Brake Pedal Vibration when stopped and moving.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by McNugget, Jan 2, 2018.
  1. Jan 2, 2018 at 3:07 PM
    McNugget
    McNugget [OP] Member
    I've found a few threads on this but not a definite solution or explanation. I have a 2013 Tacoma with about 80k miles that I purchased new and this just started happening today. There is no way I missed this before....
    Anytime I press that brakes beyond 70% there is a slight vibration in the brake pedal. Its very much like the typically ABS vibration but only 5-10% of the strength. It feel almost as if I have my foot on a cell phone that's set to vibrate. The vibration only lasts 1.5 seconds then stops. This occurs while and I am driving and while I am in park at a dead stop. I can recreate the issue with every press of the pedal.
    I called the dealership and they had no clue what I was talking about. They asked that I bring it in for a free brake inspection. I will take them up on that but wanted to check with you guys first.
    Brake fluid is slightly over the max line, maybe 1/2" inch and I have never bled the lines. I replaced the pads 4 months and have had no issues until today.
    Thanks.
  2. Jan 2, 2018 at 3:15 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Is your truck an off-road with the TX Pro package added? If so the vibration you’re feeling is almost certainly the electronic brake booster pumping the pressure back up as you use the brakes.
    Jimmyh and bubbakingaroo like this.
  3. Jan 2, 2018 at 3:22 PM
    McNugget
    Yes, TX Pro.
    If that is correct, why have I never felt this before?
    ma2co likes this.
  4. Jan 2, 2018 at 3:35 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Let make a discrimination here. There was the T|X Pro package, and the T|X Baja , but not a T|X Pro Baja.
    That stated, they are based off the same functional level of truck, the TRD Off road. As stated above you have the electric boosted master cylinder found on all TRD OR 4x4's 09+ (and some trucks pre 09 optioned with the VSC package).
    The vibration you feel is the electric pump filling the brake fluid accumulator. I have it on my truck and have gotten used to it, There have been 2 or 3 times where an air bubble got in the line or something happened where the vibration was MUUUCH worse (happened only after VERY VERY cold nights up at the ski resort) but worked itself out over a day or two, its been a year or two since it had that "issue"
    Tig3r_Bit likes this.
  5. Jan 3, 2018 at 9:10 AM
    fshams
    fshams Well-Known Member
    Columbus, OH
    2012 Tacoma V6 4x4 TRD/TX PRO - DCSB
    When was the last time you checked your rear brakes? I had a similar issue with my last 2003 Tacoma and it turned out to be the rear drums. All was good once they were replaced and brake shoes readjusted. It might be worth while checking in to.
    ma2co and scottalot like this.
  6. Jan 3, 2018 at 9:15 AM
    McNugget
    Interesting, I live in Utah and my truck is constantly outside in cold temps this time of year and have never felt this vibration before.
    I will give it some time and report back.
    Thanks for the suggestion. I will check them out.
    ma2co likes this.
  7. Jan 3, 2018 at 9:15 AM
    tacozord
    tacozord Well-Known Member
    2015 DCLB 4wd SR5
    Icon suspension, ARB front bumper, Pelfreybilt rear bumper, Warn 9.5-XP winch, Demello Offroad sliders
    I am no brake expert, but my neighbor is (30+ years at Ford!) Anyway, I recently changed my front brakes with his help, and we've been having a lot of discussions on the topic. At one point, I was sensing a vibration in the steering wheel when hard braking. He said that one reason for this could be warped rotors, especially if you're feeling it in the brake pedal.
  8. Jan 3, 2018 at 9:19 AM
    McNugget
    This issue also occurs when the truck is in park so that rules out the rotors.
    YE2KA, ma2co and Jimmyh like this.
  9. Jan 3, 2018 at 9:23 AM
    tacozord
    2015 DCLB 4wd SR5
    Ah...I overlooked that detail. Oooops. o_O
  10. Jan 3, 2018 at 10:04 AM
    nd4spdbh
    SoCal
    Yes like stated, its the master cylinder electric accumulator pump. I can guarantee you can make it run for 10+ seconds straight if you get in your driver seat, pump the brakes 5 x with the truck off, turn the key on but dont start the truck, and you will hear the pump run to refil the depleted accumulator.
    Jimmyh likes this.
  11. Jan 3, 2018 at 10:19 AM
    Pigpen
    Northwest Montana
    You are far overdue for a brake fluid flush. There's a lot of water in there, even though Utah is arid. The temp shifts cause water to condense in the system. Brake fluid is designed to absorb this water. Not sure if it will solve this "problem", but you're overdue by a couple years.
  12. Jan 3, 2018 at 10:27 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    yes, brake fluid is hygroscopic
  13. Jan 4, 2018 at 5:57 PM
    McNugget
    Update:
    I took my truck into the dealership today and they said its a failing hydraulic brake booster pump.
    Quote was $3100.00.
    ma2co likes this.
  14. Jan 5, 2018 at 6:13 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    owwwwwch!
  15. Jan 5, 2018 at 7:43 AM
    McNugget
    Um yeah.
    The Toyota certified part is $2500 and $600 in labor. They also don't want the vehicle to leave the lot until the repair is complete because its a ticking time bomb for catastrophic brake failure.
  16. Jan 5, 2021 at 8:36 AM
    D-fern_19
    D-fern_19 New Member
    Daniel
    19 TRD off road
    Just started feeling the same vibration in my 2019 off road! Haven’t even had it for a 2 years and on a lease
    YE2KA likes this.
  17. Jan 6, 2021 at 1:05 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    LOL. :rofl:
    No. They just saw your fat wallet and want to lighten it up a bit. You need to tell them to pound sand and to explain how they determined it was failing.
    You need to go elsewhere and get a real evaluation if you are concerned.
    That is what the pump is for. It runs and acts as the vacuum brake booster would on a normal vehicle.
    CurtB likes this.
  18. Jan 6, 2021 at 3:39 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Another example of why so many hate dealership service depts.
  19. Jan 6, 2021 at 7:00 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Ok....lets play Devil's advocate.
    Say your brakes have a "catastrophic" failure.
    There are safety features built into the truck.
    1st: Front and rear hydraulic brakes are on separate hydraulic circuits. Unlikely, you would lose both circuits at the same time.
    2nd: Emergency brake is cable actuated. If both hydraulic circuits fail, the E-brake will still operate the rear brakes.
    3rd: Hydraulic and E-brake fail. Shut off the engine, leave it in gear. It will come to a stop.
    Statements like that from a dealer are only uttered to instill fear driving you to a hasty decision.
    Suggest finding another dealer or shop.
    Jimmyh likes this.
