Broken crankshaft key leads to tear down and timing service
Discussion in '2nd Gen. Tacomas (2005-2015)' started by p16, Feb 12, 2024.
  1. Feb 12, 2024 at 4:47 PM
    TacoTuesday1
    FL
    I mean it’s already fucked. So if a jury rig fix gets it to last another 100k to prolong invasive R&R that’s a win.
    Just googled broken crank key repair to see what people do, with the crank in or out.
    Apparently one guy used adhesive like so:
    Consider this. Many vehicles nowadays aren’t even spotwelding the body together any more. They use high strength adhesive.
    replace crank would probably cost more than throwing in a used motor.
    places do weld repair. But that is on expensive race car motors where it is worth it and the engine is taken out and apart on a bench for welding and precise machining.
    p16[OP] likes this.
  2. Feb 12, 2024 at 4:50 PM
    p16
    p16 [OP] Well-Known Member
    2005 Tacoma V6 4.0 L 4x4
  3. Feb 12, 2024 at 4:51 PM
    TacoTuesday1
    FL
    there may be other ways. For example woodruff key.
    groove cut into the shaft
    Groove cut into the pulley
    Piece of metal matching them
    what would they do in Africa or India
    Torspd, p16[OP] and GilbertOz like this.
  4. Feb 12, 2024 at 4:53 PM
    p16
    I’m not familiar with this method I’ll have to look into it. Thank you everyone so far for all the help. Yk you’re fucked when this many people respond this quick on the forum
    Steve Berman likes this.
  5. Feb 12, 2024 at 4:54 PM
    TacoTuesday1
    FL
    what if this forces you to swap in a:
    -GM V8
    -Toyota/Lexus V8
    -diesel
    beater old P71 for around a grand to get around in the meantime could be an option
    that front timing cover looks leaky and in need of a reseal anyway at that miles
    consider this. Any other car front timing cover would already be leaking by 100k.
    I guess this is the one single thing Audi/VW may have gotten right on the 2.0T.
    full surface triangular key system on a replaceable sprocket
  6. Feb 12, 2024 at 4:56 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    At least you caught it before it completely failed. Not sure what happens when the key on a crankshaft breaks off and the crankshaft pulley no longer spins. At a minimum the water pump & cooling fan stop and coolant temperature starts to skyrocket.
    I would guess it's the kind of thing you can hear immediately and would then pull over within 5-10 seconds to investigate. If you were just driving along & didn't hear it let go or ignored the change in engine sound (maybe loud music playing or something,) you would cook the engine in a very short period of time from zero coolant flow.
    But anyway, none of that happened because you caught it before the pulley and/or crankshaft keyway broke entirely.
    p16[QUOTED][OP] likes this.
  7. Feb 12, 2024 at 4:57 PM
    p16
    Idk man best outcome for me right now is spending the least amount of money I can. I don’t really understand how the woodruff key works.
  8. Feb 12, 2024 at 4:57 PM
    bfonic
    bfonic Well-Known Member
    2023tacoma
    Maybe drill in from the front and tap a steel pin in
    TacoTuesday1 and p16[OP] like this.
  9. Feb 12, 2024 at 4:58 PM
    Finbox
    Finbox Well-Known Member
    Tim
    15' access cab 4x4
    A used engine would be better than just fixing the crank, just the crank on one with 230k on seems like waiting for other problems. If funds are short - just get a new pully and put it on, call it good enough.
    Steves104x4 and p16[OP] like this.
  10. Feb 12, 2024 at 4:59 PM
    p16
    I’m still wondering if tightening down the crankshaft bolt tight enough with thread lock on it could be good enough? Does the crankshaft spin in a direction that would unscrew the bolt over time?
  11. Feb 12, 2024 at 5:00 PM
    GilbertOz
    GilbertOz Driver
    CA
    This is actually possibly not too bad an idea if your budget is tight or you're not trying to keep the truck forever. Being sure to use threadlocker Red, whatever the speciality ultra-high temperature stuff is. Idk, it's possible that might hold for the long term?
    p16[OP] likes this.
  12. Feb 12, 2024 at 5:03 PM
    TacoTuesday1
    FL
    yes. If there’s a second intact key that would let the pulley sit on right stationary (engine off). Bolt tight
    Hole of the right size drilled
    A pin would be easy to find
    Big enough size chosen
    And the single drill hole would match the crank and pulley
    question is how to drill perfectly straight and how much room there is
    Another option. Slap on a new pulley. And weld it to the crank from the outside if possible before putting the bolt. Might have to grind it flush. But that would make taking it off again in another 200k+ a shitshow. Which may not matter. Or gluing the new damper on.
    A weld bead run around the whole diameter gap in a circle might work.
    or loctite supposedly has an adhesive that requires an extreme amount of heat to loosen again in the future. ie Torch, that 210deg of motor running shouldn’t mess with. Probably normally used on turbos that can get up to 1000deg.
    Jakerou and p16[OP] like this.
