Brakes stuck after washing the truck??????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BBBsti LTD, Oct 26, 2010.
  1. Oct 26, 2010 at 3:51 PM
    BBBsti LTD
    BBBsti LTD [OP] Well-Known Member
    Irvine, CA
    2010 TRD Off Road 4WD
    Today I washed my 2010 TRD/OR 4x4. I washed the truck at a pressure DIY carwash. After that I moved the truck to dry it up and then after 20 min,
    I put the truck in drive and move like 7 feet and stopped for like 5 sec. to put something away (still in drive) and when released the brake the truck was like if it had the parking brake engaged, but it was not. I gave it a little bit of gas and the truck made a clunk noise and abruptly move forward after that it was perfectly normal and I could not replicate it.
    I washed the inner fenders of the truck and pressure washed the wheels from the outside of the wheels no water from the differential area.
    Any ideas?? I know Toyota brakes get touchy when wet but I have never seen this.
  2. Oct 26, 2010 at 3:53 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    there's been multiple posts about this happening. I dont think a real reason was found. But the theory is the water "freezes" the brakes and giving it a little extra gas will free it.
  3. Oct 26, 2010 at 4:03 PM
    BBBsti LTD
    Irvine, CA
    Thaks for the quick reply, I saw the post but this happened today in Socaltrailriders with a 70ish weather.
  4. Oct 26, 2010 at 4:06 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    It happen to me also, I washed it and let It on the driveway overnight, the next morning it won't move.
  5. Oct 26, 2010 at 4:07 PM
    xroller
    xroller Blowin by em sideways
    X-roller
    Albuquerque New Mexico
    2006 Toyota Tacoma Xrunner Speedway Blue
    1 hp mod
    hmmm.... the only thing that may do that is be e-brake cable... maybe it was jammed and then since you gave it that gas it broke it loose...
  6. Oct 26, 2010 at 4:08 PM
    xroller
    X-roller
    1 hp mod
    did you use the e-brake?
  7. Oct 26, 2010 at 5:54 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    I used it, it was engaged when parked but it was released and still didn't moved.
  8. Oct 26, 2010 at 6:22 PM
    xroller
    X-roller
    1 hp mod
    It's probably the e-brake cable. Seems like it's faulty on newer models. I would recommend taking it to toyota and see what they say if you are still under warranty. I'm sure they have quite a few complaints on it seeing we have seen this a few times already.
  9. Oct 26, 2010 at 7:54 PM
    BBBsti LTD
    Irvine, CA
    Seems like it happens quite frequently to Toyota Tacoma owners, even to some Tundra owners too, and most of the time water is involved.
  10. Oct 26, 2010 at 10:24 PM
    pinktaco808
    pinktaco808 Hot Steppa
    talk about problems
  11. Oct 27, 2010 at 1:47 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    The exact same happened to me last winter during a rain/snow storm.
    I think the drums got stuck on it.
    I ony way I got them unstuck was putting my truck in 4Lo
  12. Oct 27, 2010 at 8:21 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    LOL, so much for unintended acceleration...
  13. Oct 27, 2010 at 9:26 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    yes welcome to car ownership... this used to be very common... it may speak to low quality steel...
  14. Oct 27, 2010 at 5:27 PM
    spp
    spp OC, Kalifornia
    OC California
    The left rear locked up on me once when I just washed it and put it in the Garage overnight. Drug the tire a foot and stopped because of the noise.
    Put it in reverse and the drum unfroze.
    I think it rusts a little and being a new truck the tolerances were still tight.
    I drive the truck a little after washing now and never happened again.
  15. Oct 28, 2010 at 6:37 AM
    pinktaco808
    gptta cjange the rotor to aftermarket any suggestions????
  16. Nov 10, 2010 at 4:48 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Well, just had this happen to me this morning when I went to leave for work. After searching for a few mins, seems like this has happened to alot of people. Yesterday got home from work, washed the truck and dried it off same way I have always done. So maybe 20 mins after I'm done my wife came home and I moved the truck so she can park in the driveway and I park the truck for the night. This morning I start the truck grab a quick smoke while it warms up for a few mins and melt the frost off the windsheild, I get in and take off the parking brake and put it in drive and it will not move! I have had the e-brake stick a little before, but never this bad. I kept hitting the e-brake petal on and off and still would go. Went from D to R, In drive gave it alot of gas to try to break it free, moved a little and then I started laying tire!! Got out of the truck, said a few choice words and got back in. All of a sudden it broke free and I was on my way to work, a few mins late. So thats the fix. She must be a little moody in the morning specially after being wet, you just have to swear at her to make her move!
  17. Nov 10, 2010 at 5:21 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    This is why I always drive any vehicle at least a mile after washing it.
  18. Nov 10, 2010 at 5:27 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Thats a good idea. Think I might start to do that.
  19. Nov 10, 2010 at 10:03 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    it also has something to do with the crappy oem brake shoes in the rear. Mine would lock up after moisture gets in there. And if it doesn't lock, it squeals. I changed to Wagner thermoquiet brake shoes and I don't experience any of that anymore
  20. Oct 14, 2016 at 8:12 AM
    Scrat
    Scrat GRYLNG
    Jacob
    Woodland Park
    V6 SR5 '15
    ARE CX Topper, Yakima rails with various accessories, Bilstein 5100, Icon RXT, OME 886 coils, Firestone Ride-Rite, 265/75/16 KO2, Mobtown Offroad Rear Bumper., Diode Dynamic map and dome lights, headlight harness, Cali-raised bed stiffeners, Cali Raised accessory bed mount, Cobra 75wx st, Leixen VV898e, Safari Snorkel, SOS Sliders, CBI Full skids pack, and more coming!
    I was pulling my friends VW out of some water (Mathew flooding in VA Beach) and I was in reverse for a block. I had my brakes seize up about 4 times. Giving it some gas un-stuck them. Thanks for thread.
