Broken door handle
Discussion in '1st Gen. Tacomas (1995-2004)' started by labrador01, Dec 6, 2017.
  1. Dec 6, 2017 at 8:27 AM
    labrador01
    labrador01 [OP] Well-Known Member
    Kyle
    Northern IL
    2015 Tacoma
  2. Dec 6, 2017 at 8:53 AM
    Glamisman
    Glamisman Well-Known Member
    I think that is how Toyota designed the unlock feature... if you had a key FOB it would take 2 clicks to do the same thing. As to the outside door handle breaking, it broke at where the lever and rod attach. This is a weakness of the design but it can be mitigated... there is so much resistance built up in the latch mechanism from old hard grease, dirt etc that needs to be cleaned out an relubed... it takes may 1/2 hout to take the latch out and clean it and out it back. if you do do this it should take 1 finger on the outside latch to open the door when you are done.
  3. Dec 6, 2017 at 9:30 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Your handle broke, or the door lock mechanism? They are two different things. If just your handle broke, you replace just the handle. Not the lock. Everything would work the same.
    Edit: Also was going through door handles like it was going out of style. Eventually cleaned the lock mechanisms themselves, as well as handles and anywhere else using pressurized windex. Then silicone grease. door handles are like butter now.
  4. Dec 6, 2017 at 10:41 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    As stated above, definitely clean the latch mechanism! If you don't, you will break the new handle in short order. First cold day, the old greese will be extra stiff and the plastic in the handle extra brittle, and snap. The OEM handles are tougher than the after market ones, but they will still break if you don't clean the latch.
  5. Dec 6, 2017 at 1:15 PM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    I think I have gone through 4-5 door handles over the past 17 years. I'm a pro at replacing them now. Definitely clean the mechanism out real good to keep it from gumming up on you.
  6. Dec 6, 2017 at 9:26 PM
    donlogan
    donlogan Well-Known Member
    My finger has a calcified spot from where I've been opening up my broken door handle for the past year. I should probably sandpaper down the jagged edges.
    cruxofthebisquit likes this.
  7. Dec 7, 2017 at 3:53 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    I can't get my head around what this means. Help me out?
  8. Dec 7, 2017 at 7:52 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Haha certainly, I sprayed the piss out of the electric locks with windex. Probably not the smartest things, but you cannot take them apart so I gambled. Anyhoo, I sprayed a ton in there and subsequently using an air hose blasted 160psi in as well pushing the windex through. What came out was black windex. I went until it was clean.
  9. Dec 7, 2017 at 7:30 PM
    tacotuesday128
    tacotuesday128 Active Member
    Aaron
    2000 tacoma prerunner
    I broke my drivers side door handle, I never fixed it and spent the past year and a half climbing in through the passenger side haha
  10. Dec 7, 2017 at 7:34 PM
    01GreenTacoma
    Dear lord fix that door!!
  11. Dec 7, 2017 at 7:42 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    One of these days, you'll all of a sudden find that you've gotten too old to do that, you can fix it then.
  12. Dec 7, 2017 at 7:48 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    My Drivers side just broke today. Passenger broke 6 months ago. seems like a trend.
  13. Dec 7, 2017 at 7:54 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Can you do this with the door panel removed? How to do this? My passenger side handle is kinda stiff.
  14. Dec 7, 2017 at 7:56 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    I also have poverty spec so I insert key into lock to open
    Embarrassing people staring at me
    Whatever
    Hat said all my handles are 17 year old OEm
    I can feel my driver side will break
    As long as it stays intact till next owner takes it over
  15. Dec 7, 2017 at 8:34 PM
    Gyrkin
    Wyoming
    I took the latch mechanism out to clean it. You do have to unbolt the bottom of the window channel to get it out, but it's not too tough.
  16. Dec 7, 2017 at 10:29 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Do you think I could get away with a squirt of Silicone?
  17. Dec 8, 2017 at 9:12 AM
    Gyrkin
    Wyoming
    I doubt it. I tried blasting the latch mechanism with brake cleaner and then lubed it, all with it still installed. Put a new handle on, and less than six months later the new handle broke. Second time I took the latch out and cleaned it good. The door now opens with just my little finger easily lifting the handle. It's really not very hard to remove.
  18. Dec 8, 2017 at 10:27 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Are there any places I can look at instructions? I might do this since my door panel is off anyways
  19. Dec 8, 2017 at 10:38 AM
    Gyrkin
    Wyoming
    I don't know of any, but there are probably some out there somewhere in internet land. It was pretty easy to get unbolted, but couldn't actually get it out until I took the bottom bolt on the window track out. This allowed the bottom of the window track to move enough to get the latch out. The rubber part that is in the track kept it in line at the top, so it went back together easy.
  20. Dec 8, 2017 at 10:49 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I was just about to say this. Once I cleaned everything out and lubed it all up you can open the door with one finger.
