Broke off a skid plate bolt
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mrcheap, May 18, 2024.
  1. May 18, 2024 at 9:22 AM
    mrcheap
    mrcheap [OP] Well-Known Member
    Went to do an oil change this morning and snapped the head of one of the bolts off
    what’s the best way to remove the threaded end still attached to the car
    tried some pliers couldn’t get a good grip. Should I drill it out?
    thanks
  2. May 18, 2024 at 9:28 AM
    MilkDud
    MilkDud Well-Known Member
    2021 MT DCSB Off-Road
    If it were me, I'd drill it out
    kahanabob and Bob1971 like this.
  3. May 18, 2024 at 9:39 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Drill it and use a extractor.
    These are very good quality.
    TS4x4 and Bob1971 like this.
  4. May 18, 2024 at 10:27 AM
    turkeyslayer66
    turkeyslayer66 Well-Known Member
    mike
    22 AG Trd Sport
    Soak it down good with some penetrating oil after you drill it out. Maybe a little heating too, don't want to break the extractor off in bolt, that would be really miserable.Been down that road, ugh! Coat the threads on the new bolts with some good anti-seize, should help next time you have to remove it. Good luck, I hope you get it out with a minimum of trouble.
  5. May 18, 2024 at 10:42 AM
    mrcheap
    Will do!
  6. May 18, 2024 at 10:45 AM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Did you try a good set of vise-grips, or just regular pliers?
    I’d hit it with pb-blaster or whichever penetrant you have, see if the vise grips will work, if not then remove them and try a torch and the vise grips again.
    For me the drill and extractor is the last resort....an you'll want to get close to center as possible.
  7. May 18, 2024 at 10:48 AM
    mrcheap
    I sprayed some wd40 on it and I think it made it slippery for the pliers and vise grip
    I’ll try again later with the vise grip
  8. May 18, 2024 at 11:01 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    YES...I helped a friend, he broke 2 off. Drilled it using slightly smaller drill bit then the actual hole. The small pieces left inside came out with the help of a screw driver and threads were still good. Got new bolts at home depot
    Add a little grease when you put you back on.
    helix66 likes this.
  9. May 18, 2024 at 11:11 AM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    If it's like mine, the skid plate bolts to some pieces of metal that are easily removable with three large bolts. You could take that off and then have better access to work on it. It would be easy to weld a new nut on if you need to.
    akimmel likes this.
  10. May 18, 2024 at 3:20 PM
    tacoma warrior
    tacoma warrior Well-Known Member
    2020 Tacoma SR5 silver
    Same thing happen to me, I drilled the and use extractor tool to remove the
    I bought the bolts on ebay
    M3-M8 Socket Countersunk Screws 12.9 Steel/ Black Oxide Hex Allen Key Flat Bolts
  11. May 18, 2024 at 3:42 PM
    mrcheap
    Well I don’t have a good drill. Can I just buy this bracket? Any idea part number or name?
    thanks
  12. May 18, 2024 at 3:47 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I don't know man, the cost of that bracket from Toyota might shock you! I'm sure someone will chime in soon with a number.
  13. May 18, 2024 at 3:52 PM
    helix66
    DPRC
    2017 DclB TRDor MgM
    wd40 isn't the best penetrating oil, pb blaster, liquid wrench, kroil do a better job....since it's off try soaking the whole thing in whatever you have for a day or so and you can try the vise grips again.......locked on well and tap them to mimic an impact effect, leaning into it is the way thing break.
    Try a torch to heat up the area where it's threaded into and then the vise grips........use gloves and safety glasses!
    That plate is a splash guard, not a skid plate.
  14. May 18, 2024 at 4:02 PM
    mrcheap
  15. May 18, 2024 at 4:17 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Use an extraction kit should come out .
  16. May 18, 2024 at 4:55 PM
    Buck Henry
  17. May 18, 2024 at 6:09 PM
    joeyv141
    New Jersey
    Ohh shit I just assumed(stupid I know) that it was broken flush, you got at least 1/2 inch sticking out. Get yourself some pb blaster or equvilant and set of vice grips like these and you should be able to get that out no problem. Best ones I've used are Mac tools but I'm fairly certain that Irwin makes them for Mac, im sure knipex ones are also great. Clamp onto the bolt as tight as possible, turn it back and forth to break it loose.
    https://www.lowes.com/pd/IRWIN-Original-VISE-GRIP-10-in-Locking-Pliers/1003142346
    helix66 likes this.
  18. May 18, 2024 at 6:17 PM
    helix66
    DPRC
    2017 DclB TRDor MgM
    That’s what I said….
  19. May 18, 2024 at 6:44 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    File a flat surface on each side if it, that's if you have a file. then chanelocks on the flat surface and make sure you are turning it the correct way.
    T4R_hereforbearings likes this.
  20. May 18, 2024 at 6:55 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Get you a set of these. Drill a small pilot hole then line the drill bit up and drill away. The bottom part is a tap so it'll drill and tap all in one go and its super sharp so it'll melt through the bolt. I've done dozens of the stupid skid plate bolts like that.
    https://www.milwaukeetool.com/Products/48-89-4875
