Brand New Generalspring Leaf Springs Sagging Bad
Discussion in '1st Gen. Tacomas (1995-2004)' started by VolcanoTacos, Oct 7, 2022.
  1. Oct 7, 2022 at 10:05 PM
    VolcanoTacos
    VolcanoTacos [OP] Well-Known Member
    This week I just recieved new standard duty Generalspring leaf springs for my 98 4x4 taco. After installing along with new shocks the back now sits ~1.5" shorter than the front (stock springs and height). As you can see from the pics the springs are sagging really bad and are bent up in the middle (also a weird kink in one of the springs. I have not put any load in the truck yet it's only been about 24 hours since install. I find it odd that both springs are sagging like this. These are WAY worse then the factory springs I replaced at 270k miles. Does anyone have any ideas or advice besides contacting them which I already have. Any other suggestions for a higher quality OEM replacement leaf?
    IMG_5546.jpg IMG_5558.jpg IMG_5560.jpg IMG_5565.jpg IMG_5566.jpg IMG_5568.jpg
  2. Oct 7, 2022 at 10:21 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Yeah I have the rwd Taco zero lift version.....and my leafs came from factory looking just like yours....no difference....
    well except for that kinky one.....
    I'll be doing rear fuel lines refresh tomorrow ......I'll snap a pic........
    That kink is your ticket for a RMA......
  3. Oct 7, 2022 at 10:35 PM
    VolcanoTacos
    Thanks! Yes, these are worse than the factory ones I had on a 3" spacer. I'm pretty frustrated and since both are like this I have serious doubts that a replacement would do anything. IMG_5386.jpg
  4. Oct 7, 2022 at 10:39 PM
    O'Silver_Taco
    MD
    A red neck fix would be put a helper leaf in there.....maybe longer rear shakles....maybe the adjustable ones...
  5. Oct 7, 2022 at 10:42 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Costs triple of what you paid, but I'm sure it's far better quality.
  6. Oct 7, 2022 at 10:46 PM
    O'Silver_Taco
    MD
    Was under the impression that the Generalspring leaf springs were meant for 4X2's......
  7. Oct 7, 2022 at 10:48 PM
    VolcanoTacos
    I did get the new shackles that General spring sales as well.
    I'm trying to restore the original ride height. the OME claims to have 2.25" increase in height.
    At least for the 98-00 model years they have both and also a Heavy Duty version: https://www.generalspringkc.com/leaf-springs/toyota/tacoma/1998-2000-toyota-tacoma-leaf-springs/
  8. Oct 7, 2022 at 11:09 PM
    O'Silver_Taco
    MD
    Mines the small 3 band one, and your 4 band one looks as weak as mine or worse...
  9. Oct 7, 2022 at 11:10 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    New u bolts, right?
    Could you post a pic with the shackles in view?
  10. Oct 7, 2022 at 11:17 PM
    O'Silver_Taco
    MD
    To qualify for a refund, you must make sure we receive the returned order within 30 days of purchase.
  11. Oct 7, 2022 at 11:31 PM
    VolcanoTacos
    Yes new shackles and U-bolts from GS. Here you go.
    Area51Runner[QUOTED] likes this.
  12. Oct 7, 2022 at 11:35 PM
    Area51Runner
    :thumbsup:
    Looks good, except for this -
    Reach out to them and see what they can do. Sucks, sorry to see this.
    MalinoisDad likes this.
  13. Oct 7, 2022 at 11:46 PM
    O'Silver_Taco
    MD
    So does that mean if you get longer shackles.....you ride around on two W's.....
  14. Oct 7, 2022 at 11:48 PM
    VolcanoTacos
    I did, I will update the thread with what they say. The thing that is most concerning as I said before is that they are both doing it. It would make more since as a one off issue if only one were sagging like this. They are also squeaking when I get in/out of the truck.
    Does anyone else know any OEM height spring options?
  15. Oct 7, 2022 at 11:53 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    I think husky spring makes some
  16. Oct 7, 2022 at 11:56 PM
    Speedytech7
  17. Oct 8, 2022 at 12:19 AM
    VolcanoTacos
  18. Oct 8, 2022 at 2:37 PM
    O'Silver_Taco
    MD
    With the flaw you got a get out a jail free card....
    ....i'd send them back ......shouldnt have to buy a helper leaf when brandnew......what happens 5 years later....
    And then start a new thread poling whats worked for leaf upgrades......no shortage of advice.....this and wheels......biggest passion play here.......
    Might even luck out and find someone who has an extra uninstalled set.....
  19. Oct 8, 2022 at 6:03 PM
    andywear
    andywear Active Member
    Tulsa, OK
    '99 TRD manual
    of course I find this thread after I buy my GS.
    any update from the MFG?
  20. Oct 8, 2022 at 6:56 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
