed my 2nd gen hidden winch mount. I cut the holes in the frame horn plates to accept a steel tab to the inside of the tube frame, with a 5/8” bolt into that tab through the existing hole in the frame.
    The first pic and fourth pic here show what I mean, look closely for the bolt in the fourth pic:
    https://www.tacomaworld.com/threads/landphil-05-11-hidden-winch-mount.354527/
  14. Dec 1, 2024 at 3:12 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
  15. Dec 1, 2024 at 5:20 PM
    Ricardo13x
    Upland, CA.
  16. Dec 1, 2024 at 9:35 PM
    longhairedhippy
    Ray
    Seattle, WA
    2019 MGM TRD OR SB
    That looks amazing! Definitely a lot to chew on there, I am certainly going to borrow some of your ideas. I especially like the stealth D-rings and the additional braces underneath. Fantastic job!
    landphil[QUOTED] likes this.
  17. Dec 1, 2024 at 9:50 PM
    longhairedhippy
    Ray
    Seattle, WA
    2019 MGM TRD OR SB
    It quickly became clear, either learn to weld or go broke. I don't know what I'm doing so I've broken a lot of stuff. I'm not sure about skill and ability, but I've certainly got a welder and lack of caution!
    helix66[QUOTED] likes this.
  18. Dec 2, 2024 at 7:00 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Great to see the clear pictures of the failure. I’ve seen many bumper mounts bent but not broken.
    Before I did my winch work I found this company’s solution:
    https://www.rockhoundoffroad.com/product-page/tacoma-bumper-reinforcement-bracket-16-current
    I used this as inspiration for my mount replacement, however if I were to do it again I would go the route it the link first brought up in post #11:
    https://overlandoutfitters.ca/produ...reinforcement-kit?_pos=1&_sid=1f6bff504&_ss=r
    My pictures: my material is 1/4”.
    soggyBottom likes this.
  19. Dec 2, 2024 at 8:27 PM
    longhairedhippy
    Ray
    Seattle, WA
    2019 MGM TRD OR SB
    Damn, that thing is stout! I've gotten the mounts replaced at this point and the paint is drying. I ended up ordering a set of the RCI braces, which I hope will get me a little further down the road. If this breaks, I am certainly going with your setup.
  20. Dec 2, 2024 at 8:35 PM
    soggyBottom
    soggyBottom Well-Known Member