  13. Feb 12, 2024 at 5:06 PM
    TacoTuesday1
    FL
    That would just be a risk of doing less instead of more
    because the pulley is going to be up against
    -torque and rotation of the motor spinning during starting and running
    -resistance fighting against having to spin the accessories
    -constantly exposed to heat and cold, expanding and contracting
    -natural vibration of the motor running
    Every now and then there’s used cheap 1GR-FEs for sale on whatever classifieds with owner claiming it to have some other issue, that could be a cheap donor to pull parts from
    But that’s still:
    -invasive work
    -full status of donor motor not 100% known
  14. Feb 12, 2024 at 5:12 PM
    TacoTuesday1
    FL
    side note
    Is anyone else getting paranoid now about ordering a new damper to replace theirs and deal with the PITA of doing that
    Maybe it’s not too involved.
    -remove fan shroud
    -remove fan
    -remove serp belt
    -replace crank bolt with new during job
    RockAuto is cheaper than $200 dealer
    But these pics and brand names don’t exactly look quality or OEM supplier brand…
    Never heard of ATP (doesn’t even have pic) or Pioneer
    Dorman is bad reputation
    I have SKP spindles
    Dayco might be Autozone type shit and the pic of it shows it not looking how it’s supposed to look
    FWIW FluidAmpr told me they have a non Tacoma pulley that is similar enough it might be able to be made to fit
    Which if so would be better than OE
    PN 571101
    But based on pics 1GR has 6 ribs
    571101 appears to have 5.
    would be awesome if another model ATI SuperDamper or FluidAmpr fits
    The 2JZ one appears to also have a keyway slot and be 6 ribs.
    Not sure if the diameters and offset spacing dimensions are the same. But they should list all that info online. And stock damper can have measurements taken.
    Theres other shit I don’t know about
    Like this
    ATI drill kit
    ATI keyway spacers
    Both of which could also be made by a machine shop given specs
    p16[OP] likes this.
  15. Feb 12, 2024 at 5:18 PM
    #35
    GilbertOz
    GilbertOz Driver
    CA
    Yes, the hard part is if it's possible to get in there & drill the hole, and drill it straight. Probably not.
    If you go this route I would strongly recommend using an OEM/genuine Toyota replacement pulley. If you weld it on you don't want to have to try it get it off again any time soon.
    How about this: carefully file some very gentle linear grooves all around the crankshaft circumference, like 60 or 80 of them, sort of like splines, but just little shallow roughening grooves. Then file similar grooves on the inside of the brand-new pulley. Then use the special high-temperature (search for it, don't just use ordinary Locktite Red) thread locker. The grooves on both surfaces would give surface area for the thread locker to work against and lock into.
    p16[OP] likes this.
  16. Feb 12, 2024 at 5:18 PM
    #36
    p16
    I was looking at a diagram from a past thread and saw this. Are the keys removable from the crankshaft? Or are they one solid piece with shaft?
  17. Feb 12, 2024 at 5:30 PM
    #37
    TacoTuesday1
    FL
    you better hope that’s the case and that the pic above is from a 1GR. Because if so that would be good news.
    And exactly how some other engines are made.
    why? Because it would mean what is damaged is a replaceable sprocket and not the crank. But a sprocket that sits on the crank.
    Just more involved to replace.
    -timing cover remove
    -timing chains remove
    not impossible if you follow the repair manual.
    supposedly it is its own piece sprocket.
    https://www.purefjcruiser.com/docs/2007 Toyota FJ Cruiser Repair Manual/1GR-FE Engine Mechanical/Engine/0060013.pdf
    that would give you the opportunity to reseal the timing cover which looks like it needs anyway
    potential cam gears upgrade
    Verifying the engine is in time and retiming it
    Potentially replacing timing chain guides if they’re plastic and old
    don’t quote me on the PN
    Rule of thumb always verify PN’s, supercesions up to date, matching VIN within Toyota parts database
    but IF this is the part
    GilbertOz likes this.
  18. Feb 12, 2024 at 5:35 PM
    #38
    GilbertOz
    GilbertOz Driver
    CA
    Nice find. Verify 100% certain that it's from a 1GR-FE & proceed w/ further planning from there.
    It'd sure be nice if that's replaceable, one of those things where the engineers thought ahead to "what if the crank pulley gets jammed somehow, wouldn't it be nice to be able to replace the key if it gets damaged or sheared?"
    Also it's probably cheaper to manufacture, instead of machining in a full permanent key on the crankshaft, you just machine a little slot and insert a separate key piece during assembly.
  19. Feb 12, 2024 at 5:36 PM
    #39
    p16
    https://www.tacomaworld.com/threads/1gr-fe-crankshaft-question.664739/
    this is the thread I look at it seems so. Either way idk if I’m equipped to be doing the repair myself. Anyone with any past experience with this crankshaft and the keys? I know y’all were talking about someone specific earlier
  20. Feb 12, 2024 at 5:37 PM
    #40
    p16
