Brake rotor turning is a waste
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stillwell-Taco, Aug 16, 2018.
  1. Aug 16, 2018 at 3:09 PM
    Stillwell-Taco
    Stillwell-Taco [OP] Well-Known Member
    06 sr5 trd prerunner
    So I replaced my front brakes, at 171,xxx. Tried once again like an idiot that forgot I’ve tried before to have my rotors turned. No need to waste money I thought. I don’t care if my front rotors are 20 years old if they spec and turn right. But once again I got bit in the ass. Take off after replacing everything, brake pedal feels like shit and like I need to shove it a mile to get anything done. Driving over 65 results in what I call the Yoo-hoo effect. As in I could tape a bottle to my steering wheel and it would get shaken good and plenty. Braking from high speeds results in the same shit only worse. So with only a week and a half on my pads I order a new set of rotors from Rock Auto. They came in this evening, swapped them out. Pumped pedal up. Started truck, took off down the road and it’s like it’s brand new again. All those problems gone. Brake pedal tight as can be and responsive. So for anyone reading this, when you do front brakes, I finally learned in my 35 years today, just spend the money on new rotors. I see a lot of post and questions about brake troubles, just replace the damn rotor and be done. Same goes for drums. I don’t care what anyone tells you! Ok my bitchin is done. Thanks for listening.
  2. Aug 16, 2018 at 3:26 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Not that I have rotors turned anymore either but who turned them?
    Agreed if they spec they should work. I’ve tried turning my own but not on a brake lathe and failed.
    Of course 6 month machinist at the time now with 30yrs in the trade I still wouldn’t do it.
  3. Aug 16, 2018 at 3:56 PM
    Stillwell-Taco
    Oreilly is where I normally go. Granted that may be part of the problem. But it’s been the same result any time I’ve ever tried. Everyone can’t be that retarded at using a lathe. It’s a pretty simple operation in the end. Of course you’re right, might wanna make sure it’s a rotor lathe I suppose.
  4. Aug 16, 2018 at 4:00 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    As cheap as they are new,I have never had mine turned,its new rotors,and the cost of turning your old ones is not much cheaper than just buying new.
  5. Aug 16, 2018 at 4:11 PM
    Dan 77
    Dan 77 I leave my bikes outside
    Dan
    San Antonio
    06 DCSB TRD Sport 4X4
    Kings and TC UCAS 01 DCSB 4X4 Totaled All-Pro bumper, mile marker winch
    I've had my rotors turned for my 02 Grand Prix back when I was driving it. I paid under $20 for the fronts to be done.
  6. Aug 16, 2018 at 4:14 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Information I've come across(web search) claims rotors are not as thick as in the past in order to reduce unsprung weight - helps mfgs. more easily meet CAFE stds.
    These thinner rotors supposedly don't turn as well as their ancestors - not as much to shave off as before.
    Last time I had rotors turned was about the turn of the century - 1995 Isuzu Rodeo.
    Stillwell-Taco[OP] likes this.
  7. Aug 16, 2018 at 4:24 PM
    Petrol
    Petrol Well-Known Member
    Central Va.
    Tacoma
    I ran a brake lathe many years ago and there are a few things at play.
    The first is there's a limit to how much run out you can correct by removing metal.
    Second, if you remove too much material the rotor will warp the first time it gets hot and at that point you would be better off if you had just replaced the rotor to start with.
    Third, the alloy used in the rotor is critical. Some rotors just can't be turned and some are far more prone to warping than others.
    The reality is that rotors have become fairly economical and it's generally easier to just replace them.
  8. Aug 16, 2018 at 6:14 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I'm at 190,000 and mine have been turned twice. It cost me about 1/2 of what one new rotor would cost each time. They work fine. I'll need new brakes again at about 230,000 and will need new rotors then.
  9. Aug 16, 2018 at 8:14 PM
    Stillwell-Taco
    It was 12 a piece for them to be turned. 47 with shipping for new ones. I wound up spending both trying to avoid one. Fml. I just think it’s a case by case thing but a lot of guys I have read on here complain after doing brakes of the same symptoms I had, and new rotors fixed it. Who really knows, we all just take an educated guess at the right thing, and hope for the best.
  10. Aug 16, 2018 at 8:17 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    12 bucks is a small price to pay to learn a lesson. ;)
  11. Aug 16, 2018 at 10:25 PM
    93yotasr5
    93yotasr5 Well-Known Member
    Sacramento
    Very odd. I’ve had the rotors on many vehicles turned without any issues. I’m wondering if the guy who turned them didn’t even measure or check the clearances before he worked on them. I’ve brought rotors and flywheels in and have been told they are out of spec. That’s when I bought new ones.
