Brake shudder immediately after tire rotation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wes_peebles, May 15, 2016.
  1. May 15, 2016 at 6:55 PM
    wes_peebles
    wes_peebles [OP] Member
    Wes
    2010 Tacoma PreRunner
    2010 Pre-runner Crew cab. New rotors and pads about a year ago. Brakes were smooth before I had Americas tire rebalance and rotate my tires, then immediately leaving their parking lot I felt a shudder/vibration only when braking above 50mph and I can feel the pulsating grab any mph below that.
    I have read about over tightening lugs causing this but also just read the Stop Tech article about how warped rotors are a myth...
    Has anyone else experienced this sudden shudder? And if so, will I be looking at new rotors or will a re-torque due the job? Thanks for the info!
  2. May 16, 2016 at 11:22 AM
    wes_peebles
    Wes
    Anybody?
  3. May 16, 2016 at 11:24 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Maybe they knocked off a wheel weight on accident?
    Arailt likes this.
  4. May 16, 2016 at 11:24 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I bet the wheel is not seated correctly or balance is off(some balance issues are more prevalent under braking). Take it back and tell them to fix it.
    bluezzy and scottalot like this.
  5. May 16, 2016 at 12:06 PM
    Berniebikes
    Berniebikes Well-Known Member
    Bernie
    Williamsburg, VA
    2015 White TRD OR Double Cab
    i'd put my money on either a wheel not seated or more than likely a warped brake rotor due to over tightening
  6. May 16, 2016 at 12:09 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    you do realize the stop tech article specifically states that when all bolts are tightened correctly in the correct
    order and correct torque they have not seen a rotor warp
    "With one qualifier, presuming that the hub and wheel flange are flat and in good condition and that the wheel bolts or hat mounting hardware is in good condition, installed correctly and tightened uniformly and in the correct order to the recommended torque specification, in more than 40 years of professional racing, including the Shelby/Ford GT 40s – one of the most intense brake development program in history - I have never seen a warped brake disc."
    YES if some hambone power-shoveled on the lug nuts with a Harbor-freight throw away jackhammer you bet your ass rotors can have
    some sub-mm warp and that translates into a pulse
    it's likely in need of dropping all 4 wheels and reinstalling them correctly at 80ft lbs on the lug nuts
  7. May 16, 2016 at 12:11 PM
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
    Probably an unbalanced wheel. I recently had my tires rotated and the tech notified me that the tires he put up front were out of balance. I have very similar brake pulsing/vibrating issues now.
    127.0.0.1 likes this.
  8. May 16, 2016 at 12:11 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Tires wear differently. It's possible that one of the rear tires had uneven wear from before, and now it's affecting the front end. Properly torqued lug nuts could play into it, too.
    127.0.0.1 and Arailt like this.
  9. May 16, 2016 at 12:12 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    also what seabass and arailt said ^^
  10. May 16, 2016 at 3:14 PM
    DEMikey
    DEMikey Mr. Badwrench
    mikey
    delaware
    2013 red taco
    100XR, OTW Surf Rod Rack, Toytec 3" lift, +1 on tires
    Why was it in need of a balance? Just curious. I always ask this because if there is a defect spotted, the best balance in the world may not correct it an now you have created a problem.
    If it In fact instantaneously happened after the rot and b, I would go with wheel seat/over torque. But a tire that was out back that has very high road force could "talk" more when the weight is transferred to the front under heavy braking. Hth.
    Arailt likes this.
  11. May 16, 2016 at 6:49 PM
    wes_peebles
    Wes
    Thanks everyone. The tires were rebalanced and are smooth when driving, I'm only having issue when applying the brakes. Ill pull the wheels off and confirm a good seat and torque and see if that resolves the problem.
    REDdawn6 likes this.
  12. Sep 7, 2018 at 3:00 PM
    Yinzer
    Yinzer Well-Known Member
    2012 Micah Green 4x4 SR5
    Hi, what did you find?
    scottalot likes this.
  13. Sep 8, 2018 at 1:27 PM
    jhinderliter
    jhinderliter Well-Known Member
    West central il
    2009 Double Cab TRD Off Road
    Now that’s funny
