Broken drivers side windshield wiper help...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AlexW, Apr 30, 2017.
  1. Apr 30, 2017 at 11:36 PM
    AlexW
    AlexW [OP] RLTW
    Alex
    Yeah... so sometime this past winter my windshield wiper froze to my windshield, I tried to turn it on and crack... and now the drivers side blade doesn't work/move(although the passenger side still works). I made due for the rest of the winter.
    Fast forward to now, summer time, its beginning to rain now and then, and I need it fixed. Anyone else have this problem and/or know the solution? I don't even know where to begin to replace the motor for the wipers. And theres no way I'm taking it to a dealer....
    Please help!
    08 Tacoma TRD Sport 4x4
  2. Apr 30, 2017 at 11:42 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You need to replace the arm. There are splines inside the arm and splines on the shaft of the wiper post. The arm splines are made of a softer metal and strip out. Its designed that way on purpose.
    All you need is a screw driver to pop off the cap and 10 mm socket wrench to remove the nut and then wiggle the arm to free it from the post. New arm install is the opposite procedure.
    Call the dealer and find out what they get for a a new arm. I guarantee they have them in stock. This is a common repair for snow/ice states.
    nobescare and AlexW[OP] like this.
  3. Apr 30, 2017 at 11:46 PM
    AlexW
    AlexW [OP] RLTW
    Alex
    You remind me why this website is so great. Thanks for the tip ill let the world know how it goes. I'm sure people are really dying to read this thread.
    nobescare and koditten[QUOTED] like this.
  4. May 1, 2017 at 5:38 AM
    Devlop
    Devlop Well-Known Member
    Grand Junction, CO
    2023 Tacoma Offroad
    You may want to try tightening the nut first. Snugging it up might help it sit tight on the spline again, that could save you some time and money.
    TRDSport10 likes this.
  5. Feb 24, 2021 at 9:08 AM
    Rain_man
    Rain_man Member
    Monterey, MA
    2007 4x4 2.7 manual
    Bilstein | OME RTR 2885 Icon AAL 51100
    THANK YOU for this. Saved me $30-40! Nut was loose, gave it a few turns. Mine was 14mm but no biggie.
    TRDSport10 and koditten like this.
  6. Feb 24, 2021 at 12:23 PM
    ozarkie
    ozarkie Member
    Arkansas
    2005 Tacoma Access Cab 4x4
    Next time freezing wet weather is forecast, be proactive and flip your wiper arms up. Saves a lot of grief later.
  7. Feb 24, 2021 at 9:22 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Good job O.P.
  8. Feb 24, 2021 at 10:02 PM
    Waasheem
    Waasheem
    2007 xrunner
    I had one, instead of going 3 o’clock to 11, it would go 2 to 12. I took the arm off, out poured a bunch of metal powder. A new arm fixed it.
    whatstcp likes this.