  12. Aug 17, 2018 at 4:07 AM
    Stillwell-Taco
    I watched him put the calipers on them to at least measure before and they were right at the edge of enough to turn. We both agreed it would be the last time they could be. The guy there seems pretty knowledgeable about it.
  13. Aug 17, 2018 at 4:58 AM
    Petrol
    Central Va.
    Tacoma
    Having done that type of work in the past I can say that it isn't exactly rocket science but the outcome isn't as predictable as one may think.
    The cost of brake rotors, adjusted for inflation, has come down over the years. It was significantly cheaper to turn rotors (and drums) 30 years ago than it was to buy those parts new 30 years ago. As the cost of replacement rotors came down, there was less incentive to turn used ones in an attempt to extend their service life.
    Vented rotors (the ones with the hollow space between the two outer surfaces) are usually a little more amenable to turning than the solid types. Of course the solid types are almost always less expensive to start with.
    The alloy used to make the rotor is important. Some suppliers get it right and make good rotors. Some suppliers just turn out a part that looks like a brake rotor.
    An important consideration when deciding to turn or replace rotors is the amount of run out. (how far from being perfectly flat is the rotor surface).
    Overall thickness is the pass/fail measurement after the rotor has been turned. If you have to remove a lot of material just to get the run out to near zero but the final thickness is still within spec, it's probably not worth turning.
    Because they get paid to turn rotors and not to measure rotors, some shops will simply turn the rotor until it's flat, measure it to see if it's still within specifications and charge you for turning the rotor. If they had to remove a lot of material just to get it flat, even if it ends up being thick enough in the end; it's probably not worth putting back on the vehicle.
  14. Aug 17, 2018 at 5:17 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    It is important to understand WHY brake shimmying happens.
    When you understand this you understand why you don’t reface rotors.
    Make sure you properly bed in your new pads and rotors or you can develop a shimmy again.
  15. Aug 17, 2018 at 8:12 AM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    Wow. This is pretty ironic.
    Just for the hell of it, literally yesterday I called up my local machine shop (just about the only one left in town...) to ask about turning my rotors.
    My dad (being a frugal MF) always says "oh you should get them turned" whenever I replaced my rotors.
    Kinda like a jab at 'us old people FIX our stuff, you youngins just throw it out and buy new'.
    For years he says "you should get xxx turned" - rotors, flywheels, drums, etc.
    I finally call a machine shop just to see the price and turnaround time.
    The guy says "uh...yeah we can turn a rotor, but we barely do that anymore." I ask why, pretty much already knowing the answer. "Costs $45 to turn them, but sometimes you can buy a new rotor on Rockauto for $35. Just doesn't make sense. And not all rotors can be turned. If it's .450 right now, and the limit is .430, but it comes out at .420 when I'm done, then it will just warp again in a couple months."
    At $45, it didn't make sense to me. But I suppose we have a high labor rate here. Turnaround time was quoted at 2-3 hours though :notsure:
    I think the issue here is - ROCKAUTO rotors are like $30-50. OEM rotors are much more expensive. If a OEM rotor from the dealer is...$120? and you want that "OEM quality" then it makes sense to turn them.
    I'm not much of a sucker for 'OEM quality' but there have been times I've removed an old, beat-up OEM part, and it still looked better than new Raybestos, Moog, etc.
  16. Aug 17, 2018 at 8:52 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I have not turned a rotor in 30 years, replace is so much easier than dealing with a busy machine shop
  17. Aug 17, 2018 at 9:03 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Agreed. The economics have changed, it doesn't make sense to turn them anymore.
  18. Aug 17, 2018 at 10:27 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Do vehicle OEMs/Dealers pre-break in brakes before selling new cars?
  19. Aug 17, 2018 at 10:29 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    totally...theres a reason rotors and drums are cheap...
  20. Aug 17, 2018 at 10:32 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    Im in the auto inditray at the dealer level, or "stealership" haha! There is more to tuning rotors than putting them on a machine and walking away till it's done. If you take off too much to fast they will warp. If you dont manage the harmonics they will warp. The best way to machine rotor is on the car. That way if there are any variances it the hub or rotor hat they are accounted for. Machining on the car is the best way to do it. After machining rotor they have to be cleaned.
    Most people dont want to someone to do the whole brake job. I get it. It a f-ing lot of money to pay for a brake job.
    Thebubble likes this.
