Brake Slap/clack noise..
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Danbeau111, Oct 29, 2021.
  1. Oct 29, 2021 at 8:26 AM
    Danbeau111
    Danbeau111 [OP] Member
    Dan
    2016 taco off road
    UCA/LCA/DSC upgrades, rear leaf, rear shock upgrade, LED, K&N, trim, bed mods
    Has anyone experience what i call 'Brake slap" when applying brakes upon 1st moving forward, or, in reverse, and apply brakes, hear a noticable "CLACK" noise from brakes...
    is this due to sliding calipers??
    EireBleuTacoma and Darksport like this.
  2. Oct 29, 2021 at 8:29 AM
    syswalla
    syswalla Knob
    5557 ft.
    2015 DCSB TRD OR
    The pins that hold the pads to the calipers are probably dry. You can grease them and the noise should go away. I did that, but eventually they started doing it again most likely because the grease was eventually worn or washed away.
  3. Oct 29, 2021 at 9:35 AM
    Darksport
    Darksport Well-Known Member
    Jake
    NE Ohio (Cleveland)
    2017 Black Tacoma TRD Sport 4x4
    33” BFG Ko2s,16” Method NV wheels, CMC, King 2.5 Remote Reservoir, Baja Kits UCAs
    Dude I have this and I hate it so much. Happens when I switch direction and is pretty loud. Kind of embarrassing. Hopefully syswalla is correct about the dry pins. I’ll try that after the rain dies down around here.
    Stocklocker likes this.
  4. Oct 29, 2021 at 9:46 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. It is the pads shifting in the caliper and there isn't much that you can do about it. If they were tight, they would drag on the rotors after you left off of the brake pedal.
    Skydvrr likes this.
  5. Oct 29, 2021 at 10:02 AM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    This is an easy fix....Install 2 sets of retainer clips on each side (top and bottom) your problem will be gone instantly. It's the same clip just turn it upside down and install. At least on 2nd gens anyway.
  6. Oct 29, 2021 at 10:16 AM
    Gen2Tacoma
    North East Atlanta
  7. Oct 29, 2021 at 10:17 AM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    hmm, never noticed this on my truck. but i probably will now. thanks...
  8. Oct 29, 2021 at 10:18 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Mine does this all the time. Everytime I leave my driveway. I back down the driveway, which biases the pads to the rear, and the first time I apply the brakes in the forward direction “slap….slap”. Super loud and annoying. Toyota says this is normal.
  9. Oct 29, 2021 at 10:21 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is for inboard / outboard rattling. Not the forward / rearward shift and noise, right?
    Skydvrr likes this.
  10. Oct 29, 2021 at 10:21 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Our Subaru does it. Heck, my bike will do it also.
    Stocklocker[QUOTED] likes this.
  11. Oct 29, 2021 at 10:22 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    This will happen as your brake pads wear. I installed new pads and rotors and so far the noise is gone.
    Junkhead likes this.
  12. Oct 29, 2021 at 10:46 AM
    Gen2Tacoma
    North East Atlanta
    tonered[QUOTED] likes this.
  13. Oct 29, 2021 at 10:49 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  14. Oct 29, 2021 at 10:52 AM
    Gen2Tacoma
    North East Atlanta
    I think it has worked for some and not others.....it's inexpensive and easy to do for possible elimination of the noise. It worked for me.
  15. Oct 29, 2021 at 10:55 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Heck yeah. That is the perfect price to experiment with.
    EireBleuTacoma likes this.
  16. Oct 29, 2021 at 4:19 PM
    Darksport
    Jake
    NE Ohio (Cleveland)
    Yeah well Toyota is smokin somethin weird cause 99% of cars I ride in don’t ever make that noise. Normal my ass
  17. Oct 29, 2021 at 4:40 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Mine does it too, especially noticeable by a cement wall, etc.
    Fits right in with the diesel engine sound of the injectors, fuel pump, vac pump -- or what ever the heck makes it sound that way...
    It hasn't missed a beat so I don't worry about it.
  18. Apr 19, 2023 at 5:56 PM
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    Does it kind of sound like a bad CV Axle pop? Trying to determine if what I’m hearing is brake slap. Drives me nuts!
  19. Apr 19, 2023 at 6:07 PM
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    I had a noticeable clink when applying the brakes...turns out the person who did my alignment a year and a half ago didn't tighten one of the lower control arm bolts so it was moving, took it a year and a half to work itself loose, all the other bolts were good and tight though...my steering wheel would turn when applying the brakes too. it didn't make any noise when I'd jump up and down on the side step or bounced the front end, had the truck raised up and it didn't wiggle when I pushed/pulled on the top/bottom or sides of the tire either...just when applying the brakes and only when moving forward
    most likely it's actually what others have recommended, but this is something that I literally just figured out and fixed so fresh on my mind. just something to check too. oh and our calipers don't slide at all, only the pistons move in and out (pushing the pads in, those clips help keep the pads off the rotor when brakes aren't applied) you can grease the pins too (just a coating, nothing excessive), you can also put a very small amount on the flat surface of the caliper the pads sit on, just make sure to not get any ON the pad or rotor, obviously. or just take the pads out and spray the hell out of the rotor with brake cleaner, scrub them really well, some dust could be preventing the pads from sliding easily
  20. Apr 19, 2023 at 7:40 PM
    Stocklocker
    17TRDORDCSBAT
    It’s just one loud “clack” as the pads slap back into place. It does not sound like a blown CV to me.
