Brakes coated with gear oil need full replacement?
Discussion in '1st Gen. Tacomas (1995-2004)' started by trashfire, Jan 30, 2019.
  1. Jan 30, 2019 at 9:36 PM
    trashfire
    trashfire [OP] Member
    1999 Tacoma TRD SR5
    just got a new rear axle seal installed at the shop today, there was a leak that got gear oil all over the brakes. the wheel bearing is apparently still fine. but they're telling me that the brakes on that side are going to need full replacement.. which means the other side has gotta go as well. can't you just take some brake cleaner and go to town on the shoe and drum? or do i have to drop the $400???
    OneWheelPeel and Nunya Bizness like this.
  2. Jan 30, 2019 at 9:53 PM
    Nunya Bizness
    In my mind a thorough cleaning would do the trick...
    But Im not a trained brake technician.
    Welcome to TW
  3. Jan 30, 2019 at 9:55 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Sounds like they’re trying to just charge you more. Hit it with some brake cleaner and degreaser. A little oil shouldn’t ruin the brakes.
    Edit: I stand corrected. I’d get a quote from another shop.
    wilcam47 and Nunya Bizness like this.
  4. Jan 30, 2019 at 9:55 PM
    Bishop84
    Bishop84 Well-Known Member
    The oil soaks into the metal of the drum and shoes.
    Also the bearings 100% should be replaced, they will sling oil onto the new shoes once replaced. Plus the new retainer gives the new seal a fresh surface to ride on. If you just change the seal the leak could return due to wear on the retainer.
    Sorry about your luck. Make sure to check your diff breather valve.
  5. Jan 30, 2019 at 10:31 PM
    trashfire
    1999 Tacoma TRD SR5
    thanks for the responses ya'll. looks like theres some difference of opinion here, others wanna weigh in???
  6. Jan 31, 2019 at 12:44 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If it was you doing the work I would say go for cleaning everything your only downside is pulling things apart again and changing the brakes when you still have brakes grabbing .
    If I have a job like this replacing a seal that has failed for a paying customer !! I will not take the chance unless they state to only clean the brakes and drums it gets put right on the work order .
    A business does not need a disgruntled customer coming back pulling things apart again what profit you made is gone.
  7. Jan 31, 2019 at 2:56 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    agreed. once that rear axle seal goes, the oil contaminates your brake shoes. Sucks when it happens but it needs to be done.
  8. Jan 31, 2019 at 3:00 AM
    abodyjoe
    abodyjoe Well-Known Member
    joe
    2017 Tacoma double cab TRD Offroad. quicksand in color
    Yes change the shoes. It’s a no brainer.
    tirediron likes this.
  9. Jan 31, 2019 at 6:20 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    $400 for rear brakes???
    :gossip: Buy new Genuine Toyota Parts shoes and install them yourself. You'll be glad you did, and you'll save over $200.
    tirediron and wilcam47 like this.
  10. Jan 31, 2019 at 10:01 AM
    shmabs
    shmabs Well-Known Member
    Because the friction material is porous, it tends to absorb oil. You may be able to get it "clean" but I would venture to guess that once its hot again, you'll get oil seeping out and braking performance will seriously degrade.
    I know it's $400 and money might be tight, but brakes are one of the more important things on your truck. As others have said, it may be worth looking into getting the parts and doing them yourself, some patience and a few cheaper drum brake tools go a long way.
    skeezix and wilcam47 like this.
  11. Jan 31, 2019 at 10:05 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Depends. You could clean them off but most people will say it won't help. I don't know if it matters all that much for the rears since they only do about 20-30% of your braking power. There's been times I've only cleaned off the drums with no issues, but it depends on how long the oil has had to soak into the shoe. Also they had to replace my drum shoes anyways because they screwed up the axle seal install the first time. So I got free shoes out of it.
    Moral of the story - if you have a shop replace your axle seals, keep an eye on it for a few months after. If you see gear oil getting slung around again, they need to fix it again, for free.
    Area51Runner and 2002Tacoma4x4 like this.
  12. Jan 31, 2019 at 10:08 AM
    shmabs
    I guess if the oil has only been on there a very short time, its possible that the pads didn't absorb much of it, but still.....brakes are rather important, why chance it?
    wilcam47 likes this.
  13. Jan 31, 2019 at 10:13 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    If the drums are ok just replace the shoes. You'd be able to get the oil off the drum but prob not the shoes if its been soaked too long.
  14. Jan 31, 2019 at 2:10 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    To change the rear seals you must press the bearing off, I would replace the bearing, seal and oring on both sides. I would also replace the friction and replace the axle breather on the diff, mine was plugged and caused both axle seals to fail. Just get some shoes from rock auto for 60 bucks, the labor on the seals and bearings is the expensive part
    Yotarunner54 likes this.
  15. Jan 31, 2019 at 2:14 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    So wait, the shop spilled oil on the brakes, and they want to charge YOU to replace them?
    F that.
    Or was the leak why you took it to the shop?
    That said, $400 seems steep. They aren't too hard to replace yourself. I can't comment (intelligently) on the bearing, but it makes sense that would fling oil on the new pads, too...
  16. Jan 31, 2019 at 2:20 PM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    I just did this on mine. The shoes are ruined but you can just hit the drums with brake cleaner. New shoes and mine work fine now.
  17. Jan 31, 2019 at 2:26 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Replace the brake shoes
  18. Jan 31, 2019 at 2:27 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Shoes are done for sure.
  19. Jan 31, 2019 at 2:48 PM
    trashfire
    1999 Tacoma TRD SR5
    thanks for all the replies ya'll. im a tacoma newbie but ill definitely be coming back to this forum for advice. whats the best brand of replacement shoes to buy???
  20. Jan 31, 2019 at 4:53 PM
    1997tacomav6
    Denver
    Just had a rear seal pop on me last month.
    It was because the breather valve was stuck shut with dirt.
    Shoes and drum were soaked with oil.
    You have to get new shoes because the pads will absorb the oil.
    The drum you need to have it turned because the metal absorbs the oil too.
    Get a new breather valve
    Need to replace the bearing when you do the seals both or you will
    be doing it again sooner than later
    Greg617 and Area51Runner like this.
