Break In Period For Power Steering Fluid / Pump Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by glockner, Oct 29, 2018.
  1. Oct 29, 2018 at 2:34 PM
    glockner
    glockner [OP] Well-Known Member
    Scottsdale, AZ
    2006 Tacoma TRD Sport 4x4
    I, being a noob, put wrong power steering fluid in the other day which I thought was the cause of my super stiff steering that began happening right after. I took to dealer to have them flush the system, and they noticed the pump had failed as well. Just picked up and my steering is still pretty stiff, definitely not as bad as before, but still stiffer than it should be. Is there a break in period for new fluid and pump? Or could there be another issues such as intermediate steering shaft?
  2. Oct 29, 2018 at 3:13 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    what fluid did you put in it that was "the wrong stuff" and how long was it in for?
  3. Oct 29, 2018 at 3:20 PM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    Curious as well. I have a hard time seeing the "wrong" fluid ruining the pump unless it was 140w or similar.
  4. Oct 29, 2018 at 5:26 PM
    glockner
    Scottsdale, AZ
    I put just regular steering fluid in, not ATF. My steering seems to be back to normal now after driving it a while today. Must have just had to work itself in.
  5. Oct 29, 2018 at 5:30 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Is the pump still growling a little? It may just have an air pocket.
  6. Oct 29, 2018 at 5:32 PM
    glockner
    Scottsdale, AZ
    I don't think that was the cause of the pump failing, I think it just failed. But when I noticed the stiffness, I checked power steering fluid level and it was low so I topped off with regular power steering fluid, not ATF like it calls for. I obviously can't read.
  7. Oct 30, 2018 at 11:27 AM
    nd4spdbh
    SoCal
    eh you probably were fine, its a pretty simple hydraulic system and could probably run off vegetable oil haha.
    Glad things are better now though.
    b_r_o likes this.
