Braking turns my wheel to the right
Discussion in '1st Gen. Tacomas (1995-2004)' started by Caslon, Nov 12, 2022.
  1. Nov 12, 2022 at 11:18 PM
    Caslon
    Caslon [OP] Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    What might it be if it happens intermittently more and more, but not every brake stop? Calipers acting up? I think I have at least one more year on a brake job. Wheel turns to the right when breaking to a stop. Not every time tho. More and more tho.
  2. Nov 13, 2022 at 12:50 AM
    NickFox
    NickFox Active Member
    Nick
    2019 Tacoma TRD Off Road
    Stock
    Could be a good amount of things.. caliper piston getting stuck, air in the brake system, slides not properly greased, unevenly worn pads, a clog in one of the lines etc. Your gonna have to pull a tire and take a peek, I'd start with the side it's being pulled towards.
    vern650 likes this.
  3. Nov 13, 2022 at 7:27 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It could very easily be the grade of the road.
    Does the wheel pull to the right so hard it pulls out of your hands ??
    This is on severe brake applications or slow soft brake applications ?
    Left side caliper is hanging up the right is doing the only braking pulling to the right.
  4. Nov 13, 2022 at 10:03 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    How's your camber and toe in front?
  5. Nov 13, 2022 at 10:38 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Check the bushing in your steering rack and your lower control arm bushings.. with intermittent failure like that my money is on steering rack bushings
  6. Nov 13, 2022 at 11:36 AM
    Caslon
    Hold on! Lol! Can a good brake shop determine what causes that?
    Abeyancer likes this.
  7. Nov 13, 2022 at 11:55 AM
    Abeyancer
    Jimmie
    PNW
    Yes they could if you specifically asked them to inspect that.
    You can also inspect it yourself fairly easy if you have a second person.. one of you in the truck turning the wheel left to right and the other looking under the truck at the steering rack. If there is ANY play in the rack when the wheel is being turned, you'll need new bushings
    With the LCA bushings, just take a prybar between the arm and where the arm attaches to the frame. If you see the arm shift more than 1mm, you'll need new bushings
  8. Nov 14, 2022 at 9:45 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    There is ALWAYS play in the rack/bushing interaction. That's the point of a bushing- to soak up that difference.
    I am not saying that excessive play isn't possible, but if you're expecting brand new bushings to hold the rack in an absolute position, then you're incorrect. It would be hard to put a measurement on what is acceptable or not. But to say that "ANY" play is out of spec is a far cry from reality.
    Bivouac and Abeyancer[QUOTED] like this.
  9. Nov 14, 2022 at 9:58 PM
    Abeyancer
    Jimmie
    PNW
    Fair enough, that's a valid point.
    @Caslon if you're able to get noticeable movements in your steering wheel before the wheels actually start to turn, the the bushings are bad.
  10. Nov 19, 2022 at 4:41 PM
    Caslon
    1/2” at the most. Even then, there’s firm tension. How about a slowly wearing out caliper? Being that it’s fairly intermittent is a bit puzzling. Can a garage test for a partially failing caliper?
  11. Nov 20, 2022 at 9:13 AM
    lookatitgo156
    lookatitgo156 New Member
    long island ny
    I am dealing with the same problem and I know it is because the front LCA bushing is worn.
    I can move it with a pry bar- I know the braking force will move that wheel out of alignment, pulling truck to right.
  12. Nov 20, 2022 at 9:36 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    i dealt with this for years... braking would turn steering wheel and was most noticeable with ruts in pavement. After a suspension upgrade got a new alignment and the problem disappeared.
  13. Nov 21, 2022 at 6:41 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    If it's a caliper remember it's the one opposite of the pull. Mine was doing the same thing intermittently then shortly thereafter the left caliper seized.
