Brake Recommendation for Towing
Discussion in '1st Gen. Tacomas (1995-2004)' started by life as ben, Aug 26, 2017.
  1. Aug 26, 2017 at 2:55 PM
    life as ben
    life as ben [OP] Well-Known Member
    Getting ready to replace my rotors and pads up front, I tow a 3,500lb camper. Any recommendations?
    My truck is a 2002, 4x4, manual piece of awesomeness.
  2. Aug 26, 2017 at 2:57 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    Are they currently wore out?
    I'd be looking really hard at the rear brakes. It's been my experience that they're the most neglected and are usually out of adjustment.
  3. Aug 26, 2017 at 3:07 PM
    chvymechanic
    chvymechanic Well-Known Member
    Thomas
    New Hampshire
    04 Limited TRD Off Road 4x4 Xtra Cab
    Stuff and Thangs
    Tundra Brake upgrade!
  4. Aug 26, 2017 at 3:09 PM
    Rockymtntacoma
    Rockymtntacoma Well-Known Member
    Jake
    SLc,UT
    03 ext cab 4x4 v6 5 speed sr5
    Dual cases, triple sticks, 4.88’s, Harrop e-locked f/r, 35’s, boosted
    Search for the tundra brake upgrade. You can fit the tundra's larger calipers and rotors. I plan on doing it soon.
  5. Aug 26, 2017 at 3:15 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Best Upgrade that I've done! You'll really feel the difference! GL!
  6. Aug 26, 2017 at 3:21 PM
    Rockymtntacoma
    Jake
    SLc,UT
    Also while checking the rear brakes make sure the proportioning vavle is adjusted correctly, especially if your rear suspension has been lifted or modified for heavy loads.
  7. Aug 26, 2017 at 3:52 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    My last brake pads and Rotors I bought at Toyota
    So far so good .
    My Truck seldom goes more then a few miles empty
  8. Aug 26, 2017 at 4:58 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    If you have trailer brakes, that are property set up, it won't matter all that much as long as the brakes you have on the truck aren't worn out. At 3500# I certainly hope you have brakes back there...
    Tundra brakes are cool when you are running bigger/heavier tires and need the extra stopping power. For a trailer with brakes, IMO it's not all that necessary. Just make sure your brakes are in good working order, and maybe get some higher performance/friction pads.
    If you don't have brakes on your trailer, get them! Even tundra brakes would struggle to stop an extra 3500#...
    I tow a ~2500# trailer, and I'm planning to install brakes on it. My stock brakes (both the 04 Taco and the 17 4Runner I have) did just fine, but I wanted extra control for the hills (hence the trailer brakes).
    Blkvoodoo likes this.
  9. Aug 26, 2017 at 5:46 PM
    preybird1
    preybird1 02 taco on 37's
    Russ
    Salt lake city Utah
    2002 taco s\c
    Trd S\C with nosecone hybrid bearing upgrade kit. 2.0 urd pulley, 7th injector kit-urd "6 fabtech lift with 3" body lift. 20" XD spy wheels with toyo open country r\t's in 37"x 12.50x20. Front and rear diffs re-geared to 4.88 dirty 30 drive axles. and a rhino pack clutch. Custom exhaust and huge mudflaps!
    You NEED to do the tundra brake upgrade. I also HIGHLY recommend the lc engineering steel braided brake lines and brakeperformance.com cross drilled and slotted rotors with a ceramic pad. JUST AMAZING UPGRADE. I have no abs and 37" tires and 2000lbs over stock weight on board all the time . This upgrade is A MUST DO!!
    Dalandser likes this.
  10. Aug 26, 2017 at 7:53 PM
    life as ben
    Thanks for all the replies and useful info!
    Yes, I have properly setup my trailer brakes, I wired in and use the Tekonsha P-3 controller. My trailer brakes are dialed in and work great! Makes such a difference (oh, and in most states are required over 1500lb).
    But yeah, my truck's brakes are in need of some love...getting close to wear warnings.
  11. Aug 27, 2017 at 12:56 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Tundra big brake or GTFO!
    I went with 2002 tundra after market rotors, rebuilt Wagner calipers and ACDelco ceramic pads. Nothing fancy and more brake then you'll ever need. 2 hunting 4x4 quads a trailer and gear is no problem going down a 7% grade.
    The Driver and Dalandser like this.
  12. Aug 27, 2017 at 7:08 AM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    There used to be some rear disk conversion kits available. I read at the time, that they were great for trailers. They put the stopping power at the rear wheels where the trailer weight is.
    Ritchie likes this.
  13. Aug 27, 2017 at 12:07 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    DIRTY SEVENS.... sweet!
  14. Aug 27, 2017 at 6:38 PM
    Glamisman
    Glamisman Well-Known Member
    I was at my local Toyota dealer and they had some 18" take offs from a new vehicle that was sold with some aftermarket lif/wheels/tires. $900 for 4 brand new 6 lug 18" factory wheels/tires. My parts guy said there is some wiggle room in the price... If I had seen this 2 months ago I would have borrowed one to see if it fits and if it did I would have gone with the big brakes.
  15. Sep 3, 2017 at 6:58 AM
    1997tacomav6
    Denver
    The safest solution is electric brakes on the trailer where the brakes pull from the rear as not putting all the load on the front brakes without electric brakes. With a controller you have control over the brakes if more braking power is needed
    Green stuff 7000 series are fantastic and get drilled and slotted rotors,
    But the best you can do is have trailer with electric brakes, that will solve all you brake issues with a trailer, I have a double axel with electric brakes and have no issues with braking,
