Brakes Make Clicking Noise
Discussion in '4 Cylinder' started by delidad1, Aug 27, 2015.
  1. Aug 27, 2015 at 6:36 AM
    delidad1
    delidad1 [OP] New Member
    Rochester New York
    13 Access Cab SR5
    My 2012 Taco Access has started to make a clicking noise when I apply the brakes. Everything 'feels fine' when stopping, any ideas?​
    05Taco4x4 likes this.
  2. Aug 27, 2015 at 7:22 AM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    Is it after changing directions or all the time?
    How many miles on truck?
    An audible click can be heard sometimes when changing directions and then stopping,
    think in reverse and you stop before going forward. It's the brake pads shifting in the
    caliper. Usually normal...
    Benny123 likes this.
  3. Sep 11, 2015 at 9:13 AM
    Spindifferent
    Spindifferent Well-Known Member
    Central Texas
    2013 PreRunner 4.0 v6
    I hear the same on my 2013. One click after the initial application of the brakes. Brakes seem to work fine.
  4. Sep 11, 2015 at 9:28 AM
    TRDrunner
    TRDrunner Well-Known Member
    Victor
    Vacaville
    2014 Tacoma TRD Offroad
    The "click" is just the brake pads shifting after sitting for so long. completely normal.
  5. Sep 15, 2015 at 9:06 AM
    EngineerMatty
    EngineerMatty Active Member
    2009 Silver Tacoma Access Cab 4x4 TRD
    My 2009 does this upon initial pressing after going forward or reverse. I can simulate this over and over in my driveway. The sound is a loud mechanical click or more like a clank. However the brakes work absolutely great on this vehicle.
  6. Mar 5, 2016 at 4:13 PM
    FLJB
    FLJB Well-Known Member
    J
    FL
    2020 4X4 Sport MT
    you can fix that relatively easily. You need to buy some Syl-glide or other brake approved silicone lubricant. Jack truck up and take off front wheels. Pull the two pins on the brake caliper and sand/wire brush or replace them its like $5 for the items each side, lube up and reinstall and the sound will go away. See pic of offending item. There is a cotter pin that locks this pin on the inside that needs to be removed, but pulling it out and reinserting it is easy and wont hurt anything else.
    ChadsPride and Benny123 like this.
  7. May 6, 2019 at 6:29 AM
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    Appreciate the tip. I think there are several reasons you can get brake clicking. I had 2.
    I lubed my slide pins in it stopped the smaller clicking noise. On further inspection I did see a slight movement of the rotor on the hub studs. I get a noise from this only when changing directions, forward to reverse or vice versa, on the first brake only. I think the louder clank is coming from this slight rotor movement.
    The rotors are otherwise good. However I suspect this would improve when I ultimately change my rotors out.
  8. May 6, 2019 at 8:33 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    OP start paying attention to when it happens and I bet you'll notice it's usually in parking lots of driveways where you have recently changed from forward to reverse or vice versa. As many people have said it's totally normal and is just the pads shifting around in the calipers.
  9. May 6, 2019 at 12:12 PM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    My oem pads started doing this just as described above at maybe 20 k or so. I lived with it until about 50k and thinking they were due for replacement I installed new oem pads. Not a sound since and at 61k. The original pads still had lots of life left in them by the way. If you have aftermarket pads now, get oem from the dealer, install and enjoy quiet and dustless braking.
  10. Jun 1, 2019 at 7:37 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I get this sound in the rear
  11. Jun 3, 2019 at 6:27 AM
    Benny123
    Ben
    South Charlotte, NC
    Just to verify the fix, my clicking sound went away when I reapplied ceramic lube to the back of the brake pads today. Been bugging me for the past few months. I had already checked torque on calipers, torque on ucas and lcas, and lubed slide pins. Good luck all.
