Brake Power Low/Pre Collision Malfunction???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RookTRDOR, May 24, 2021.
  1. May 24, 2021 at 8:14 AM
    RookTRDOR
    RookTRDOR [OP] New Member
    2020 Cement Tacoma TRD OffRoad
    Hey yall! Have these warning messages appeared for you before and what did you do to resolve them? Any help or advice is greatly appreciated!!20210522_153316.jpg 20210522_153314.jpg 20210522_153312.jpg
  2. May 24, 2021 at 8:29 AM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Check your brake fluid level. If it's good, I'd guess your electronic brake booster isn't working. Check the fuse for it. If the fuse is good, the whole booster may be f'ed. Edit: Of course, there's more possibilities, this is just a guess.
    ORtoCOTaco likes this.
  3. May 24, 2021 at 9:04 AM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    Have you made any recent changes to your truck such as larger tires or a lift? If not then I’d take it to the dealer and let them figure it out; it should be under warranty.
  4. May 24, 2021 at 9:15 AM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Hook up an OBD reader if you can? Some local parts stores do free readings if you don't have one.
    Go from there.
    I had a brake override malfunction and it told me exactly where the problem was. Throttle body was stuck open.
    Good luck
  5. May 17, 2022 at 12:41 PM
    SlavaTheShrimp
    SlavaTheShrimp Well-Known Member
    Slava
    I have the same issue.
  6. May 19, 2022 at 1:20 AM
    JMR-4runner
    JMR-4runner New Member
    2020 TRDORP 4Runner
    Sorry I’m not a taco guys! but I have been having some issues and there’s a thread on another forum. If you want to hop over and see the mess it’s been, I’ll link it below.
    soundman98 likes this.
  7. Jun 12, 2022 at 8:19 PM
    aggie1974
    aggie1974 Member
    Charlie
    2023 Tacoma TRD Sport
    Just had this exact same issue in my new 2022 SR5 with 700 miles on it. Thanks for the heads up on what was repaired.
  8. Jun 13, 2022 at 7:20 AM
    SlavaTheShrimp
    Slava
    Replacing the ABS harness in the rear fixed and got rid of all the lights. Hopefully yours did too.
  9. Jan 19, 2023 at 8:39 PM
    bfox4848
    bfox4848 New Member
    I just had this exact thing happen to my new 22 TRDOR... 2000 miles.
    Sounds like it is electronics with the brakes?
    Considering this is a brake issue, is it safe to drive to the dealership or does it need to be towed?
  10. Jan 20, 2023 at 6:49 AM
    SlavaTheShrimp
    Slava
    I had the same issue. my issue was that the rear ABS harness was ripped off from the sensor. Check your ABS harness to see if it’s intact.
  11. Jan 20, 2023 at 6:53 AM
    bfox4848
    bfox4848 New Member
    squirrels....:mad:
  12. Jan 20, 2023 at 6:54 AM
    SlavaTheShrimp
    Slava
    Did you confirm it?
  13. Jan 20, 2023 at 8:45 AM
    crookedcoast
    crookedcoast Well-Known Member
    2025 OR
    I had the same thing, for me it was a shot speed sensor, getting the codes read should tell you for sure.
